Question about LG DLE2050 Dryer
My LG electric dryer wont turn on the control lights wont even light up but the one in the drum does. Help!!!
  • 1462 Answers
SOURCE: The Drum on my LG DLE2512W Dryer will not turn
no problem with motor or control board. fault is with the motor capacitor only. this is often attached to the motor or near it. the value of the capacitor will be printed on it (usually about 8uf) and you should be able to source from an electrical spares shop
Posted on May 23, 2007
  • 582 Answers
SOURCE: dryer drys drum turns , but it makes this banging
THERE ARE TWO ROLLERS ON THE FRONT OF THE DRYER THAT KEEP THE DRUM IN PLACE, IT SOUNDS TO ME LIKE ONE OF THE ROLLERS IS GOING BAD OR HAS A FLAT SPOT IF THE BANG SOUND IS CONSTANT AND STEADY THIS IS THE PROBLEM. EASY FIX YOU CAN ORDER THE ROLLERS ONLINE
Posted on Aug 10, 2009
cherylogle
SOURCE: lg tromm dryer electric cooling light staying on
I called LG after seeing this light as well and they say it's supposed to stay on and should "blink" at the end of the cycle. I've never remembered this light staying on in all the years of owning this machine but she (LG rep) said it was normal. Otherwise, if you've checked everything and it's not drying clothes, you may need to have your dryer serviced. :(
Posted on Dec 14, 2009
marka19
  • 1430 Answers
SOURCE: LG DLE5977W electric dryer hums when attempting to restart
This is usually the motor but not always. Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers, pulley, rear bearing, then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor. You can also enter your model # for diagrams and illustrations at www.appliancehelponline.com
Posted on Mar 31, 2010
pjhislay1
  • 822 Answers
SOURCE: I have a LG DLE2301R dryer that has no power to
mite be the capacitor (or starter.).........
little silver can with 4 wires connected,...........
cheers
Posted on Mar 22, 2011
Lg dryer dlg5966w wont heat, smells like gas in the drum
I have same problem. I have tried everything. Even new control board. It only intermitantly does this. When it fails to light it pumps raw gas. Only thing to try next is new ignitor.....
Jul 17, 2012 | LG D5966 Gas Dryer
Lg DLE3777W wont start
if the motor is running and the drum is not spinning check the belt that wraps around the drum and motor. may have broke or just slipped off
Jun 21, 2012 | LG DLE2512W Electric Dryer
LG DLG0452W: Light inside the drum stays on even after closing the door tightly and dryer does not start. It flashes to check the lint tray but there isn't anything in there. HELP!!
If that light stays on I would say something definitely is wrong with the door safety lock mechanism. I have an LG dryer service manual that may help you: LG GAS& ELECTRIC DRYER repair manual
Jan 10, 2011 | LG DLG0452W Gas Dryer
My LG DLE5977W's drum will not turn, and makes hmmmm when I hit the start button. I can turn the drum manually; power is good as it lights up; lint is cleaned out also;
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jan 02, 2011 | LG DLE5977 Stainless Steel Electric Dryer
Dryer lights up and makes noise but wont turn drum. tells me check filter. where is filter located. I have had the rear of the machine vacummed out and it still doesnt work
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 07, 2010 | LG DLG3788W Gas Dryer
The WHIRLPOOL TEDS840PQ0 dryer wont turn on. The
Check the house electrical panel dryer circuit breaker pair--push off, then on. Try the dryer again. If still nothing, measure the voltage across the two slanted slots in the dryer power socket. It should measure: ~230 volts AC. If at or near zero, either one of the breaker pair is defective, or a wire is open from the breaker to the socket. If you read ~230 volts, then the problem is within the dryer--motor runs, but drum doesn't turn (broken belt), or motor doesn't run (bad controller, motor, door switch, start switch. Does the unit get hot? Need more help on your end.
Oct 18, 2009 | Estate TEDS840JQ Electric Dryer
Dryer has power but drum want turn
check to make sure that nothing is stuck in the blower wheel if nothing is caught then you need a new motor
Dec 19, 2008 | LG DLE2532W Electric Dryer
LG DLE2050 Dryer Logo
60 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
