Question about Brother MFC-7340 All-In-One Laser Printer
Two side print mfc-7340
2 side printing not working properly. Supposed to print even # pages first, then odd, but it prints odd first, then prints even, and it prints wrong order. For 6 pages, it prints 1 & 6, 2 &5, 3 & 4
    New Friend:
I am unable to change the language from Turkish to English
Posted on Nov 29, 2012
Mix-it-up
  • 832 Answers
SOURCE: Can the 420CN print double sided pages
There is only a manual double sided printing avaiable:
After the first side was printed you have to turn the page into the papertray again.
Canon bubble jet printers can do double side printing but the back side black print will be mingled through C/Y/M ink!
Posted on Jan 08, 2008
SOURCE: Brother MFC 7840 W printing blank pages no text or images
Had the same thing happen. Unplugged the power on the printer and plugged it back in. No problems now.
Posted on Feb 07, 2010
  • 39 Answers
SOURCE: Just bought a Brother MFC-7340 but there is toner
yes. that is possible. if the machine was jossled around, the toner contained in the drum unit could leak out between the connecting points of the toner and drum unit. May cleaer it self up, or may not.
Posted on Apr 04, 2010
  • 1570 Answers
SOURCE: My MFC 7340 will not
Hi
Please adjust the paper size to envelope size when printing envelopes because it sensor and setting is only for A4 size paper. Go to printer icon, right click mouse, choose printing preferences, choose correct paper size setting like envelope.
Also, check the document file you are printing and try to do it again in another document file and maybe the file your are printing causes the problem.
if not, try to set up againn the printer once more.
Please let me know if you need more help.
Posted on Mar 22, 2011
  • 7 Answers
SOURCE: Wrong ink in slot
POWER PURGE!!
Hold down the menu key. While still holding the menu key, unplug the machine and plug it back in. Do not let go of the key until the machine reboots and the screen says "maintenence". Hit the following keys: 7, 6, 4,black start. The machine will then go into "power purge" or deep clean mode for about 5-7 minutes. When complete hit: 99 to get out of maintanence and reboot. Be sure to have extra ink cartidges on hand as it does use up a lot of ink but this process works the best every time when the printer wont print
Posted on May 11, 2011
Reverseprinton hp2540
this unit prints one side of paper only
to get it to print 2 sides when you go print on a document thee will be a section that says print all pages , print this page ,print elected pages
in the print selected section type in the pages you want to print ie 1,3,5,7,9 or even pages 2,4,6,8
or there may be a section that opens up with print all pages, print odd pages ,print even pages
to print both sides select odd pages and when they have printed take the whole of the pages and reverse them in the printer feed and then select even pages and print
the operators manual will explain how to do ti.
Feb 15, 2015 | HP Deskjet 2540 Wireless Color All-in-One...
Drum Life Ends soon - Brother
The problem with this is the design. Each toner cartridge has a microchip on it, that counts the pages you print. The company has determined that you get x amounts of prints. Then you have to replace it, empty or not. This printers do not work the same way as an expensive professional business copier. In an pro style there is a spent toner cartridge that collects all of the wasted toner that is on the drum. On a small business/home style this spent toner goes back into the cartridge. There is no level indicator, even on the inkjet printer. They too, have a chip that says you have x amount of prints/cleaning cycles they can go through. Look up inkjet refill kits or inkjet cartridge programmer.
Mar 31, 2014 | Brother Mfc-7340 All-in-one Laser Printer...
Why the print out is black when using printer MFC 7340
May be printer head or cartridge already broken...i think you should change the printer cartridge..
****If you need any technical help on printer then you can reach at here
Mar 04, 2013 | Brother MFC-7340 All-In-One Laser Printer
How do I print double sided?
first off you need to tell your software (office word, or etc ) that you want to print doulbe sided, it will then open a dialog box where you would pick "print odd pages only" after those print you will take the paper out and reinsert it (opposite side) and then click print again, this time clicking on "print even numbered pages only" now your will have a sequence of pages that are like a book, with page 1 on the front, page 2 on the back, etc, etc.
Mar 20, 2011 | Brother MFC-9420CN All-In-One Laser...
Is it possible to copy double sided pages using brother mfc 7430?
actually, this machine is not design for bouble side printing, but you can manually do that if you want to, just need to open the front manual feed cover to do it.
Feb 09, 2011 | Brother MFC-7340 All-In-One Laser Printer
Double sided printing
Go into "properties" when printing, and it's probably under "finishing", or "page layout" or similar (varies by printer), then look for "duplex", or "print on both sides". I'm not sure if your printer does it automatically, or if it will print the first side and then ask you to refeed the sheet.
*please rate response.
Mar 22, 2009 | Brother MFC-7340 All-In-One Laser Printer
How do i print on both sides of the paper
I still do not know how to print on both sides of the paper. I already paid US $200.00 for the printer do you think I should pay more to get what I though would be a simple problem solved? I don't think so!! That's my solution!!
Nov 06, 2008 | Brother Multi-Function Center MFC-240C...
Double sided printing Pixma MP520
here's how:
1. Set your computer software for double sided printing if you have a printer that is compatible. Double sided printers are generally professional style machines, and most offices, schools and libraries will have them. On a PC, go to the drop down "File" menu and select "Double Sided Printing" under the "Preferences" or "Properties" window and print. If you have a MAC, click "Copies and Pages" under the "File" menu, select "Layout" and then click on "Long-Edged Binding" and print.
2.Print double sided with your standard home printer, again, by setting your PC writing software. When you are ready to print, click on the drop down "File" menu and select "Print." From the "Print" window select "odd pages only," or "even pages only."
3.Set your odd and even pages a bit differently if you are working with MAC writing software. Select "Print" from the drop down "File" menu and click on the arrow to drop the "Copies & Pages" menu. Under the "Copies & Pages" menu, select "Paper Handling" and then click on "Odd Numbered Pages" or "Even Numbered Pages."
4.Select "Odd Pages Only" or "Odd Numbered Pages" and then print as usual. It is a good idea to mark the top of your first page with a pencil so that you know the direction and side of the page your printer prints. Use the mark to determine how to turn your pages and place them back in the printer. Select "Even Pages Only" or "Even Numbered Pages" and print again. $('.Article .Steps .Image').each(function(i,e){ e = $(e); e.find('img').error(function(){ $(this).unbind(); e.remove(); }); });
Sep 16, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Brother MFC-7340 All-In-One Laser Printer Logo
118 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
