New laptop battery not charging
Is there something I should be doing...other than putting battery in and charging it....The lights stay at amber , despite lengthy charging...could this be a faulty battery
  • 2 more comments
  • micatap Jan 10, 2009
    The same problem here, Acer Aspire 5560 series. I have a new - replacement battery and it wouldnt charge. If I boot the laptop with this battery it says the battery is wrong and it turns off. If I put it in when the laptop is running and unplug the AC power, the laptop works... But the system doesnt recognize any battery... I have had this problem before with another battery and it stoped running when the battery was going to die. Since then I never managed to recharge the battery. It looks like this time is the same - the battery doesnt charge... I tried newer bios, didnt help... Any suggestions??? Please help. Thanks. Andy
  • micatap Jan 11, 2009
    Hey, thanks for the post. I think my charger is fine because it works with my original battery that I had with the laptop... When I insert the new one and want to turn the laptop on without AC adapter the laptop starts beeping for few seconds and then turns off (doesnt boot at all). With my AC adapter it says the battery is wrong but it boots the system properly... But it doesnt recognize the new battery at all... The funny thing is that it works even if I unplug the AC adapter and go on the battery power... The light that indicates the battery is flashing - orange into green - normally green light is when the battery is fully charged and orange when its dying. I have no clue if it is charging the battery or not so maybe I just try to run it on the new battery until it dies and then see if I will be able to recharge. If yes, I will still have problem turning the laptop on... Well, a lot of information. Hope you can help me with this... Thanks a lot. Andy
  • wklemme Mar 09, 2009
    IBM T41... has been working great but the other day gave me notice that the battery needed to be charged and said I should save my work. Problem was I had it plugged into the wall outlet and have been using it that way almost all the time.
    I tested the charger and saw 14 volts output. The laptop will run on the charger alone with no battery inserted, but will not charge the battery if I insert one. I bought 2 more (used but good) batteries and they do the same thing. Yellow light stays on when battery is inserted.
    This does not seem to be a battery issue or a charger problem. What else can it be?
    Bill K
  • Stephen Scheneman
    Stephen Scheneman May 11, 2010
    It's possible...how old is this laptop and battery, and what kind is it?
    Sergeant:
    Champion:
  • 259 Answers
If you have had a couple of different batteries why not look at the charger If you have a Multi meter test the voltage and the see if it is putting enough in If you do not have a multi metre a small one can be purchsed under $20 and it can be used to check other things You need to eliminate things Battery then Charger and then laptop and if what you have said is not the battery it is most likely the charger
Posted on Jan 10, 2009
Why is my battery light staying on constantly
You mean, your laptops shows your battery is charging when charger is no connected? Is it amber or green?
How well does the battery work? Are you getting at least 90 minutes on just battery power? If not, maybe the battery is not working well. Remove the battery, turn on the computer, shut the computer off and restart the computer with the battery installed. Maybe if you reset the battery the computer will "see" the battery as new and after awhile of charging the LED should go from amber to green. While you have the battery out of the computer, check the battery contacts on both the battery and the computer. Make sure that they are clean and not corroded or damaged.
If your battery level is ok and your battery keeps it's charge, let it alone. You wouldn't like to send to repair tour laptop just for that.
Aug 10, 2015 | Dell Latitude E6410 Laptop Computer (Intel...
I just got a brand new Satellite Toshiba touch screen laptop yesterday for chritmas and its plugged in and charged over night but wont turn on unless its plugged in. Is this temporary? or is something
As long as the charge is not complete the battery LED remains amber.
Give the laptop the time to charge: it should take 3 to 4 hours it it is not being used, and 3 times longer if it is used.
You do not need to register immediately with Toshiba.
Dec 27, 2013 | Toshiba Satellite P105-S9722 Notebook
I purchased a new battery for my Dell Latitude 810 and it still won't hold a charge. The battery indicator light is green for a brief period, turns amber and then shuts off.
If you installed a new battery in your Dell computer and still can't get it to charge, there is a strong possibility that there is something wrong with the charging system
Mar 07, 2013 | Dell Latitude D810 Notebook
Battery charge light flashing amber
Ok, lets start slowly, do you have both a new battery and a new battery charger? If both attempt to use your old battery with the new charger. Also could be a bad charger or a shorted out battery...
Good Luck
Feb 13, 2013 | HP Compaq nx9600 Notebook
Battery light flashing amber
Is the battery a exact spec.? Some aftermarket batterys, inexpensive replacements, do not play-well with your laptop. If you purchased from a computer store, return for a replacement. That said, It may be that it's not fully charged or need to be drained and charged, cycle it a few times. Some batteries have to go through a "learning" process. It says fully charged in windows software, right? again, some replacement batteries don't play-well with windows.Its a "pins" thing in the battery connector.
Nov 19, 2012 | Lenovo Computers & Internet
Battery light won't change colors, drops to 0% once unplugged
Let the battery completely discharge all they way and let it sit for a day or so. Some times when a battery is new most user do not let it fully charge and then completely drain this causes problems for long use batteries. Then give it a try. It also sounds like your plug your cord that connects to the battery may be faulty. Did you by a different cord with the battery? Or use the one from your old one? If you did. This is a "No No" always buy the cord that come for those battery since they are rated for the particular battery.
Feb 25, 2012 | Fujitsu LifeBook A1110 Notebook
1721 Inspiron shows flashing amber, three times, then blue.
The cells in the battery are starting to go bad which is why the light is blinking the way it is.
Once you get a new battery put in there the light will stay blue instead of flashing amber.
Jul 04, 2009 | Dell Latitude D600 Notebook
Amber light constantly flashes when trying to charge
Hi there.
The battery could be faulty, power off the laptop, take out the AC power and the battery wait 2 minutes and put the battery back in, turn the laptop an and look at the indicator LED to see if its changed, if it has plug in AC power and see if its the same.
Good luck and thanks for choosing FixYa!!
Jun 01, 2009 | Packard Bell Easy One II 3136 Notebook
Toshiba 1410-S173 battery charging light blinks amber
did you buy the battery brand new or used?
brand new, deffectibe motherboard, bad charger or bad dc socket.
used, change it.
Mar 03, 2009 | Toshiba Satellite 1415-S173 Notebook
Computers & Internet Logo
1,590 people viewed this question
David Payne
David Payne
