I have a Weil mcLain Gold gas furnace and the Amtrol WH-7L hot water maker. I heat alot with an indoor woodstove and if the furnace is not being used I cannot get any hot water. However, when the furnace does kick in and run for awhile I have hot water. would I be having a thermostat problem with my Amtrol and if so can I get a replacement part for it?
  • 3,287 Answers
You should download & review the manual for Amtrol Boilermate products here.
Page 12 of the manual begins examples of wiring between the Boilermate and aquastat (also gas valve and multi-zone relay), that is usually mounted on the boiler. In order to use it correctly, you'll need to determine which aquastat (or other device) your furnace has. You should be able to locate this info on the inside of the aquastat cover. The Honeywell Triple Acting aquastat is very common and looks like this:
I have a Weil mcLain Gold gas furnace and the Amtr - 11_29_2012_7_17_38_pm.jpg
The cover is held by a single screw on the top, bottom or front (depending on the model you have). The inside should have wiring information along with the model number. Compare the model number with the wiring diagram for it in the Boilermate manual.
Make sure power is OFF before continuing.
Check that all wires are terminated and undamaged. Make sure terminal screws are not loose. Tighten any found to be loose.
The orange wires are connected to a switch that is normally OPEN but CLOSES to start the boiler when the hot water has cooled. It is also used to operate a "power vent" for a minute or two both before ignition and after flame out for safe pre and post purging of the combustion chamber of furnaces that lack a chimney.
Blue wires are connected to a switch that is also normally OPEN but CLOSES to start the boiler when the hot water has cooled. When the switch connected to these wires is CLOSED, ignition happens instantly. There is no delay for purge so when these wires are used to start a furnace, it should be one with a chimney - not a power vent.
For additional help with your particular installation, you will need to provide information concerning the wiring diagram in the manual that applies. Otherwise, there are simply too many variations to walk through.
I suspect that the switch(es) that are connected to the orange (or blue) wires - or the device (aquastat or multi-zone relay box) is not operating as expected to start the furnace.
The troubleshooting section of the manual that seems to apply best is the section: Boiler will not operate when calling for hot water on page 27 (if you want to try some of their suggestions while waiting for additional replies).
I hope this helps..
Posted on Nov 29, 2012
vanni7
  • 163 Answers
SOURCE: 3 amp fuse blows on a carrier 58mcb furnace board
Hi!!! Does your ac unit work fine?If not check your low voltage problem..You have a low voltage problem check the wire going out to your condensor make sure that they are not touching..Good luck..Check low voltage wires..short in progress..
Posted on Jan 04, 2009
  • 2920 Answers
SOURCE: Furnace fires for 10 seconds then cuts off
have the thermocoupler checked
Posted on Jan 17, 2009
pierre1811
  • 144 Answers
SOURCE: my furnace is leaking water when the heat is running
You probably have a 90+% efficient furnace. They produce condensation. Does it have PVC vent pipes? If so there is a drain tube for condensation.
Posted on Jan 23, 2009
koolbreezes
  • 540 Answers
SOURCE: i have a white rogers thermostat, it wont click on
Did you connect the jumper wire to rc---rh on the thermostat?
Posted on Dec 08, 2009
  • 10 Answers
SOURCE: I have a suburban lp furnace and duotherm air/heat
I'm not sure what the problem may be but you could try calling All Seasons RV Appliance Parts & Service. There number is 1-800-344-0673 they have helped me in the past. That and there tech calls are free so it wouldn't hurt to give them a call.
Posted on Feb 16, 2010
Operating worcester bosch 240 gas boiler
  1. If there is no water on the floor, your crack is probably OK so far. The water thing is a worry though. NEVER fire a boiler that is low on water. Adding water to a hot boiler will crack it. Tell me all you can on what components you have in the water and gas lines.
Nov 15, 2013 | Weil-McLain Heating & Cooling
Amtrol water heater WH-7P gets barely warm water
From what you are saying it sounds like an issue with either a circulator pump or a zone valve. It depends on what type of system you have ... if you have a circulator pump that only runs the Amtrol then that is probably bad. If you have a zone valve system then it is probably the zone valve if you still have heat for the rest of the house. If you have no space heating then it is probably the circulator pump.
Nov 04, 2009 | Water Heaters
AMTROL Boiler Mate - No hot water
Most likely either a bad controller (which is the little display you use to reset) or the temperature probe which is accessible on the underside of your tank. Sensor is a 2 wire probe in center of underside and easily replaced.
Jun 08, 2009 | Water Heaters
Heating & Cooling Logo
252 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
