Question about Cell Phones
Cant factory reset and hard reset in my phone
    New Friend:
  • 23 Answers
Your phone make and model please?
Posted on Nov 29, 2012
How do I do a factory reset on a huawei h868c when I cant get into settings
Huawei H868C Tutorials
there no a factory reset, try hard reset with phone on remove battery and install after few minuts
Dec 20, 2014 | Cell Phones
How to factory reset samsung duos GT-E2202 using combination code ? its accidentaly change language and i cant understand it and it put phone lock and i cant recognize.. when i turn on my CP cant use
In order to factory reset you phone, follow the below mentioned steps:
1. Go to dial pad and type *2767*3855#
2. Your Phone Will Be Restarted
Warning: - Performing a hard reset will delete and wipe all of your personal data ( Contacts, Sms , Messages, Notes ). So it's highly recommended to backup your important data and take the SD Card out from phone before performing the hard reset. Take out the SIM card And SD Card before full reset.
GuruAid.com
Dec 12, 2014 | Samsung Cell Phones
How do I hard reset this phone
First remove your sim and SD card if you have one.You lose everything after a hard reset,so back up your contacts to your sim card first if you have them installed on your devices memory only.Also make sure your battery is charged.
Then you will have to enter the factory settings menu by dialing 338464#*# , or if this doesnt work for you dial 277634#*# .
Jan 03, 2014 | LG Vu CU920 Cellular Phone
How to do a factory reset on my motorola blur cause I bought it but the lady did not erase her accounts so the phone is all lock
if the phone is locked you can perform two things one is factory reset for that you have to go to settings and then privacy settings and the factory reset..that will factory reset your phone. and if your phone is completely locked and you cant even get to properties then..you have to perform the hard reset.switch the phone off....then press the power button along with volume up button and press both the buttons for some time. phone will start hard reset again..then in some time it will ask you to press power botton and volume up botton again..and you phone will start hard reset.but it can take some time. :)
Apr 16, 2012 | Android Apps
My lg gw 300 sound is not working i cant so i cant hear if im geting a phone call or listen to music
First ...check if the problem is a software problem by resetting your mobile settings to FACTORY
SETTINGS.
You can Reset your mobile to Factory Reset by typing the code below on your mobile screen:
2945#*# and choose the FACTORY RESET .But before you type the code save your important files or
data,because this code makes a HARD RESET (FORMAT) for the mobile.
After FACTORY RESET ,check if the voice of the mobile speaker came back by try to listen to some
music.If the problem still not solved that means its a HARDWARE problem and the speaker device
in your mobile hardware needs repair or needs to be replaced with a new one.
Jun 13, 2011 | LG GW300 Cell Phone
My phone has had to many pattern attempts and i cant rember the google password or username how can i reset my phone ?
Performing a Normal (Soft) Reset on a LG Optimus GT540 A normal reset is sometimes referred to as a soft reset. A normal reset stops all running applications but does not erase any programs or saved data.
Caution be sure to save any unsaved data before performing a normal reset since a normal reset erases all unsaved data.
To perform a soft reset:
  1. Press lg_optimus_hard_reset1.jpg > lg_optimus_soft_reset.jpg > Settings > Privacy > Factory data reset.
  2. If you are certain that you would like to restore all factory settings, tap Reset phone.
Performing a Hard Reset on a LG Optimus GT540 A full reset is sometimes referred to as a hard reset. Perform a full reset when you want to clear all settings, programs and data from RAM.
Caution if you perform a full reset, your LG Smartphone returns to its default settings and looses all information that is not recorded in ROM.
(CAUTION! If you perform a factory (full) reset, all user applications and user data will be deleted. Please remember to back up any important data before performing a factory reset.)
To perform a factory (hard) reset:
  1. Turn the power off.
  2. Press and hold the following keys for over 5 seconds: Down volume key + lg_optimus_hard_reset1.jpg + lg_optimus_hard_reset2.jpg .
  3. When the power turns on, release these keys.
May 13, 2011 | LG GT540 Cell Phone
Cant send text messages,just saves them to outbox
You should try a hard reset. Doing a hard reset will reset the item to factory settings. Please make sure you backup before performing the hard reset as the phone will be completely wiped. Once the reset has completed, you should be able to send messages. All you must do to reset is:
dial
* # 7730 *
Apr 08, 2011 | Nokia E72 Smartphone
I cant unkock my phone
hi im rain this code will reset your password nd some settings
--------------------------------------soft reset -------------------------------------
Soft Reset will clear pending errors and bring your mobile to an initial state by restoring Factory setting. To operate this function on your mobile, the shortcut is: *#7380#
This function apparently works on almost all nokia mobile phones.
if this fails you can try a hard reset .
---------------------------- Hard reset ---------------------------------------
Enter the code: *#7370# and press Yes to confirm initialization.
Important Notice: It is recommended that you save all important information on your phone
Nov 15, 2009 | Samsung SGH-F250 Cell Phone
Cell Phones Logo
12 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
