Laptop wont boot to windows, and flashing a blue error screen
My laptop wont boot into windows, even in safe mode it half loads the drivers and the flashes to a blue screen which appears for a few seconds before the laptop restarts
  • 7,627 Answers
Do a system restore/recovery to a date before this issue. Unplug, remove battery, leave battery out during this procedure, plug into AC, Start tapping the F key that will start the restore/recovery page. You didn't give OS or other info. Did you do updates? Add software/hardware? What preceded the issue?
Posted on Nov 29, 2012
  • 317 Answers
SOURCE: Driver error upon boot
You have a corrupt OS, assuming you have XP, you should do a repair installation. Don't worry, none of your files or settings or installed programs will be deleted. You may have to reinstall some old device drivers though. * Insert the XP CD and boot to it * When you see " To setup Windows XP now, press ENTER", go ahead and press ENTER * You will now see an option to repair Windows by pressing "R". Do not select this option - it will only take you to the Recovery Console which is not what we want to do. Instead, choose to continue the installation * When you see the license agreement, press F8 to agree * On the next screen make sure your current XP installation is selected and then press "R" to repair XP * At this point XP will begin to install on top of itself, replacing damaged, missing or altered system files. Follow the instructions on the remaining screens to complete the Repair Install. It will look very much like a normal (new) OS installation. If all goes well your repaired XP installation will remain intact, keeping your personalized settings and installed programs as they originally were.
Posted on Aug 08, 2007
gabysrivera
  • 8 Answers
SOURCE: The laptop appears to boot but no display even on ext monitor
Check the memory bank "Ram"... If you don't know how to change it, I recommend you go to a professional that will test it for you...
Posted on Jul 21, 2009
mopar2009
  • 32 Answers
SOURCE: Cannot start up
Try this: Reboot and select Recovery Mode, then from the c:\windows prompt type: chkdsk
Let it run through checkdisk then try it should boot up.
Posted on Sep 15, 2009
danmats
  • 195 Answers
SOURCE: my asus eee pc 701 SD wont boot into Windows
reboot your laptop..
Posted on Oct 05, 2009
parrotheadpc
  • 2600 Answers
SOURCE: ibm thinkpad r50 notebook won't boot
Windows Start-up Errors
Step one, you need a Windows Installation CD. If you only have a recovery disk set like the ones from HP or Compaq they will not do what you need done. Under normal circumstances however, you can use a Dell disk because the Operating system is on a stand-alone disk. All retail versions are also acceptable as well as upgrade disks. For a rule of thumb, if the disk has the Microsoft hologram it should work. You can order a boot up floppy disk from here:
http://support.microsoft.com/kb/310994 with this file, if you know how, you can use “ImageBurn” to burn the file into an ISO file which can be burned to a disk. Now make sure your computer boots to the cd rom first. If you know how to do this skip on down, if you don’t, while the computer is first starting up and you see the manufacturers splash screen, tap F12 (some computers it’s F9, others it may be another key, you may have to watch and see if the computer lists the key strokes for getting to the boot menu. If you still cannot find it, boot into the BIOS settings and change your boot order there. Save your settings and exit, the computer will now seek the cd rom as its boot source first.
Place your Windows disk in the computer and start it up. When you see the test at the top of the page “Press Any Key To Boot From CD” Just hit the space bar to activate. The next screen you will see will most likely be a Windows setup screen, when you see this press the “R” key to get to the recovery console. It will get there, it may take a little time, patience. Once it loads you will be given a choice of Windows installations, there should only be one, if there are more, always pick number one. It may ask for an administrators password, if you have not set this particular password, then just leave it blank and press enter. The next prompt you see is:
C:\Windows>
You need to type the following:
cd \
hit enter. Pay close attention to the spacing between the characters. There is a space between the character “d” and the “\”
You are now at the ROOT of the drive, this is where basic commands can be given and changed. You should now see the following:
C:\>
Now type the following:
CHKDSK /R
Hit the enter key.
The chkdsk /r command also includes the P command and will also look for lost recoverable information in bad sectors.
There are occasions depending on how corrupt the system is, that this process could take several hours, so be patient with it.
Now, after chkdsk has run type the following:
FIXBOOT
Hit the enter key.
It may prompt you with a warning, that’s ok, just continue. When fixboot has finished, type: EXIT hit enter and windows will reboot. When the system reboots, tap the F8 key during this time and you will see the multi-boot menu come up. Scroll to the title “Last Know Good Configuration” and hit the enter key. If you were having some simple drive errors this should have fixed them.
Posted on Oct 15, 2009
Blue screen
Which operating system you are using??
You can follow the given steps to avoid blue screen error..
