Question about Exercise & Fitness
How do i set up the centrios talking pedometer
I lost my manuel and cannot set up the proper distance
3 Suggested Answers
greenspan
  • 1734 Answers
SOURCE: reebok B 2 pedometer
1. Reset pedometer by pressing the reset button.
2. Find a long open place and take 20 steps with the pedometer
closed.
3. Check the number of steps the pedometer counted. It should be
between 19 and 21 steps.
4. If the count was not right, try to move the pedometer forward
(toward your belly button) or back (toward your hip) on your
waist.
5. Repeat this until you get the best count of your steps.
6. Once found, place your pedometer in this spot each day.
Posted on Jul 23, 2009
jyackle5
  • 8197 Answers
SOURCE: my dad gave me a sportline 340 walking advantage
You can get the manual on the link below.
http://www.sportline.com/manuals/340.pdf
Good Luck and please rate 4 thumbs up and please leave a testimonial
Posted on Oct 04, 2010
Lost instruction manual for pedometer I want to reset it
Instructions 1. Press the "Mode" button until you advance to the "Step Count" feature. 2. Hold the "Reset" button for three seconds. A screen will appear asking you if you wish to reset. 3. Press the "Start/Stop" button to select "Yes." 4. Press the "Mode" button to continue and return to the pedometer mode. You have now reset a New Balance sport pedometer.
Oct 06, 2014 | Exercise & Fitness
What batteries do i need for my centrios talking pedometer
I finally found the centrios talking pedometermanual which should provide it with the batteries. You could download it here.
Mar 08, 2013 | Radio Shack Digital Pedometer
I have a new sportline belt clip pedometer. It has 3 buttons: mode,set and r/s. How can the length of stride be entered into it so an accurate mileage reading is possible?
I have an older Sportline pedometer with the same three button arrangement.
My pedometer is set as follows:
First press Mode to get the unit in the Distance mode. Note if the unit is in Kilometers or Miles. (Press and hold Reset for 5 seconds to switch the setting. This will reset the entire pedometer.) Press and hold Set for 2 seconds. The current (or default) step length will appear and flash. Press Set repeatedly until your step length is displayed. It changes by 1" or 1 cm at a time. Then release the Set button. (The pedometer will return to the normal operating mode if you do not press a button for 5 seconds.) When you reach the maximum step length, the unit will advance to the lowest step lenght when you press Set again. Since my step length is actually not a whole number, I rounded down.
A different Sportline step and distance pedometer (the 340) is set slightly differently. To switch from Miles to Kilometers, press and hold Mode when in the Step mode. Then switch to the distance mode and press and hold Set until the step length flashes. Press Reset to advance the current step length by 1" or 2 cm. Then release the button when you have the correct step length displayed. The pedometer will return to the normal mode after 5 seconds with no button presses.
Many Sportline pedometer manuals are available from the company's web site on the product site: http://www.sportline.com . You can look up the model number.
If you add your Sportline pedometer model, I'll be glad to give the specific setting procedure for you.
I hope this helps.
(on her third Sportline pedometer, two had the plastic spring clip fail. They all had similar programming details.)
Aug 18, 2011 | Sportline step and distance Pedometer New...
I have the most simple sportline pedometer. I want to change it from Km to miles...can't figure it out and have lost the instructions.
Hit he Mode Button until you reach the Distance Mode (MIL or KM) will appear on the display. Press and hold the Reset Button (S) until the display changes to the mode you want. Note that performing this step will reset all your readings to zero and return your stride and weight setting to the factory settings.
Manual here: http://www.sportline.com/manuals/303.pdf
Jan 01, 2011 | Sportline Exercise & Fitness
I lost my directions and don't know how to change my stride to a lower number.
Manual is here: http://www.sportline.com/manuals/340.pdf
INPUT YOUR STRIDE LENGTH (Range: 12 inches to 60 inches or 30cm to 150cm) 1. Walk 10 steps. 2. Measure the distance that you've walked either from heel-to-heel or toe-to-toe. 3. Divide by the distance covered to arrive at your Stride Length. 4. Example: measured distance 360 inches, number of steps taken was 10 = 36 inches stride length. Important: Please remember that the length of your stride while walking is different than the length of your stride while running. If you plan to use this pedometer for both types of exercise, you will have to reprogram your stride length when you go from one to the other. 5. Press MODE button to reach the DISTANCE MODE showing MILE or KM. 6. In DISTANCE MODE, press the SET button. The display will show previous stride input in Inches or CM and start to flash. You will now have five seconds to start changing your stride length. If you do not adjust your stride length during these 5 seconds, you will have to start step 3 over again. 7. To change your stride length while the display is flashing, press the RESET button. Each press of the RESET button will increase the input by either 1 inch or 2 cm depending on which mode you are in. If you hold the RESET button, the numbers will increase continuously. Release when the display shows the Stride Length for you. 8. Once you have entered your stride length properly, wait 5 seconds - the display will flash and reset the memory - and the display will return to DISTANCE MODE
Dec 31, 2010 | Sportline 340 Step and Distance Pedometer...
