Question about Craftsman Garden
I have a 2000 riding garden tractor Mod # 917.273080 with a Hydro Gear Transaxle Ineed to know what oil I need for it (222 301 ol) 02561057) made in USA
What type of oil do I use in the Hydro Gear Transaxle & how much do I put in or how do I know wen it full. Thanks Dave
  • 6 Answers
SOURCE: Craftsman Transmission problem
Some of these tractors have a friction wheel that is driven off of a flat wheel on the bottom of the engine drive shaft. The rubber ring on this friction wheel could be worn out, or it could be out of adjustment.
Posted on Apr 22, 2009
  • 95 Answers
SOURCE: I have a 20 hp craftsman lawn( hydro gear
It sounds like the oil in transaxle is degraded.The transaxle is supposed to be a sealed unit requiring no service but over time the oil will get dirty enough to cause problems like you are describing.Remove the back hitch plate and look at the transaxle it will have a rubber vent hose or a 1/4 alllen wrench fitting on top. You will need to purchase a battery suction bulb from sears automotive and use it to remove as much oil from transaxle as possible. Warm the transaxle up first by running it around,then suction the oil out.Refill with a good synthetic motor oil 15w-50 or 20w-50 like Amsoil or Mobil 1.Do not use transmission fluid or hydraulic fluid. When adding the new oil back fill it to within 1.5 in from the top,be sure to allow this amount of air space in top of transaxle for expansion.
Posted on Jul 31, 2009
  • 138 Answers
SOURCE: Craftsman hydro gear transaxle problem
check the brake for sticking and dragging. check the bypass lever, make sure it's disengaged fully. did you just fix a flat rear tire? if so, the square key that links the axle and wheel fell out. do you pull a heavy garden cart around? that can stretch a belt and overheat the trans. last thought, check the belt and see if it came off a pulley, i know that should have been first but it's late and i'm tired. good night
Posted on Aug 22, 2009
kel1guy2002
  • 3740 Answers
SOURCE: lawn mower has hydro gear transaxle reverse was
Most of the time when this happens the reverse shift linkage is too short. It is usually cause by either a bent linkage or worn linkage bushings.
The internal shifting fork can be bent inside the transmission which is rare but does occasionally happen... most of the time it is a linkage problem. Also check on the side of the transmission to make sure the shifting lever has not moved from the original position on the Yoke shaft.
Thanks for using FixYa.
Kelly
Posted on Mar 29, 2010
wilsodfarm
  • 986 Answers
SOURCE: My craftsman tractor model #
One thing you can try is to drain your fluid and refill with stp oil treatment,it not a perment fix but it will help you for now,and maybe you can trade,I have had this happen to me and it worked
Posted on Aug 29, 2010
Transmission repair or replace
Jim, The links below are what I found on the Net., You could also do a search with your year, make and model# for possible better results. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Rebuilding lawn tractor transaxle Part 1 of 2
1 Hydrostatic Garden Tractor transmission rebuild 1 of 4 Hydro Gear
Tractor hydro transmission rebuild part 1
Part 1 K46 hydrostatic drive Removal
MTD Transaxle Basic Rebuild Replacing all Bearings Part 1 of 2
Aug 20, 2016 | Huskee Tractor Replacement Riding Lawn...
A diagram of the transmission on a cub /zero turn/tank
Michael, The dealer may print the diagram off for you, just try asking them nicely. Check the attached links,instruction and guides, Good luck
Cub Cadet Riding Lawn Garden Zero Turn Tractor transmission diagram Google...
Cub Cadet Riding Lawn Garden Zero Turn Tractor transaxle diagram Google...
https://www.cubcadet.com/wcsstore/CubCadetCatalogAssetStore/Attachment/owners%20manuals/residential/ZF50_02005033-08-1.pdf
Jul 02, 2016 | Cub Cadet Riding Lawn Garden Zero Turn...
Ariens model 935335 hydro tractor leaking what appears to be grease or oil out of seal around the axle where it comes out of the transaxle also how to check fluid in the transaxle
look for a dip stick it may be color coded with a yellow end or their may be a tag directing you to were it is located the seal may be bad
Apr 14, 2014 | Ariens Garden
How to put oil in transaxle
You should have a plug in center of axle. Takes 14mm wrench.
Apr 12, 2014 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
WHAT TYPE OF OIL DO I USE ON MY TRANSAXLE MOD 917.273080
Hydrogear transaxels take a multi grade oil 20-50 the filler is a brass plug on the top, there should be a 1/4" air gap at the top to allow for expasion, Tuff Torq units also take a multi grade oil 10-30, these units normally have a resevoir on the top with upper and lower fill marks.
Dec 10, 2012 | Garden
Tansmission oil type for model# 917.254740
Your Craftsman is equipped with a Agri-Fab transaxle, the predecessor to the Hydro-Gear brand. The recommended oil is 10w-30. Unfortunately, the transaxle on your craftsman tractor is not serviceable. It is sealed for life. The only way to change the oil is to remove the unit from the tractor, tip it upside down and drain the oil out the reservoir plug.
Jun 16, 2012 | Craftsman 24 Hp 48" Deck Yard Tractor
Wat typy of oil to use in the hydro gear box
My name is Dane and I am going to help you solve your problem.
For your mower, the transaxle is a sealed unit. There's no distick or other way to check it. They don't want the operatpr messing around with it. But I know I wouldn't go to the shop unless I had to, so you probably won't either. I put their phone number at the bottem, and added a link to your manual here.
http://www.husqvarna.com/us/homeowner/support/download-manuals/?query=Yth24v48ls&types=O
1-800-487-5951
I hope I've helped. Thank you! Dane
Dec 14, 2010 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
I have a hydro gear transmission i have changed oil and when it gets hot it will not move it is a simplicity rider 2000 mod.i need help please my email is wunrau@mymts.net thank you kindy
Your transmission is shot. You need to buy a new or used one and install it. Or there may be a rebuild facility which will rebuild yours. Either way it will not be cheap.
Aug 12, 2010 | Garden
I have a 20 hp craftsman lawn( hydro gear transaxle ) tractor in terrific shape that losses drive on a grade. I replaced the worn drive belt and it was good for the first few mows, Now Im right back to...
Jul 15, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a 25 hp -50 Filling transaxle with fluid?
Hi, I will try to help you. In the rear of the tractor on the right hand side as you stand behind the mower if you get down and look at right over the axle you will see a small hose with a plug in the end of it and that is where you put fluid in. Hope this helps. George
Apr 06, 2009 | Craftsman 26 Hp 54" Deck Yard Tractor
Garden Logo
60 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
