Question about GE GSH22JFR Side by Side Refrigerator
Ge gss25wgmd fresh food freezing
My fresh food area of the refrigerator is freezing my produce and I can't seem to make temperature adjustments to fix the problem.
  • GE Master
  • 4,654 Answers
You will need to perform a refrigerator self diagnostic test found in the service manual found here=> GSS25WGMD Service Manual
Then go to page 48 of the service manual (Damper Door Not Opening or Not Closing) GE ARTICA PROFILE TECHNICAL INFORMATION This test will help you determine if the problem is the damper, temperature sensor or the control board. Doing these test are not for everyone and may require that you have someone that can perform diagnostics. If you have questions please let me know, Thanks Sea Breeze
Posted on Nov 29, 2012
MNTECH
  • 1543 Answers
SOURCE: ge profile refrigerator PSS27SGNA BS....unit's
Check the air damper at the back top left of the fresh foods section to see if the damper door has broken and thus not able to close. It is electrically operated, but if it breaks, you can have your exact condition occuer.
Posted on Feb 03, 2010
  • 4 Answers
SOURCE: Side by side GE refrigerator freezing food in refrigerator.
The unit is having a damper control issue. In the back of the refrigerator there is an assembly that is in the center at the top. It connects to the freezer side. The damper is broken, cracked or has an obstruction. Check this and see if it is the problem.
Posted on Jan 09, 2009
SOURCE: GE Monogram freezing food
I got the same problem.
Temperarily solution:
Open the top hook overnight and you will see the temperature will return to normal i.e. 1 degree F
I suspect there is the thermostat or some type of thermal sensor that prevent the freezer to operate during summer time
Hope it help
Posted on Jul 28, 2008
SOURCE: GE side by side refrigerator freezes food in the
no cold air gos in to frig side
Posted on Feb 07, 2010
marka19
  • 1430 Answers
SOURCE: Refrigerator is too cold (28 degrees)
this is likely one of the thermistors on the fresh food side has failed. They are usually located under a small cover inside the fridge. They should have a reading of 15.5k-16.5k ohms at 72 degrees. They are easy to check and replace. Here is a link that should help. You can also enter your model # for diagrams and illustrations of your specific model. http://appliancehelponline.com/sxsfreshthermistor.html
Posted on Jul 16, 2010
GE psc23ng...the veggie bin is freezing vegetables and temp. on fridge and freezer does stay put!!
GE Appliances Customer Phone Number Shortest Wait Best Support
GE Appliances Calls You Instead
Good Luck
THE FIX
Avoiding Frozen Lettuce
By TIM McKEOUGHPublished: March 18, 2009
Q. How can I keep produce from freezing in my refrigerator?
More Articles in This Series
Jason West, the marketing manager for refrigeration at General Electric. "Nobody really knows what the temperature of B is, or what the temperature of No. 5 is."One solution is a refrigerator thermometer. Oxo makes a handsome one with a round dial attached to a suction cup that can be installed easily on either interior side wall ($12.99 atoxo.com). Taylor makes a rectangular digital one that is installed the same way ($12.47 atamazon.com).
Once you have the thermometer, "put it in overnight and check it immediately in the morning, the first time you open the fridge," Ms. Reek said, because the temperature varies during the day as the door opens and closes.
The problem might be where you're storing fruits and vegetables, which are sensitive to cold air. Leafy vegetables are especially prone to freezing, Ms. Reek said, because of their high water content.
Although some newer refrigerators have separate cooling mechanisms for the main body and the freezer, most refrigerators cool by funneling air from the freezer into an opening near the top rear of the main compartment.
Fruits and vegetables should be kept away from this outlet, Ms. Reek said, or else "you're going to be blowing that very cold air right on the produce."
Both she and Mr. West recommended keeping produce in the crisper drawer, away from the circulating air.
"You don't want the moisture to transpire out of the product and make it limp," which can happen with produce on a shelf, Ms. Reek said.
If the crisper is full and some produce has to sit on a shelf, it's better to keep it at the front of the refrigerator, because cold air falls down along the back wall. Along with the area directly beneath the outlet, Mr. West said, "the back and bottom of the refrigerator tend to be the coldest spots."
Shirley O. Corriher, a biochemist and cookbook writer, suggests shaking off all the surface moisture from produce and sealing it in heavy zip-top freezer bags before putting it in the crisper drawer or on a shelf.
"Oxygen is a major villain, so to speak, in the deterioration of fruits and vegetables," said Mrs. Corriher, the author of "BakeWise: The Hows and Whys of Successful Baking" (Scribner, 2008) and "CookWise: The Secrets of Cooking Revealed" (William Morrow Cookbooks, 1997).
Lettuce leaves, in particular, benefit from being sealed in plastic, she said, and you should roll the bag "until you squeeze all the air out. That lettuce will keep for three weeks. It's just amazing."
Still, Ms. Reek said, "the objective of food is to eat it."
