Question about Hitachi 42HDS69 42 in. Plasma Television
My husband moved the tv from one table to another, and now the color is all screwed up. Mostly purple and green. What's the problem? It's an Hitachi 42" plasma tv.
  • 505 Answers
Usually this is caused by unproperly hooked up component video cables. Check the green, blue and red component video cables on the tv and on the device (cablebox) to hopefully solve the issue. Sometimes one just pulls loose also
Posted on Jan 10, 2009
Hitachi 42in tv started to show purple color over whole screen.i could see picture and here the sound ok just a purple color.tried the button on the front for color called magic focus no help.now picture...
there is a problem in display driver circuit, some display problem cause by some capacitor in
power supply are bloated or changed value, the remedy is changing those capacitor
you need some technical skill to do this repair, if you don't have, call for a service technician,
.try to see this video http://www.youtube.com/watch?v=hgcmWO7mqmo
thanks.. hope this help.
Sep 05, 2011 | Televison & Video
Purple and green color
It sounds like a convergence problem to me. I had the same problem with my set and fixed it myself using a kit I bought from www.TvRepairKits.com. These guys rock!
Aug 19, 2009 | Hitachi 61SWX10B 61" Rear Projection...
Color problems??
There doesn't happen to be a speaker nearby does there? I've seen this a lot with center channel surround sound speakers. It goes like this because of the magnet in the speaker. Try moving the speaker if there was one (or anything else near the TV that may have a magnetic field). Then, every time after you turn your tv on it should get slightly better thanks to the built-in degaussing coil in your tv. If not, find a TV/Appliance repair man near you, and he will have what's called a De-gausser and will probably charge around $30 to use it on your tv. You'll be watching 2D TV again in no-time!! ;-)
Jun 05, 2009 | Hitachi 43FDX01B TV
Moved tv to clean table and now all color is purple
try thumping the bottom or back cover sounds like a dry joint or bad conection good luck farr64
Apr 30, 2009 | Televison & Video
My color is off real green you do not see colors like purple and i see blue spots tv hitachi model 61swx10b v1k004865
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section.
Try to adjust the convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Its a fairly easy fix on the Hitachi sets.
You can get a repair kit that includes all the parts from www.TvRepairKits.com. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself.
Aug 20, 2008 | Philips Magnavox 51MP392H Rear Projection...
Color off on TV
fluids need to be change
Apr 05, 2008 | Televison & Video
HITACHI 42 INCH HD
Convergence Amp IC issue....originals are STK392-110..replace
W / upgrade Stk394-160E Hitachi part # CZ 01341 and check nearby resistors for overheating............................T.
Jan 07, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Crt's
The quality of the color diminishes = greens aren't green,etc.
or one color may dominate = pix is mostly green.
or one or more colors are weak = pix is purple = no green.
As you see, it would be best for you to tell me what you observe
the tv doing or not doing......T.
Nov 03, 2007 | Panasonic PT-51G44 51" Rear Projection...
Color convergence?
Can anyone give me the resistor values for location RK 42, RK 46 and RK 62? Hitachi 46F500 TV. Or can I be pointed to the location of a service manual?
Tony
Sep 13, 2007 | Hitachi 46F500 46" Rear Projection...
Hitachi 42HDS69 42 in. Plasma Television Logo
151 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
