Projection hdtv 1080pi pt56wx53g convergence adjustment problem
Have a green, blue,pink wave at the bottom of the tv try to adjust the convergence and problem is still there
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Change the two stk-392-110 chips and look in front of them for any of the 2.2 ohm resistors to be bad.
Posted on Dec 22, 2012
MikeNJ1964
  • 398 Answers
SOURCE: Toshiba 56H80 Convergence Problem?
There are 2 large IC's in your set and one of them has burned out. These are called convergence output IC's and are usually the STK392-010's. A good idea would be to go ahead and replace both with the newer, upgraded STK392-150 IC's. A good tech can change those IC's in about an hour and a half, and when I do a housecall for a set like that I charge $150, but shops in your area will vary so be sure to ask around.
Posted on Sep 10, 2007
  • 133 Answers
SOURCE: Convergence issue?
This still could be the convergence . This will should be repaired by a tech if you do not know how to repair . Around $200 - $300 if you could get it to him or more if he has to make a service call . Call around for the best price as alot of shops vary in there charges. On this problem if it is the convergence make sure they will use the original IC's and not the cheap replacements as they do not hold up as long . Good luck
Posted on Mar 03, 2008
bestdarngood
  • 3037 Answers
SOURCE: Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
Posted on Mar 29, 2008
Slinteriors
  • 8617 Answers
SOURCE: Convergence adjustments
Replace both convergence ICs nuber STK392-040 that should take care of the problem. you can get new replacement ICs at the following link and they will send free instalation instructions with pictures so you can install the new ICs. heres the link.
http://servicemanuals.vstore.ca/
Posted on May 27, 2008
SOURCE: PT-47WX53G green convergence and wave on bottom of screen
Had same problem with Red. Could not adjust. Funny broken lines. Found this link:
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Replaced the ICs. Was disappointed at first 'cause it was still all bowed out, but then realized that the Convergence 2 "target" can be changed with the number keys. Working thru 1-9 and going back to readjust as necessary adjusted each one into perfect alignment.
Problem solved. TV works great.
I should add that while I am reasonable technically adept, I am a software geek and never soldered before... hardest part was getting up the courage to dive in and do it myself. Glad I did.
Posted on Oct 29, 2008
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
When i try to adjust the convergence, the red and blue adjust ok, i assume the green in the basline color, but it turns up on the right side of the screen and the picture has a green wave in the lower left...
The tv 100% have convergence problems,it dead,if have any colors lines mis alignment or don't stay in the convergence - + grid.The tv convergence board is dead.The 2 STK convergence ICS and some or all is resitors are dead.Must replaced these parts on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 11, 2010 | Panasonic PT-47WX49 47" Rear Projection...
The picture all of a sudden became blurred , color convergence is not aligned and there is a pink wave at the top left of the screen and a green wave at the bottom of the screen. When the color is adjusted...
Tv have convergence problems,it dead.Colors lines R,G,B don't aligned.The tv convergence board is dead.The 2 STK convergence ICS and some or all it resistors are dead,these parts must be replaced to solved the tv pictures covergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 18, 2010 | Sony KP-43HT20 43" Rear Projection...
Have a projection tv...RCA model 61830BL. Had
Hi the green cross it cant move that the reference for red and blue adjustement ;just try to put the red and blue cross over the green pattern then quit/
if that doesnt work you probly have the stk-xxx ic
who control the color alignment ,are blow/
you will have to replaced and make the convergence
check if you have an auto adjustement for that most projection tv have one...
hope that help..
Mar 28, 2010 | RCA P61830BL 61" Rear Projection...
My tv is having a pink and green lines. It looks
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 27, 2009 | Philips 55PW9363 55" Rear Projection...
My picture is not fitted to the screen.
go into the menu find convergence
some models have auto convergence
if you have the option to manual adjust convergence adjust red and blue DO NOT move green
Sep 02, 2009 | RCA HD52W59 HDTV Projection Television
Sep 24, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Jvc pos
when in manual convergence hit the select bottom to change to blue. as of green i have no clue.
Apr 17, 2008 | JVC AV-56WP74 56" Rear Projection...
Wave at bottom of screen with green and pink shadows
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Feb 17, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Pt-47wxs1ce green wave at bottom of screen cannot adjust green convergence
you have bad convergence IC's and possable 1 bad resistor
let me know and i will help you find them in the set if your are a good solderer - or call a tech
thanks
scott
Aug 30, 2006 | Panasonic PT-47WX51 47" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
