Question about Reddy Heater-30-55,000 BTU Variable
Ignition I have a reddy heater 35. When I plug it in the fan comes on, fuel dispenses, but then it trips the reset button. Why? When I removed the cover and repeated, I didn't see a spark at the spark plug but then again I don't know if it's supposed to be visible.
  • 232 Answers
This is a "probably". The reset button trips because the photocell fails to see a flame in the combustion chamber. That's its job.
Check the ignition device ( transformer, coil). See if 110v going in. If there is no spark coming out, replace it.
Troubleshooting tips
Posted on Jan 12, 2009
I have reddy pro 170 i plug it in , the fan & igniter comes on for 10 to 15 seconds then shuts off ,blew through fuel line and nozzle still same result, i do see fuel mist coming out nozzle ,i dont k
You must make sure the mist is not to close to the igniter . If it is it wont be misty enough to ignite. And make sure its in the path of the mist. If its new return it to the store.
Feb 07, 2015 | Reddy Heater Pro-Tough Kerosene/Diesel...
Reddy heater r100a unit comes on app 1 min then turns off tripping reset button
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Feb 02, 2011 | Reddy Heater-170,000 BTU Kerosene Deluxe
I have a reddy heater 100000 btu model r100a. Everytime I plug it up I have to push the reset button. It comes on only for about 30sec. Then the reset will trip back off and it shut down. What could be...
Does the heater light up before it cuts off. If it does, then you need to first clean the flame sensor. It is a photo type sensor. Remove the top from the heater and the flame sensor is a black rubber boot close to the burner. You can clean it with a soft cloth or a cotton swab and some alcohol. If the heat isn't lighting up before the reset trips, with the top off, start the heater and check the igniter. If it is OK look for fuel spraying from the fuel nozzle. Watch out for the fan while the top is off and the heater is on. If fuel isn't spraying out, check the nozzle for clogs and check the fuel filter. Let me know if you need more help and please rate the answer.
nitensheaterservice@earthlink.net
Jan 15, 2011 | Heating & Cooling
I have reddy htr 35 was running great,just stopped reset breaker lit right up then went out Pulled cover off fan and spark fine reset it lights right up can see the fuel atomizing flame starts...
Check your fuel lines and most models have a fuel filter in line. A few things come to mind one how old is the fuel? Check the screen in the nozzle assembly by removing nozzle it sits directly behind the nozzle, these corrode and affect fuel flow. While you have this tore down clean the fire-eye with windex and terry cloth rag, it may not be seeing the flame. Check the air filter at the back of the heater as well. These are common problems with these heaters.
Dec 13, 2010 | Reddy Heater-30-55,000 BTU Variable
When filled with kerosene then plugged in, the heater will kick on for about 3 seconds and the fan will run but it will not ignite, then it shuts off. reddy heater 55, 55000btu. runs on K1 or fuel oil.
REDDY HEATER 40 KEROSENE FIRES UP FOR A FEW SECONDS AND QUITS WITH A WHITE CLOUD OF SMOKE COMING OUT THE END
MY REDDY HEATER 35 KEROSENE RAN OUT OF FUEL AND WILL NOT RUN AT ALL WHEN PLUGGED IN
Jan 11, 2010 | Reddy Heater-30-55,000 BTU Variable
Dayton kerosene heater 3E219B will not turn on
I have a Dayton Model # 3e219b 150,000 BTU potable heater and it runs fine with the top cover off.But if I put the cover on it will go out is less than a minute and trip the reset.
Jan 31, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater-30-55,000 BTU Variable Logo
234 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
