Question about New Balance Balance 1500 Treadmill
Lubricant needed for new balance 1500 treadmill
Treadmill belt needs periodic lubrication applied with foam pad wand.
    Top Expert:
  • New Balance Master
  • 12,223 Answers
1) the deck belt can be use 100% silicones or wax if your model use wax.
2) rollers bearing use WD-40 or similar for lube bearing.
God bless you
Posted on Nov 30, 2012
2 Suggested Answers
roadtech7
  • 297 Answers
SOURCE: my new balance 1500 treadmill
It sounds like you have a bearing failing, either in the front roller or the motor. If it is the front roller it will be a dull "Clicking" noise, if its the drive motor it will be a growl noise. The growl will be so loud at top speed you wont be able to even talk over the noise. Remove the motor hood and this will help you determine the culprit.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Posted on Nov 04, 2010
Can I fix a NB1500 treadmill belt that is bowing in the middle? I've tried adjusting the tighteners on the back and cannot eliminate the bowing in the middle.
No, you need a new belt as it is stretched because that is where it gets pounded all the time. $50 to $100 depending on the quality you choose.
New Balance 1500 Treadmill Walking Belt 20 x 119 - Treadmill Doctor
https://www.treadmilldoctor.com/new-balance-walking-belt-1500
Replacement Walking Belt For The New Balance 1500 Treadmill. Belt size 20" X 119".
New Balance 1500 Treadmill Walking Belt - eBay
www.ebay.com > ... > Fitness Equipment & Gear > Other Fitness Equipment & Gear US$94.99 - ‎In stock
New Balance 1500 Treadmill Walking Belt in Sporting Goods, Fitness, Running & Yoga, Fitness Equipment & Gear, Other Fitness Equipment & Gear ' eBay.
Amazon.com : New Balance Treadmill Running Belt Model 1500 ...
https://www.amazon.com/Balance-Treadmill-Running-Belt-Model/.../B00H4QKAOO Rating: 5 - ‎1 review
This is a 1-ply Residential walking belt, some sellers will try to sell you a 2-ply belt (claiming better quality) for your treadmill, which is not recommended for ...
Amazon.com : Treadmill Doctor Newbalance Treadmill Running Belt ...
https://www.amazon.com/Newbalance-Treadmill-Running-Belt-Model/.../B008EYOF... Amazon.com : Treadmill Doctor Newbalance Treadmill Running Belt Model 1500 : Exercise Treadmill Belts : Sports & Outdoors.
NB1500 treadmill belt Google Search
Aug 14, 2017 | Exercise & Fitness
Hi, my Pro Form 470cx has just started to stop when I walk on it intermitently. The belt is running perfectly until I stand on it and then it appears to stick instantly on the base causing a stall in the...
Susan,
The most common cause of belt slippage is lack of lubrication. Most treadmill belts use lubrication on the underside of the belt to reduce friction between the belt and the platform. This helps the treadmill glide along smoothly under the weight of a person. If your belt is lacking in lubrication, it can catch on the treadmill platform. Apply lubrication every few months to the underside of the belt to prevent this from occurring.
A petroleum or silicone based lubricant is recommended, and most easily applied in a spray can. Simply lift up the belt about midway along the platform and spray a small amount of lubricant underneath from about the middle of the platform width to the closest edge. Repeat from the other side. Apply lubricant sparingly...it can be messy.
Next, turn on the treadmill and let it run for a minute, then check if the belt still sticks. A little more lubricant may be necessary.
Hope this helps.
Regards,
DIYpro
May 04, 2011 | Sport & Outdoor - Others
I have a pro form treadmill and it seems like the belt is sticking, its about 14 yrs old. I think I might need to replace the belt
kilgore511,
The most common cause of belt sticking or "slippage" is lack of lubrication. Most treadmill belts use lubrication on the underside of the belt to reduce friction between the belt and the platform. This helps the treadmill glide along smoothly under the weight of a person. If your belt is lacking in lubrication, it can catch on the treadmill platform. Apply lubrication every few months to the underside of the belt to prevent this from occurring.
If you have found this helpful, please take a moment to give me four thumbs up.
Regards,
DIYpro
Apr 29, 2011 | Proform Exercise & Fitness
The belt on my running machinet207 is sliping when you stand on it
Jo,
Hope this helps.
