A4tech hd 200 driver for windows 8 - Computers & Internet
Is the Pandigital SCN02 Photolink One-Touch Scanner compatible with Windows 8?
Are you using it currentrly? What is your current Operating System? I've been searching and can't see anywhate a windows 8 driver for this scanner.
Bu let me tell you, I'm using currently a Genius ColorPage, originally released for windows 98. Installed windows 2000 driver in compatibility mode for findows XP. There is no driver for Windows XP nor for Windows 7 and coldn't make it work in Windows 7. So I run it on a computer with dual bootWindows XP / Windows 7.
When I need to scan, I simply start up as windows XP. When finished scanning, reboot to windows 7
I Have Windows 7 on a 2 Tb HD SATA and Windows XP on 200 Mb IDE. Is more economical to have a dual boot then buy a new Scanner.
If your scanner won't run on windows 8, install on another HD or a partiton, Windows 7. doual boot Windows 7 / 8 work like a dream.
See comments for this scanner in Amazon;
Amazon com Customer Reviews Pandigital SCN02 Photolink One Touch Scanner...
Jun 11, 2015 | PANDIGITAL Office Equipment & Supplies
Windows 8 compatible a4tech
1st You download Webcam Driver.
a4tech Webcam After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Other Companies Camera Drivers for Windows XP Vista Windows 7
May 25, 2014 | A4tech PK-635 Webcam
I need a driver and software for my hd 1080p
software for my Camera After this install the Webcam driver in the system.
Feb 21, 2014 | A4tech A4 Full HD 1080p Webcam with...
A4tech PK Pc camera lens 2 8 download
A4tech PK Pc camera After this install the Webcam driver in the system.
Nov 25, 2013 | A4tech PK-635 Webcam
A4tech Software After this install the Webcam driver in the system.
Nov 25, 2013 | A4tech PK Computers & Internet
I need a software of a4tech "PK-770K" fow window 8
software of a4tech After this install the Webcam driver in the system.
Oct 09, 2013 | A4tech "PK-770K PC Camera , built-in mic.,...
Will an a4tech web camera work with windows 8
Click start control panel view devices and printers you should see your webcam from there if you are have trouble with your webcam Click start control panel administrative tools computer management device manager scroll down image devices you could see a yellow question mark? right click to reinstall drivers or update driver xp Click start right click on computer select properties device manager scroll to image devices expand right click to update driver in W7 http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for IE: webcam name webcam driver you might have to try a few times to get it right software if you dont have the driver you will need to download one here rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8 It might take some time being a freeware driver solution note: it will find all of your outdated drivers this is a free driver solutions This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updated Some webcams and programs require additional software, although that should be installed with the webcam if things are right. But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date. But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c - Windows Vista: DirectX 10). http://windows.microsoft.com/en-US/windows7/Which-version-of-DirectX-is-on-your-computer Hope this helps.
Jan 16, 2013 | A4tech PK5
Dc 7600 is no saund
You have SP3 and HD audio give this a try:
This patch is required before any of the HD device drivers are installed
1. On your PC change the CSDVersion registry key to XP SP2:
HKLM\SYSTEM\CurrentControlSet\Control\Windows\CSDVersion value=200
2. Restart your PC
3. Install KB888111xpsp2.exeHD_Audio/kb888111xpsp2.exe and your audio driver.
4. Change the CSDVersion key back to XP SP3 again:
HKLM\SYSTEM\CurrentControlSet\Control\Windows\CSDVersion value=300
5. Restart your PC, finalize configuration of your PC, sysprep and capture.
Simplified Directions
Goto Start>Run and type in regedit , then click OK.
Click the plus signs in front of HKEY_LOCAL_MACHINE, SYSTEM, Current Control Set, Control, and finally, click Windows.
In the right panel you will see CSDVersion.
Right click it, choose Modify.
In the highlighted input window, you should see 300. Change it to 200.
Click OK, close regedit and restart your PC. Windows will now think it is SP2 and allow you to install the UAA and your HD audio driver.
Make sure to reboot and then test your sound BEFORE, changing the value back to 300.
Then follow the same steps to change it back to SP3. Change the 200 back to 300.
Jul 22, 2011 | HP Compaq dc7600 Convertible Minitower PC...
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
