Question about Sharp SF 2540 Copier
Sharp SF 2540 - Sharp SF 2540 Copier
3 Suggested Answers
  • 62 Answers
SOURCE: f2 maintenance B required sf 2540 sharp photocopier
This is a drum code either the dm or id sensor.
Posted on Oct 09, 2007
  • 29 Answers
SOURCE: SHARP SF 2540 How to troubleshoot U3-20 and
U3,20 - Mirror motor lock detection
U7 00 - Communication trouble between PC/Modem and the copier.
Seems to me the U3 error is something similar to the L6 errors in the slightly newer machines. It seems as though the laser moter in your machine has seized.
As for the U7, i have had this error out on the field before. Especially when the machine has had IP setting put into the machine but the network cable isn't plugged in. Throws up that bad boy =]
Posted on Aug 19, 2009
My sharp SF-2540 it has a code H5-02
its an error code for the fusing unit
Sep 06, 2016 | Sharp SF 2540 Copier
Sharp 2540 code f2
F2 mean toner not supply .Change toner chip
Jul 12, 2014 | Sharp SF 2540 Copier
After powering on, it will show F2 on the Sharp SF 2540 Copier, So please, I need a programme code to clear it or any other solutions to solve it problem
You need to take it to a Sharp technician to check machine , usually a toner issue that toner is unable to replenish in developer unit and so blows the chip on toner cartridge ,
replacing toner cartridge rarely helps
seeing as it is a deeper issue
Sep 12, 2013 | Sharp SF 2540 Copier
How can I reset the password/ Copying code on SF 2540 copier
codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Aug 08, 2012 | Sharp SF 2540 Copier
MY COPPER HAS ERROR H5 . I want no problem my devise .
H5 is Lower thermofuse
Enter sim mode then enter 14 for Trouble cancel.
Jul 31, 2011 | Sharp SF 2540 Copier
I have sharp AR-163 it indicate f5 error. And Sf 2030 error code f2
Ar163 F5 = Copy lamp problem.
Possible causes are:
Blown Copy Lamp
Inverter trouble (copy lamp driver module)
MCU Board failure
This is most likely to be a blown copy lamp.
Ar2030 F2 is a process control error - depending on the sub-code it could be a number of different things. Please repost with the full code.
Hope this helps.
Feb 09, 2011 | Sharp SF 2540 Copier
Sharp sf 2530 hang
I would suggest to throw that old thing in to a pond see if it will float..
Oct 24, 2008 | Sharp SF 2540 Copier
Sharp sf.2540
Press C - interrupt - 0 - interrupt - flash
and then
14 and press start
Feb 26, 2008 | Toshiba e-Studio65 Copier
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