"If it's fresher, it's going to have higher vitamin content and be healthier for you," she said. "So it's really better not to plan to store food for ever and ever."
Feb 16, 2015 | GE Refrigerators
PSC23NSTESS FREEZING VEGTABLES
Side by Side ModelsIf foods, such as fruits and vegetables, in the refrigerator are freezing, it can be caused by several things. First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenheit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air.
  • If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents (Side by Side models only).
  • The fresh food control should be at the normal setting of 5.
Freezer on Top Models
First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • Since the cold air coming into the fresh food section originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid placing delicate items that freeze easily on the back half of this shelf.
  • If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not running long enough to maintain good air circulation. Adjust both controls up one notch.
Nov 01, 2012 | GE CustomStyle PSC23NSTSS Stainless Steel...
My GE Monogram side by side built in refrigerator will not freeze ice or keep food frozen. It stays just under the freezing temperature. The refrigerator portion seems to work. Can anyone help?
its possible that its either short of gas or the little fan motor in frezzer/fridge is not working,but if its only making ice now and then its sounds like a gas shortage
Aug 28, 2012 | GE Monogram ZISS420NRSS 42" Built-In...
Our ge fridge is freezing food all over the lower fresh food compartment and the fan makes noise occasionally. does the fan need to be replaced?
the freezing on the lower fresh food area is some times caused by the freezer cold coil freezing up also caused fan noise .( that is where the fan is located . ) the heaters and tefroat terminator need too be ck and repalced if bad ..mm hope this helpt mm feed back pls ..
Nov 08, 2010 | GE Refrigerators
Temperature regulation not working (max only), water dispenser not working and ice maker not working although dispenser works
The symtoms sound all to common on GE units. Based on your symtoms I suspect the fresh food area is to cold. The damper assy is controled by the motherboard / thermistors. This damper assy adjusts to control the air movement from the freezer. During its cycling it can snap loose when this happens the air from the freezer is uncontroled. Within a few days the fresh food compartment temps can drop below freezing. The drop in temp also can freeze the water reservoir behind the lower crispers and in some cases the water filter. Altho You may have other issue (i.e. filter, bad fill valve assy, motherboard) the above statement happens 70% of the time. Fresh food damper assy part# WR49X10091 est $135.00.
Ric
Mar 09, 2010 | GE GSS25LGM Side by Side Refrigerator
We have a ge side by side and the refrigerator is freesing stuff. the model number is GSS25X SNA BS
Is it all areas of the fresh food side that are freezing your items, or is it the drawer area?
There is a direct connection (on my GE side-by-side, at least) between the freezer compartment and the drawers in the fresh food compartment. The size of the connection is controlled with a wheel or a slider. This could contribute to freezing in that area of the fresh food compartment.
Otherwise, it could be the temp sensor(s) in the fresh food compartment. If the computer thinks the temp is too high in the fresh food compartment, it will continue to cool.
It could be a problem with the motorized door that connects the freezer compartment to the fresh food compartment, located at the top of the dividing wall between the compartment. That door should close when the temp in the fresh food compartment is cold enough. If that door mechanism has failed, is disconnected, or otherwise blocked in the open position, cold air from the freezer compartment will continue to circulate into the fresh food compartment.
Jul 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Can the fresh food drawers be disassembled?
yes they can be disassembled but it should not be special temperature drawer or zone which can be independetly controled otherwise you can change the temperature deviation in the compartment which can lead colder temp or below freezing .not good for the fresh food.
Jul 01, 2009 | GE Profile Arctica 25.4 Cubic Feet...
GE refrig Model # GSS25WGMD WW freezer is cool, compressor is running, but food is thawing out, ice has melted...not sure if I left door open ovenight, should I call repair..show long does it take to...
I pulled the refrig out from the wall, turned it off, took off the back panel (that covers the compressor fan and motor) and used the attachment on my vacuum to remove the dust from the area. Then I closed the flapper that allows the ice to release from the ice maker compartment to the dispenser, so no warm air would get into the freezer area. I plugged the refrigerator back in and within an hour it was freezing again! So far this week, I have had to repair the garbage disposal and the refrigerator.....I saved some nice $$$ by figuring this out by myself!
Jun 25, 2009 | GE Refrigerators
Refrigerator freezes fresh food section and always runs
Please read it appears that there are two defrost timers for your refrigerator one for the freezer one for the refrigerator
http://www.partselect.com/PartDetail.aspx?Inventory=310858&SourceCode=4#RepairStory
May 02, 2009 | GE Refrigerators
Crisper produce freezing
are they long times between door openings of the doors, this can cause cold air to migrate to the bottom of the fresh foor area and freeze produce
if this is not the issue, then turn down the fresh food control to a lower number monitor for 24 hrs
if this does not help replace the fresh food thermastat
May 20, 2008 | Kenmore 71812 / 71814 / 71819 Bottom...
GE GSH22JFR Side by Side Refrigerator Logo
168 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
