Question about Janome Jem Silver 662 Mechanical Sewing Machine
Drop in bobbin on singer 6234 will not thread empty Bobbiin thread winds around underside od bobbin
    New Friend:
In order to wind the bobbin on a 6234 the stitch pattern knob (inner knob) must be on straight stitch. Line up the two dots that are between the zig zag markings on the stitch pattern knob. Next set the outer knob to number 5. Machine will now wind bobbin properly.
Posted on Apr 22, 2014
  • Janome Master
  • 7,365 Answers
Try using a different bobbin and see if that helps, if it doesn't
then the machine may need to be checked to see if there is
something wrong with the hook and the hook race.
Posted on Nov 29, 2012
3 Suggested Answers
GodBlessU
  • 3513 Answers
SOURCE: I can't seem to get the bobbin thread and top
Hi
Raise the presser foot and the needle to their highest positions.
With your left hand, hold the end of the upper thread.
With your right hand, turn the balance wheel toward you (counterclockwise) until the needle moves down and back up again to its highest position.
The upper thread should have caught the lower thread in a loop. Pull the upper thread toward you and the lower thread will come up from the bobbin in a large loop.
Pull out about 15 cm (6") of both threads and place them toward the back of the machine straight behind the presser foot.
The upper thread should pass between the toes of the presser foot.
Please get back to us if you have further query else please accept this particular suggestion.
Thanks for contacting fixya.com
Posted on Aug 25, 2011
  • 22 Answers
SOURCE: Clear bobbin out of thread
Memory Craft has a bobbin winder on top of the machine.  It works beautifully, but wind it on slowly for better sewing function.
Posted on Jan 11, 2009
How to wind bobbin on model 4411
Do you mean the Singer 4411 Heavy Duty sewing machine? If so,
first place the spool on the spool pin with an appropriate sized spool holder, if you are starting the project. Snap the thread into the thread guide to the left of the of the spool pin. Wrap the thread clockwise around the bobbin winder tension discs (slightly to the left and forward of the thread guide). Bring thread towards the bobbin spindle. Thread the bobbin (put the thread through the hole in the bobbin). Place the bobbin on the spindle with the hole up. Move the bobbin spindle to the right. Hold onto the thread above the bobbin and step on the foot control pedal. When the bobbin finishes winding the thread, cut the thread at the top of the bobbin and the incoming thread from the spool. Move the bobbin spindle to the left and remove the bobbin. If you have already threaded the machine for sewing, you will need to remove it from the various guides and tension discs that are used in sewing. Then after winding the bobbin, re-thread the top thread.
The directions to wind the bobbin are in the manual on page 12 (page 19 of the PDF). You can find many Singer manuals at the Singer support page: https://www.singer.com/support . The 4411 support page is https://www.singer.com/search/support?lp=support&title=4411 . The current link to the manual is https://www.singer.com/sites/default/files/product_manual/SINGER%204411%20Heavy%20Duty%20Sewing%20Machine.pdf .
I hope this helps.
Apr 30, 2018 | Sewing Machines
How to thread HD110 heavy duty singer
Here's a link to the manual for the machine. You should find your answer there.
Singer Sewing Machine User Manual ManualsOnline com
Apr 04, 2015 | Singer Sewing Machines
How to thread a bobbin
Which Singer machine do you have? I know how to wind and insert a full bobbin for some models.
Some wind the bobbin with it in the case. This is the case with my Touch & Sew. Inserting a full bobbin is simple. Open the slide plate and drop in the bobbin with the rings up. Make sure that to hold the bobbin thread so that it comes off at the left. Then close the slide plate and make sure that the end of the bobbin thread is coming through the notch. Hold onto the threads and turn the handwheel until the top and bottom thread come back up with a twist. To wind a bobbin for this machine, open the slide plate (some models have a little mark to line up the slide plate). Put in the empty bobbin and thread the top normally. Set the machine to straight stitch and push the bobbin wind button in. (This has a bulls-eye symbol on it.) Wrap the end of the top thread around the presser foot screw several times and hold onto the end. Step on the foot control to start winding. Keep winding until the bobbin is full. The thread wound onto the screw should break. Pull some extra thread and cut it to separate the top and bottom threads. Close the slide plate and set your desired stitch.
Other models are wound at the top of the machine. For some of with a drop-in bobbin, you need to bring the thread down to a catch and then off to the left to another catch. Some have a vertical bobbin. I don't remember if they all have a removable case. Those that do need the thread to come through a notch on the case that pulls the thread under a spring that keeps the bobbin tension. However you should check your manual. If you do not have a manual, check if one is available online. (http://www.singerco.com/accessories/instruction-manuals has many of the Singer manuals for sale or download.)
If you post a comment with the model of your machine, I'll give you a description of threading the bobbin or winding one.
Jan 19, 2012 | Singer Sewing Machines
How do you thread the bobbin on the model 9805c?
To wind a bobbin, reel on top of the machine, take the thread to the left and go around the small wheel, back to the winder, bobbin on the windere and wind the thread round a few times, slacken the stop motion and wind the bobbin.
If you have a drop in bobbin, hold the bobbin in your left hand, thread on the bottom of the spool, drop the spool in, take the thread through the slot to the left and lay it across the bobbin with enough thread to be pulled through by the needle
Aug 05, 2011 | Singer 3343 Mechanical Sewing Machine
Singer Touchtronic 2000 - it will not wind a bobbin, I have found a manual onlin that says you just drop it in and push the foot feed and it will wind the bobbin but it doesn't do anything.
Take your thread that is under the presser foot and wind the thread on the tension disk. It is located right above and to the left of the presser foot. Then you will drop in the bobbin and slide the thread into the **** in the top of the bobbin. Push the little white tab in the bobbin slot all the way to the right until it is in the center of the bobbin. Then press the foot feed and the bobbin should wind.
Oct 24, 2010 | Singer Sewing Machines
I have a singer Model #6234. The bobbin is wound
If the bobbin case is defective this can cause the problem. However, this can be a difficult problem to repair, take it in and ask for an estimate to repair.
Feb 26, 2010 | Sewing Machines
How to thread a bobbin for model # 6234 sewing machine
Try this page for Threading and Bobbin Winding Diagrams for loads of machines.....even if your model is not specified, there's a good chance you will be able to work it out from similar machines.
Sep 07, 2009 | Singer 3116 Simple
Singer 7444 trouble winding bobbin
It sounds like you don't have any tension on the thread when winding the bobbin. Make sure that you are running the thread through the tension disc on the top of the machine before going to the bobbin winder.
Feb 28, 2009 | Singer 3116 Simple
Bobbin filling on Singer 626
The Singer 626 has a self-winding bobbin. You place the empty bobbin in the bobbin thingie (sorry for being so untechnical). On the left of the bobbin you will see a "lever" with a circular top on it (I think it is red-ish) Again, sorry for being so untechnical. Press the "lever" down. Thread your machine, thread the needle, wrap the excess thread from the needle around the knob that tightens the needle and holds it in place and press your foot down on the foot pedal. The bobbin will automatically wind as you hold the foot pedal down. Do not wind the thread onto the bobbin past the outer white line.
Aug 17, 2008 | Sewing Machines
Janome Jem Silver 662 Mechanical Sewing Machine Logo
335 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
