Question about Russell Hobbs GJS21A Microwave Oven
Sparks coming from microwave make rhm2018
Where is the filter
I have a Russell Hobbs RHM2018 microwave oven with grill and the turntable will not stop going round and the light stays on until I unplug it? Once plugged back in it carries on in the same way? If I
The switch for the turntable does not disengage anymore. Could be a relais, could be an electronic switch. When opening the door, a second switch, in series with the other one, connected to the turntable motor disengages, stopping the motor. The light is switched on, because you opened the microwave. Perhaps you never noticed this, but it is the normal way that should work.
Aug 31, 2014 | Microwave Ovens
Where is the bulb located on Russell Hobbs rhm2018
I have just done this myself on the same microwave - I know this was posted a year ago but maybe you still have it. Unplug the microwave. Remove the cover by unscrewing the screws on the rear and side. As you're facing the microwave, to the front right hand side on the top there's a black oval-ish shaped thing held in place by two metal clips (pictured). This is the light bulb. The clips easily lift up by hand, then you can gently lift out the bulb. With mine it turned out that the bulb wasn't broken it just hadn't been screwed in properly!8ada370f-1c5e-4600-8102-2c5c0b93f61c.jpg
Jun 18, 2013 | Microwave Ovens
Fire sparks when in use off pad on right side of microwave
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Jul 09, 2010 | Dacor DMT2420SS Microwave Oven
Sparks are coming from the bottom of the microwave
generally the microwave will only spark if there is metal on the container you are cooking with or you are operating it without anything in it. as it is that old and with all the advances they have made with microwave ovens ... if it is in the budget i would certainly suggest getting a new one
Jan 17, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Sparks coming from back of microwave
If you coffee container had any metallic logos or paint on it sparks will occur. Try to heat water in the glass container.
Dec 11, 2009 | Daewoo KOC-925T Microwave Oven
I heard a pop and then i saw sparks inside the oven, the sparks were coming from what looks and feels like a paper cover inside the microwave
This sounds like the inner lining is coming off and alloying the metal interior to spark. You will need to repair the liner and this should fix your problem.
Dec 08, 2009 | DCS MO-24-SS Microwave Oven
Microwave shorted out when metal grease filter contacted inside
It might be that the internal power fuse of the MW may have blown. You may have to just replace that fuse if possible. Other wise the electronics (most likely a circuit board) may have been blown.
Jun 29, 2009 | Frigidaire 1.6 Cu. Ft. Over-the-Range...
Sparks
usually sparks come from turning and cooking with nothing inside the microwave..if there is grease or something on the bottom the heat will generate a spark
Mar 22, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Microwave ovens
The cover is probably the magenetron. That is where the microwaves come from. If the bread was moist, it might have left condensate in the unit which is causing the sparking. Unplug the unit, leave the door open over night. If you can remove that cover, do so. Be sure to carefully replace it before using the unit. Never turn on a microwave with nothing in it.
Dec 16, 2007 | Sharp R-1480 Microwave Oven
Russell Hobbs GJS21A Microwave Oven Logo
23 people viewed this question
Top Russell Hobbs Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
paul
paul
Are you a Russell Hobbs Microwave Oven Expert? Answer questions, earn points and help others
