Question about Spherex Xbox 5.1 Surround Sound System Computer Speakers
My xbox 5.1 SPHEREX SURROUND SOUND SYSTEM DOES NOT WORK NO POWER
I,ve checked the fuse and it is fine
  • Anonymous Jan 17, 2009
    i had the same problem,and the shop i bought it from tried to fix but gave up and paid me back my purchase money.
  • 34 Answers
My bfs did this same thing he went to radio shack found the fuses replaced them and boom works great its been workin over a yr in half now no problems
Posted on Apr 28, 2009
  • VBtoons
    VBtoons Nov 05, 2013
    Aloha Neen39, I know this is an old thread but mine has been working since 2008 until now.. any chance you guys know the location of the diode that wend out? Thanks
Unit does not have power
check the fuses in the fuse box there may be a blown one, Look in your owner's manual or the display on the fuse panel. good luck
Apr 07, 2013 | Spherex Xbox 5.1 Surround Sound System...
Speakers have hiss and crackle but no sound coming through optical feed on spherex xbox 5.1 surround system
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Feb 27, 2011 | Spherex Xbox 5.1 Surround Sound System...
Is the spherex xbox 5.1 surround sound system compatable with the xbox 360, if so how would I set it up because It's not working the way I'm doing it.
yes my bf has if u have a newer tv u just plug in to the digital audio output or u can plug it right into ur xbox ull need the adapter that comes with it
Mar 05, 2009 | Spherex Xbox 5.1 Surround Sound System...
Spherex Xbox 5.1 Surround suound..USB does not work
If the xbox is not able to recognise the usb, it is most likely that the product is not compatible with the xbox i would look for an adapter which would take the usb connection to the xbox's analog connection, or if your speakers have a stero 2.5 connection then you can easily find an adapter to connect to the xbox's analog connection in the back, the analog connection is the red and white ports at the back!.
Feb 11, 2009 | Spherex Xbox 5.1 Surround Sound System...
Xbox 5.1 surround sound not working. not coming on at all
so no power at all ?? then u might want to check the fuse in the back and are cheap my bf had this problem bought fuses and works like a charm for over a yr in a half
Dec 28, 2008 | Spherex Xbox 5.1 Surround Sound System...
My shperex xbox 5.1 doesn't work for the right speakers
Unless your using the Optical and Coxal input you wont get 5.1 surround sound.
Mar 06, 2008 | Spherex Xbox 5.1 Surround Sound System...
Freezes, no sound, won't turn on!
Hi Joeker, I believe you have a problem with heat. Also to get this problem solved, you need to open the main box and clean it up real good. I use a paint brush to dust off the circuit boards. Clean all the dust and lint out of the box. Put it allback together and make sure the main box has plenty of ventilation. do not set it on carpet, this will restrict it's natural circulation of air. I truly hope this helps you.
Oct 09, 2007 | Spherex Xbox 5.1 Surround Sound System...
Rear speaker buzz!!!!!!!!!!!!!!!
i had the exact same problem which eventually spread to all speakers i took it to local repair guy, he was able to resolder the power board seem to fix all didn't really cost me much cheaper thean shipping back to spherex or whoever
Sep 30, 2007 | Spherex Xbox 5.1 Surround Sound System...
Spherex surround sound wont stay on
Mr. Vargas is right mine also won't turn on and upon further inspection I found burn discoloration on the boad where the two power cables are connected. The burn spot is where the four diodes are locaed and the big power cable connection. I am not sure how to replace these diodes or where to find them. Never done this stuff but will try for sure. Please post if you have any suggestions. thanks
Aug 23, 2007 | Spherex Xbox 5.1 Surround Sound System...
Spherex Xbox 5.1 Surround Sound System Computer Speakers Logo
811 people viewed this question
Top Spherex Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Spherex Audio Player and Recorder Expert? Answer questions, earn points and help others
