Question about AEG S75348KG Bottom Freezer Refrigerator
AEG S75348KG Bottom Freezer Refrigeratorg5 - AEG S75348KG Bottom Freezer Refrigerator
  • Broc Mudflap Dec 01, 2012
    Hi, the issue is that the unit when powered up goes straight into defrost mode. Please help
Freezer iceing up stoping fridge been chilled
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 09, 2011 | AEG S75348KG Bottom Freezer Refrigerator
Water is appearing under the front left foot (as you look at it). It builds up in to puddle over night. I have checked the instructions which are difficult to follow (not very clear English) but it said...
Freezer drain is plugged.
Two solutions:
1. Call a service repair company.
2. Turn off both controls (turn to lowest setting) and open freezer door for minimum of 24 hours (max 48 hours). That will thaw drain sufficiently.
What has happened: Somehow the freezer drain had ice build-up and eventually froze solid. Every time the unit went into defrost mode, the melted frost (now water) had no place to go. The normal exit is the freezer drain hole which leads to the drip pan underneath. That exit is plugged with ice, so the water went where it could - across the freezer floor and out the bottom of the freezer door. You found it and wondered why.
Mar 20, 2011 | AEG S75348KG Bottom Freezer Refrigerator
AEG S75358 freezer working but fridge not cooling
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 15, 2011 | AEG S75388KG Bottom Freezer Refrigerator
Aeg santo has stopped working, no power to it
Check the wall outlet for power and your breaker box for a popped breaker. Rate me if I am correct!
Aug 26, 2010 | AEG Santo 3888 KG8 Bottom Freezer...
Recently bought brand new with no instruction
email the maker with serial # and date of purchase/seller.they will supply you with one.....
Jul 10, 2010 | AEG S75348KG Bottom Freezer Refrigerator
Fridge freezer not keeping temp
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Apr 11, 2010 | AEG Santo 3888 KG8 Bottom Freezer...
Changing the doors.
tip unit back so you can see bottom hinge and unscrew it , remove plus blank from doors and rehang door on the other side inset blank plugs and stand freezer upright DO NOT turn on power if it has been lying on floor for an hour or two
Jan 26, 2009 | AEG S75348KG Bottom Freezer Refrigerator
Can I buy spare shelves for an AEG santo 3790-6 KG fridge/freezer
MAYBE,GO TO SEARS .COM CLICK ON PARTS PUT IN YOUR MODEL NUMBER AND SEE IF THEY HAVE YOUR PART,ALSO TRY REPAIR CLINIC.COM-MIKE
Dec 06, 2008 | AEG S70408KG Bottom Freezer Refrigerator
AEG S75348KG Bottom Freezer Refrigerator Logo
41 people viewed this question
Top AEG Refrigerators Experts
Oscar Netto
Oscar Netto
Jim Goldsmith
Jim Goldsmith
ashburton
Are you an AEG Refrigerator Expert? Answer questions, earn points and help others