Regards,
DIYpro
Apr 27, 2011 | Sport & Outdoor - Others
Screen states Lube Belt , do not have user Manual , Where are lubrication points and what type "lube" can I use ?
hi,
It is necessary to lubricate your treadmill running deck every six months or 150 miles to maintain optimal performance. Once the treadmill reaches 150 miles, the console will display the message "LUBE" or "LUBE BELT". The treadmill will not operate while the message is showing. Hold Stop for 5 seconds to suspend message for 5 miles. Your treadmill came with a bottle of lubricant which can be used for two applications. If you need lubricant, contact Horizon Fitness. Only use lubricant provided by Horizon Fitness.
• Turn off the treadmill with the on/off switch, then unplug the power
cord at the wall outlet.
• Loosen both the rear roller bolts. (For best results, place two removable
marks on both sides of the frame and note roller position). Once the
belt is loosened, take the bottle of lubricant and apply it to the entire
top surface of the running deck. Tighten both rear roller bolts
(matching up the marks for proper position) to original position. After
you have applied lubricant, plug in the power cord, insert the safety
key, start the treadmill and walk on the belt for two minutes to spread
the lubricant.
• Lubricate the air shocks with Teflon based spray.
• Once lubrication is complete, reset the console by pressing and holding 'STOP' and Speed '+' buttons for 5 seconds.
ok
Dec 26, 2010 | Horizon T91 Treadmill
Electric motor overheats
This machine has what they call a thermal switch. It is designed to
shut the machine off if it gets too hot. This heat is caused by
friction. Friction is caused 99% of the time by the walking belt or
the drive belt. If it is the drive belt then it can be solved by
either applying a treadmill lubricant (must be made for treadmill
belts) or by purchasing a new belt. If you feel the underneath side
of the belt and you feel a screen door type feeling you just need
lubricant. If you feel a smooth surface you will probably need a
new belt. If you have lubricated in the past year and your belt has
the screen door feel then take off the motor hood cover and check
the drive belt. If it is worn then you will need to replace that.
You can purchase either of these products from the manufacturer, at www.iconservice.com. a couple of other places that may have them for discounts are www.ebay.com, www.fitnessrepairparts.com, or www.treadmilldoctors.com.
Aug 09, 2010 | Proform Exercise & Fitness
Squeaking noise from tread
usually when a treadmill begins to make a squeaking sound it means that the belt needs to be lubricated. Try Treadmill Belt Lubricant available at Canadian Tire for $10.99 and is good for Reebok treadmills.
Aug 06, 2010 | Reebok Exercise & Fitness
Need to lubricate the bell of my treadmill . how i do that..?
you will need silicone lubricant with an applicator wand and all you have to do is lift the belt up enough to get the applicator wand under and spread the treadmill silicone on the machine - be very careful that you do not use any other silicone except what is made for treadmills. My company sells this product for $18.95 and it usually will last 1-2 years with proper lubrication
Aug 05, 2010 | Nautilus Commercial Series T916 Treadmill
I have a 1400 that when it has been running for 20 or 30 minutes goes to Power Failure and generally throw me against the rail to an abrupt stop. I do believe it is home electrical as I run a 20 amp...
This generally means that lubrication is needed to be applied between the belt and belt. You may purchase these kits thru www.jadfitness.com the products name is Lube and Walk follow the instructions that come with it to apply the lubrication.
Jun 11, 2010 | New Balance 1400 Treadmill
DOES THE UNDERNEATH SURFACE OF THE TREADMILL RUNNING BELT NEED TO BE TREATED WITH ANYTHING BECAUSE IT SEEMS TO BE STICKING
Yes! these units need to be maintained depending on usage. for example: 2 people using a treadmill 3 times weekly for a period of 30 min @ a pace of 3 mph would need to apply lubricant on deck every 3 months. Any exercise specialty store or sporting goods that are selling treadmills should have these lubricant kits with instruction on how to apply it.
Now their is a chance that your treadmill may either need the running belt or drive belt (under motor shroud) to have the tension adjusted.
Mar 11, 2010 | Proform 730 Folding Treadmill Model...
New Balance Balance 1500 Treadmill Logo
193 people viewed this question
Top New Balance Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Howard
Howard
Are you a New Balance Exercise and Fitnes Expert? Answer questions, earn points and help others
