Question about Dyson DC16 Root 6 Bagless Handheld Cyclonic Vacuum
DC16 charger output 28VDC Battery 23.6VDC only runs 1-3 sec what is wrong
  • Official Brand Answer
  • 2,572 Answers
Hi Rene,
I am sorry to hear that your DC16 handheld seems to have a short runtime.
This issue is generally the result of the filters needing to be washed or not being seated properly in the machine. If the machine is being used regularly, the filters should be washed monthly otherwise it will impact the performance of the machine.
To inspect the filters follow the steps below:
Remove the canister and separate the nozzle from the main body of the machine by pressing the silver button on the top of the machine.
Remove the pre-filter.
There are two portions to the washable pre-filter a blue sponge and a white scrim that has blue plastic.
In the lower right hand corner of the blue plastic is a small silver disc. Opposite of the small silver disc is a hole that should slip onto a molded plastic post in the main body of the machine.
While holding the handle of the machine in your right hand locate and lift up on the small "lip" on the left-hand side of the main body where the vents are.
The rectangular blue sponge is your post motor filter.
These filters should be washed once a month in cold water (no soap) and left to dry at room temperature for 24 hours or more.
If any gray is visible on any part of the filters they need to be washed.
When replacing the pre-filter into the machine it is important that the blue sponge face away from the motor and the small silver disc on the white portion be positioned in the lower corner of the main body.
If the steps above do not fully resolve the problem, please call us directly at 0800 298 0298 (UK) or 1-866-693-9766 (US).
Best wishes,
Jessica
Posted on Dec 14, 2012
3 Suggested Answers
  • 14 Answers
SOURCE: My Dyson DC16 usually
Your battery is losing voltage too quick. It has probably developed a 'memory'. Dyson claims that their handheld has the best suction out of all the handhelds out there. In order to maintain that claim the circuit board will shut off power to the motor when the voltage drops below adequate charge for full suction.
We need someone who can teach us to bypass that part of the circuit so it won't cut power to the motor or you need to get a new battery.
Shorting the battery like an Aircraft battery then re-charging won't fix it.
Posted on Nov 11, 2011
  • 14 Answers
SOURCE: I bought Dyson DC16 in
I have Dyson dc16 vacuum and it doesn't want to charge. Once I put it on charge the red led is on, but in 30 sec it start flashing. Manual says it means the battery is out of t° range, but it's not.
every possibility is that the battery is out of temp range and that is determined by the current flow from the charger
If the battery is faulty , the charge rate is out of parameters and the charger unit reads that as out of temp range
Take the charger and the battery to an accredited battery shop and have them both checked out
If still under warranty take them both to an accredited service agent for the test and warranty replacement
Apr 03, 2016 | Dyson Vacuums
DC16 what else can be the reason?
We are sorry to hear you are continuing to have difficulty with your DC16. We would appreciate the opportunity to trouble shoot with you over the phone. Please contact our Helpline at 1-866-693-9766 US or 0800 298 0298 UK so we can help.
Best wishes,
Jessica
Feb 29, 2012 | Dyson DC16 Root 6 Bagless Handheld...
UNIT WILL ONLY RUN FOR FEW SECONDS THEN THE BOTTOM OF THE 3 LIGHTS WILL FLASH
I'm sorry to hear you're having difficulties with your DC16. A single flashing red light indicates that the battery needs to be recharged. When fully charged, all 3 LEDs should illuminate without flashing. However, if the red light continues to flash even after at least 3 hours recharging time, there may be a fault with the battery or charger assembly.
Please get in touch with us directly - one of our experts will be happy to run through some troubleshooting over the phone with you to determine whether the battery or the charger requires replacement. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Jul 18, 2011 | Dyson DC16 Root 6 Bagless Handheld...
I bought Dyson DC16 in 2008. Charged full but it only last for 1 minuet. Should I get a new charger? Is Dyson going to send me a new charger?
Jun 09, 2011 | Dyson DC16 Root 6 Bagless Handheld...
My Dyson DC16 usually shuts down after about 5 to 10 seconds. However, occasionally it will run for 45 seconds to 1 minute before shutting down. It is left on charge permanently. I have checked the...
Mar 23, 2011 | Dyson DC16 Root 6 Bagless Handheld...
I have a dyson dc16 and when i pull the trigger all three lights come on but nothing happens from that point?
it needs charging . and if the lights dont light when you put it in the charger somthing is wrong with charger or battery
Oct 23, 2010 | Dyson DC16 Root 6 Bagless Handheld...
My dyson DC16 constantly shuts off even when battery is fully charged. I cleaned the filters to see if that was the problem. It only runs for a few seconds before it shuts off. It will run intermittently...
Hi its Darran at Dyson.
From your description of the problem, it sounds as though there is a problem with the battery.
Your DC16 will have been supplied with a 2 year guarantee. If it still within this period, please contact our Helpline on 0800 298 0298. However if your machine is no longer covered, a replacement battery can be purchased via our website at www.dyson.co.uk/store.
Kind regards
Darran
Dyson Customer Service
Jan 31, 2010 | Dyson DC16 Root 6 Bagless Handheld...
My DC16 will start and then stop. I have to take
My DC16 also had charging problems. I called Dyson and they sent a new charger. The old charger only produced 23.6 volts DC, not the rated 28 volts DC. The new charger has a thicker round wire and produces 28.1 volts DC. Put a volt meter on your charger terminals and see if it is producing enough voltage to fully charge the battery, 28 volt DC. If not you need a new charger.
Dyson DC16 Root 6 Bagless Handheld Cyclonic Vacuum Logo
118 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
