Question about Lexmark S305 IMPACT LEXS All-In-One InkJet Printer
How do i clean the print head on my lemarkS300-S400 Series printer?
    Sergeant:
  • 241 Answers
-From the printer control panel navigate as follows:
Spanner>Maintenance>OK
-Locate the option "Clean Printhead" or "Deep Clean Printhead" and press OK
-Press OK again
A clean will now be performed and a test page printed.
Hope this helps.
Posted on Nov 30, 2012
The printer don work and it shows has no ink,but das have ink
This issues looking printer head problem. check the following Steps for cleaning printer head :
Click on the Start button if you have Windows XP. If you have Windows Vista, click the Windows icon that resides in the lower left corner of your computer screen.
Click on "Control Panel," then "Printers and Other Hardware." Finally click on "View Installed Printers or Fax Printers."
Right-click on the name of your printer and choose "Printing Preferences." This should open a new window; next look for a tab or button marked Maintenance, or something similar.
Find the button that says "Print heads" or "Clean the Print heads" and click on it. You may be asked to choose which print heads; choose them all if you are. Make sure there is paper and ink in your printer, and that it is turned on ahead of time.
Take out the page your printer has printed and see if there are any grids or boxes missing. If there aren't, then you can just exit the program--your print heads are not clogged. If there are grids missing, then click on the "Cleaning" or similarly worded button.
Once the cleaning process has completed, print another page to be sure that your print heads are no longer clogged. If they are still clogged, repeat Steps 1-5 until your printer is printing clearly.
Oct 25, 2010 | Canon S400 InkJet Printer
INK DOES NOT FLOW. HOW TO CLEAN INK AREA.
Here is a few steps to clean the print head of your printer.
1. Make sure the CX5000 Series all-in-one is turned on but not printing, and the ink cartridges are not low or expended.
2. Right-click the printer icon on your taskbar (in the lower right corner of your screen). Select Head Cleaning.
3. Click Start or Next.
Cleaning takes several seconds. The CX5000 Series runs a head cleaning cycle and the On light flashes.
Caution:
Never turn off the CX5000 Series while head cleaning is in progress. You may damage it.
4. When the On light stops flashing, make sure paper is loaded in the CX5000 Series, then do the following:
Windows:
Click Print Nozzle Check Pattern. Then click Print.
5. If there are no gaps or lines, click Finish.
If there are still gaps or lines, or the test patterns are faint, click Clean to clean the print head again.
If you don’t see any improvement after cleaning three times, refer to Problems and Solutions. You can also turn the printer off and wait overnight. This lets any dried ink soften. Then try cleaning the print head again.
Tip:
If you do not use your CX5000 Series often, it is a good idea to print a few pages at least once a month to maintain good print quality.
Cleaning the Print Head
Hope this initial / info idea helps.
Dec 10, 2009 | Epson Stylus CX5000 InkJet Photo Printer
Not printing words on paper
There is always a protective film on the prit nozzles. Remove it. Also from the Printer Manager clean the print head.
Nov 08, 2009 | Canon S400 InkJet Printer
Soon after initiating printing, Canon s400 printer stops with a loud clunk. This produces Error 5100. Turning off and on again does not help.
Hi You can Try
Error Code 5100 This happens lots in caon
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Apr 13, 2009 | Canon S400 InkJet Printer
CANON S400 PRINTING PROBLEM
What printer do you have? Clean heads, clean heads, clean heads, etc. Then do the test print to see if the heads are open. I had similar problem with an Epson, had to clean the heads often, finally got to where the heads wouldn't clean so threw it away and bought another one (HP this time, the heads are included in the ink carts, haven't had to clean the heads at all.)
Nov 02, 2008 | Canon S400 InkJet Printer
Black ink not printing
Jun 06, 2008 | Canon S400 InkJet Printer
I have a Canon S400 series printer and I can't get it to print anything at all. It goes throuh the motions of printing but it doesn't put any thing on the paper but a few small colored lines. Is there a...
FIRST YOU CHECK WEATHER YOUR CARTRIDGES ARE EMPTY OR NOT.IF EMPTY REPLACE IT. IN YOUR PRINTER PROPERTIES DEEP CLEANING OPTIONS IS THERE, BY THIS DEEP CLEANING YOU CAN CLEAN YOUR PRINT HEAD NOZZLES. IF IT IS NOT CLEARED REPLACE YOUR ENTIRE HEAD UNIT.EVERYTIME , USE ONLY GENUINE CANON CARTRIDGES .
May 04, 2008 | Office Equipment & Supplies
Canon s400 doesnt print only blinks eight times
The tank is situated on the RHS.
The Print Head rests there when not in use.
Open the flap to expose the Print Head,slide the Print head across to the left.
On the area where the Print head rests, there is a black plastic square of plastic which contains 2 narrow vertically positioned ink pads.This is also spring loaded.from underneath.
The pad on the left is for BLACK the other Color.
These become saturated with ink during the cleaning process.
I suspect the Print Head has a built in sensor to detect overloaded waste tank.
The pad can be removed this by hooking it out, sideways.
Unless the pads are leaking ink everywhere I wouldn't remove it.
Use Cotton Buds to soak up the excess ink. I used about 15.
Then.....
Turn off printer
Hold down RESUME button and press POWER button.
Keep holding down POWER button and release RESUME button.
Press RESUME button 2 times, then release BOTH buttons.
The GREEN light will flash and stop flashing.
When the GREEN light goes out, press the RESUME button 4 times.
Press the POWER button and the printer should turn OFF
If not press the POWER button once more.
My experience was when turning the printer on at a later date the POWER and RESUME lights still flashed.
All I did was press the RESUME button and the printer operated as normal.
Jan 06, 2008 | Canon S400 InkJet Printer
How do I replace the waste ink pad on my Canon S400 printer?
before you "mess" with the ink pad, try cleaning the print head rail. This is the chrome rod that the print head rides on. Use a little alcohol on a soft rag. After cleaning it, wipe a thin layer of oil (3in1 or sewing machine oil) When you power back up it should go through the rutine of cleaning the head etc.
Nov 28, 2007 | Canon S400 InkJet Printer
Lexmark S305 IMPACT  LEXS All-In-One InkJet Printer Logo
227 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