Lost the directions need to know how to set all the buttons
Here see if this helps....
http://www.gaiam.com/product/pedometer+fitness+kit+-+intermediate+level.do
How to use the pedometer:
Take out battery insulator pull tab.
Set the metric / imperial system.
  • Press the S5 (Up/Mode) to enter step mode.
  • Press S3 (Set) and hold button for 3 seconds.
  • Press S5 (Up/Mode) to toggle between metric / imperial.
  • Press S3 (Set) to select.
  • Basic operation buttons:
    Time mode
  • The display shows the current time.
  • Press S6 (Down) to toggle 12/24 hour display format. If 12-hour display format is selected, PM times are indicated with a P.
  • To set time: press and hold S3 (Set) to adjust mode. Hour will flash and display.
  • Press S5 (Up/Mode) of S6 (Down) to adjust the flashing digits. Hold the button for fast scrolling. Press S3 (Set) to confirm and move to minute. Adjust the minute.
  • Press S3 (Set) to confirm, and return back to the time mode.
  • Step mode:
  • Press MODE key to enter step mode.
  • The display shows the steps you have dones.
  • Press and hold S2 (CLE) to reset the step count. All information regarding the step counter/distance/calorie will be erased.
  • Distance mode:
  • Press mode to key enter distance mode. It shows the distance traveled.
  • To set personal stride: press and hold S3 (Set) to adjust mode.
  • Press S5 (Up/Mode) and / or S6 (Down) to adjust the flashing digits. Hold button for fast scrolling. Press S3 (Set) to confirm, and return back to distance mode. Set stride: 30-180CM (12-70 inch).
  • Calorie mode:
  • Press mode key to enter calorie mode.
  • It will show the calories burned.
  • To set personal weight: Press and hold S3 (Set) to adjust mode.
  • Press S5 (Up/Mode) and S6 (Down) to adjust the flashing digits. Hold button for fast scrolling. Press S3 (Set) to confirm, and return back to calorie mode. Set weight: 10-15kg (20-330 lbs.)
  • Measuring your own stride:
  • An individual's stride may vary in length. Input the appropriate length by measuring the distance of 10 steps and dividing by 10 to get your own stride length.
  • How to adjust:
    Motion sensitivity slide switch
  • Attach the unit correctly and walk 100 steps. If the reading is 105 steps or more, slide the Motion sensitivity switch to the left. If the reading is 95 steps or less, slide the motion sensitivity switch to the right.
  • How to wear your pedometer:
  • Your pedometer clips easily and snugly to either side of the hip portion of your pants or shorts. For best results, keep the unit in line with the crease line of your pants.
  • The pedometer must be directly perpendicular to the ground. The pedometer needs to be at a 60 degree angle to the ground. Dragging your feet, walking with sandals or uneven footsteps in a crowded area can affect the accuracy.
  • The pedometer only works when walking, jogging, or walking up/down stairs.
  • How to use the panic alarm:
  • Pull out the panic alarm pin S7 (Panic Alarm) from the unit to trigger the alarm.
  • Press and hold S1 (RES) to stop sound temporarily.
  • Insert the panic alarm pin back into the unit to stop the alarm instantly.
  • Battery replacement:
    Panic alarm and LED Torch battery:
  • Open the battery door by unscrewing the secure screw.
  • Flip out the exhausted battery and replace with two new *CR2016 (3V) batteries. Make sure the polarity is correct. Close battery door and fasten the screws.
  • heatman101
    Oct 02, 2010 | Gaiam Walking Fit Kit Pedometer...
    Sportline Fitness Pedometer 360 Manuals
    you can email sportline and they'll send it to you if it's not already on their website
    Jan 07, 2010 | Sportline Fitness Pedometer 360
    I changed the battery on my Omron pedometer and don't have the instructions to reprogram the step distance.
    pedometersaustralia.com/UserFiles/.../File/HJ720ITE Mtrc Ped Aus.pdf
    Attached is a pdf of the instructions that will explain how to measure and reporgram the step distance.
    Jan 07, 2009 | Omron Hj 720ITC Advanced Pocket Pedometer
    Exercise & Fitness Logo
    377 people viewed this question
    Top Exercise & Fitness Experts
    Electro Med Services...
    Howard
    Howard
    Tom Chichester
    Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