Start Windows in Safe Mode:
Step1: Turn on your computer and press the F8 key repeatedly from your keyboard. You must press F8 before the Windows logo appears. It will display the Advanced Boot Options screen.
Step2: From Advanced Boot Options screen, choose Safe Mode option then press Enter.
Step3: If Windows loads and works fine in Safe Mode, a bad driver is probably causing the error. Uninstall device drivers and reinstall them. If Windows experiences issues in Safe Mode also, repair your hardware.
Startup repair:
Step1: Shut down your computer and then restart it in Safe Mode (see step1).
Step2: From Advanced Boot Options screen, select "Repair Your Computer" and hit Enter. Choose your preferred keyboard layout and then click "Next."
Step1: Click "Startup Repair", and follow the on-screen instruction .Startup repair can solve this problem.
System Repair:
Step1: Follow step1 and step2 from Startup repair section.
Step3: Now select system restore from the System Recovery Options menu. And follow the on-screen instruction to select a restore point.
**If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Jan 24, 2013 | Acer Aspire Computers & Internet
Tip
Solution for Most common blue screen error of windows.
So many computer face this blue screen fetal errors on windows.
This error comes usually when there is problem in software or driver compatibility issue with hardware or operating system.
Also this error comes when there is bed indexing unit in hard drive.
You can solve this errors with following 2 methods.
(1)When you power up the computer press F8 key then enter in safe mode.
Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error.
(2)If you are not able to enter in safe mode Then you need to fix error on hard drive.For that you need windows disk or recovery disk.
Boot your computer with that disk
For that when you power up the computer press F1 or F2 "del" key to enter in bios.
Then go to boot menu and set first boot device as your cd or dvd rom.
Then save settings and exit bios.
Insert windows disk in cd /dvd rom.
Then it boot with that disk.Then you get this message "Press any key to boot from cd.."
Then press any key.
Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r"
Then type "y"
Then it fix error on hard drive.
Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windows " then it repairs old windows then it loads again old windows.
Thanks for using FixYa.
on Dec 01, 2009 | Computers & Internet
My Samsung R530 won't boot, just shows blue screen of death on startup, states "A problem has been detected and Windows has shut down to prevent damage blah blah blah Unmountable_boot...
Then press any key.
Then type "y"
Jul 12, 2011 | Samsung R530 Notebook
Few minutes after Windows starts the computer screen shows this blue screen with lots of white text and then it shuts itself off, then it restarts itself and then again, the blue screen and it shuts itself...
Then press any key.
Then type "y"
Jun 21, 2011 | Toshiba Tecra M2V-S310 Notebook
I install windows xp profetional in g62_b39se it installed compeletly but when insatll completed, an blue screen apeared whith stop massage
Power on Laptop & Click F8 Button then Safe Mode Menu Visible Select "Disable Restart After System Failure" Then U Wacth And Reply Error Msg And Error Code Fully.
Best Of Luck
May 07, 2011 | Computers & Internet
I have a virus and need to go into Safe Mode. I can't load my comp into safe mode, even after pressing f8 several times
try allowing the bc to half boot up, before logon page and while the windows is loading screen is there, press and hold your power button until it foreces a switch off.on next boot you should be offered the safe mode option.
Apr 30, 2011 | Dell Vostro 1510 Laptop
My laptop has come up with a blue error screen and will not let me in. The screen says "A problem has been detected and windows has been shut down to prevent damage to your computer.... Technical...
Don't give up try booting into SAFE MODE press F8 at bootup and choose safe mode, with networking. Then at least you can troubleshoot what is wrong, it is often a bad Video driver. It may require reinstalling or updating, or some other driver that is giving you this BSOD.
Feb 01, 2010 | Computers & Internet
Lenovo X60 Laptop blue screen error wont boot up
Try to go into safe mode by pressing F8 as soon as you turn on the laptop.
If you get into safe mode then go into system restore and choose a date when the laptop was working properly. Let it rollback to that date and reboot the computer and let it go and see if it goes back into windows.
If you get a blue screen even when trying to go into windows then the operating system is corrupted and you'll need to do a factory restore on the laptop, meaning the hard drive would have to be wiped out and the operating system put back onto the hard drive.
Aug 27, 2009 | Lenovo ThinkPad X60 Notebook
Password
Does it boot in safe mode?
To check, please follow the steps below:
1. Power on your computer
2. Immediately begin tapping F8
3. Keep doing so until you reach the Boot Options menu
4. Select Safe Mode
5. Press Enter
This will load windows using a minimal amount of drivers.
Jun 23, 2008 | Toshiba Tecra TE2300 Notebook
Unable to boot up after windows xp
If you can get into the BIOS, try setting with default settings.
Dec 19, 2007 | MSI K8MM-V Motherboard
Computers & Internet Logo
75 people viewed this question
David Payne
David Payne
