Computer keeps rebooting on its own
I have stystem tiger computer that keeps restarting on its own it will not starton normal mode or last known settings help please
Unplug computer open it up take out battery remove hard drive, look on back of hd. do you see a small white plastic piece remove that but make sure you remember where its located at. now put hd back in reconnect cables put battery back in. plug your computer back in and restart. reset bios settings. let it try to boot. now shut computer off and we are going to do the same steps again.disconnet computer, open it up remove battery remove hd put your white piece of plastic back where it was before, reconnect cables put battery back in. connect pc and power up. should be able t boot from installation disk.
Posted on Feb 01, 2009
    Sergeant:
    Champion:
  • 259 Answers
Most likely a virus has or malware has got into the system try SAFEMODE and install or do virus check if this does not work get someone to download one of the well known free virus checks and when you use as boot CD it will do virus check other options are more drastic like take hard drive out and do virus check with another computer of Format but try and save date before these options are attempted
Posted on Jan 10, 2009
How do you fix the blue screen of death on a dell computer
Check if you can still go to the boot options once you start your PC.
How to go to boot options:
1. Restart computer
2. once computer is turning on, keep tapping F8 key
3. Boot options menu should now appear
4. use keyboard arrow to choose safe mode with networking or last good known configuration
If you are able to go to safe mode, it means that you might have installed a program or software that messed up your PC. uninstall the program then reboot and check if it will boot up normally
If safe mode did not work, use last good known configuration, this will attempt to load your computer on the last time it worked (previous days)
If the above solutions did not work, you can use the windows recovery cd that came with your computer. Here you can repair your computer using the fix and repair option
If all else fails, the only way to fix it would be to reformat the PC
Hope this helps
Jul 28, 2011 | Computers & Internet
Received 512 - chassis fan error on HP Compaq dc5100 ff - I replaced the front chassis fan after detecting fan was not working now when I attempt to log into windows - windows screen appears than...
By enforcing the option to return BACK TO THE LAST KNOWN GOOD CONFIGURATION you have nothing to lose. Respond if you have already selected that option with no success?
Bruce
Jan 12, 2011 | HP Computers & Internet
My acer 3260 have a start up problem apear blue screen and when i run desktop i able to use some time automatic stoped and apear ***stop: 0x00000CE
When you reboot the computer please press F8you will get "advance boot option" Please select "Last known good configuration" .
If it not working reboot the computer press F8 go to Safe mode. In the safe mode go to command prompt and type this command "chkdsk /f /r" after that please restart the computer. After restarting please go to Normal mode.
Aug 05, 2010 | Computers & Internet
Unit wont start, gray screen then goes to a screen with options on how to start unit and then goes blank
Answer:To load the last known good configuration in Windows 2000 / XP reboot the computer and as it's booting booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Last Known Good Configuration" and press your Enter key.
Trouble Getting into Windows 2000 or Advanced Options menu - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message as the computer is booting. If this occurs instead of pressing and holding the "F8 key" tap the "F8 key" continuously until you get the startup menu.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
As can be seen from the above example, you should be able to highlight and press enter to load the last known good configuration. Once completed the computer should restart and attempt to load into Windows.
Will running the Last Known Good Configuration delete anything?
No, running the last known good configuration will restore your last good system settings and will not delete anything. The only thing you may have to reinstall programs you have recently installed because the configuration for those programs may have been lost.
Jan 27, 2010 | NEC Versa VX Notebook
My lenovo keeps rebooting..when I select ''last known'' it shuts down and restarts the process again
Try to see if you can boot up the computer into safe mode. Keep pressing the F8 key as you turn on the computer and when it gets to the boot menu choose "Safe Mode".
If you can get into safe mode then go into the start menu and go into the system tools folder and then choose system restore. Choose a date on the calendar when the computer was last working properly and let the system reboot and hopefully that will take care of the issue.
If you can't get into safe mode or windows normally then that means windows is corrupted and you'll need to wipe out the drive completely and reinstall the OS and device drivers.
Dec 10, 2009 | Computers & Internet
I have a boot problem...
From the boot with CMD prompt get to C:/ the type chkdsk. It may say that it cant do it till it restarts, but that is OK allow it to reboot. After it has repaired the lost bytes allow it to reboot normally. This may not be the total solve if you have a virus or trojan but 99 times in 100 it will fix it. I also recomkmkend you to use a program called RESTOREIT it costs about $40 but is better than MS restore last known... REST sits in its own partition before windows and allows recovery instantly by selevcting space bar and selecting restore points
Aug 13, 2009 | Averatec 6100 Notebook
Had a power outage and now computer keeps rebooting. saw solution about going to my computer properties advance and unchecking automatically reboot, but cant' get there because computer keeps rebootin
hi
while rebooting u press the F5 key for a while, it will redirect u to a boot menu,in this boot menu u have some special options to boot like boot in safe mode,safe mode with networking ,debugging mode,last known good configuration boot,start normally,etc u first boot in safe mode and try to deactivate rebooting in ur own technicand u have more options try all of them it will be ok in 2 or 3 options
Thank You '
Dnt Foget to Rate me
Apr 21, 2009 | Acer Veriton M410-UF9500P Desktop
Hi from london, have new acer aspire 1 zg5 new keeps shutting down after boot can u hlp pls?
Try booting the system to Safe mode.
To boot to safe mode:
Restart the computer. As soon as the BIOS has finished loading, keep tapping on F8 key on your keyboard. When the Windows Options menu appears select the "Safe mode" then press Enter.
Once you managed to boot to Safe mode, change the computer startup and recovery settings by right-clicking "My Computer" then select Properties. Select Advanced tab. Under Startup and Recovery, click Settings. Uncheck the box for "Automatically restart" under System Failure.
Reboot again normally, see if it will reboot again by itself. If you managed to make the system boot normally, proceed to Events Viewer to find out what is the caused.
If the system failed to boot normally after doing the above, you might want to boot the system to "Last known good configuration"
Jan 11, 2009 | Acer Aspire 3690-2196 Notebook
COMPUTER KEEPS ON REBOOTING ITSELF.
Supose you have allready tryed to change "restart the computer" to "shut down the computer" when you shut down the computer?
/Teis
Jan 04, 2009 | Computers & Internet
Computer Keeps restarting
start in safe mode, and uninstall
Jan 06, 2008 | Dell Dimension 8200 PC Desktop
Computers & Internet Logo
206 people viewed this question
David Payne
David Payne
