Question about GE Spacemaker JVM1640SJ Microwave Oven
GE SpacemakerXL Microwave EMO2000 950 Watts
The microwave runs but is not heating anything. It sounds like a little crackling noise when operating. What is the problem???
  • 5 more comments
  • ekfroed Jan 10, 2009
    Thank you for your response. I would not try to fix it myself I would have it repaired if it was cost effective rather than buying a new one. It was manufactured in March 2000. In the owner's manual it has a nine year warranty stating that they will send a replacement magnetron tube if the magnetron tube fails because of a manufacturing defect. Do you think this is what it is?
    I would like to try to do it myself.
    Thank you so much for all of your help. It is greatly appreciated. Have a great night.
  • Anonymous Jan 11, 2009
    microwave does not heat. it runs fine.
    thanks
  • helpIneedhel Jan 13, 2009
    My sounded off with a loud electrical spark pop after I was boiling some pasta below it. Now it comes on with a louder sound and no heat. Everything else seems to work properly. It has been a great product until now.
  • jason May 11, 2010
    ok , well you will need to call ge and tell them about the magnetron failure and how the replacement for this known defective part can be fixed without charge or just a service charge. since they will not just give you this part to replace it yourself. and ask for a service number near you so you can get this repaired or if they can set up the repair,
    here is the main number : 1-800-626-2005
    it sounds like the "magnetron" has failed and sparks are arking inside from the "high voltage capacitor" and or wire
    are you trying to fix it yourself or are you thinking "repair shop"/"new one" ?
MicrowaveSvc
  • 9086 Answers
SOURCE: GE JVM1650SH Stainless Steel 1000 Watts Microwave Oven?
It sounds like you may have had an issue with a high voltage part such as the magnetron, diode, or transformer. It's also possible that you had an arcing stirrer. I would also check to see if your model is covered by / affected by this bulletin: http://microwavedisplay.com/ge_mw_mag_kit_bulletin.pdf If you or a friend decide to work on it, we have *critical* safety & disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your full model number (without the suffix) here: http://tinyurl.com/gv383
Posted on Apr 29, 2007
fridgetech
  • 473 Answers
SOURCE: GE PRofile Spacemaker XL Microwave Oven Model# JVM1460 950 watts
Sounds like the problem is in the high voltage. Most common would be magnatron, capacitor and diode. For safety reasons this should be checked by a professional. Look in your owners manual because some high voltage parts have a longer warranty than 1 yr.
Posted on Oct 10, 2007
MicrowaveSvc
  • 9086 Answers
SOURCE: ge spacemakerxl microwave, jmv1850
Your primary interlock (bottom door switch) is bad, or its mount is loose or broken.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
It's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
Posted on Jan 18, 2009
ginko
  • 19396 Answers
SOURCE: microwave not heating
Test the high voltage capacitor, the rectifier diode.or the magnetron.
If it additionally does not spin and no light, then check also the door switch.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Posted on Apr 27, 2009
  • 18 Answers
SOURCE: GE SpacemakerXL Microwave oven clicking noise
Spacemaker t/t motors are very easy to change. Removed the screws from bottom of microwave. the bottom panel will found towards wall. Mtr is in very center of unit. Should have 2 wires going to it
Posted on Nov 21, 2009
Solution-GE spacemakerXL microwave oven model:JVM16505H01 mfg.date:feb.2005
Sounds like you have a bad smart board, you can try unplugging the unit for five minutes and then back in, if you are lucky this may correct the problem...good luck
Feb 18, 2014 | GE Microwave Ovens
I have a GE SpacemakerXL microwave that stopped working after I heard a loud pop. Everything else works, but it does not heat anything. Help?
From the descriptions it likely the magnetron has failed. If you have a digital multimeter post me a comment and I will give instructions to do a rough test.
Jun 06, 2012 | GE Profile Spacemaker Over-the-Range...
Rattling, crackling type noise just started and is constant when microwave is running.
A couple of months ago my microwave started making crackling, rattling and grinding sounds everytime i used it and i thought it was going to break down. It turned out one of my children must have spillled or overflowed something with a clear liquid because the micro did not look dirty but there was a crunchy substance under the wheels of the turntable. Once i cleaned this up totally the noises all went away.
Jan 19, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Microwave will start then make a different sounding noise and will not heat anything that is put in the unit
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Nov 16, 2010 | GE JVM1650 1000 Watts Microwave Oven
Not heating up food / drinks. makes a "crackling" sound when turned on
heatman101
Oct 05, 2010 | GE XL1800 1100 Watts Microwave Oven
Nov 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My GE microwave, model #WES1450DM1BB; serial #SM908139U, shows
When I try and heat some food, the microwave runs but doesn't heat anything, its a model wes1450dm1bb
Mar 15, 2009 | GE XL1800 1100 Watts Microwave Oven
Microwave not heating
Feb 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE XL 1800 quit heating
I don't like to pass on your problem but it sounds very much like either the high voltage supply ot the magnetron has bit the dust.
Either one would make the repair marginal at best.
This is apparently not a very good unit, many microwaves jsut kind of fade away as their magnetron emissions decay.
This one seems to have a bad rep. look at this link:
http://www.fixya.com/search/p489218-ge_xl1800_1100_watts_microwave_oven/not_heat
Sorry, have owned a lemon or two myself.
Aug 27, 2008 | GE XL1800 1100 Watts Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
156 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
