Question about Logitech Cordless Desktop MX3200 Laser Keyboard Mouse
Wireless keyboard problem
Cannot use keys on keyboard to enter addresses or searches. Cannot enter password on my user log on.Computer has two users. User without password also has no reaction to key entries.For instance when clicking on Google search bar,I get the intermittend flashing vertical bar inside the search bar, but when I start typing nothing registers on screen. Also when using mouse cursor to click on a spot in the browser address bar, every thing is normal untill I press delete in order to be able to enter a new address. Nothing happens. My keyboard connector appears to be normal. I installed new batteries also in mouse. I tried many times to reset the connection by depressing the connection buttons on both mouse and keyboard. The mouse green LED light is on. Any suggestion on what to try will be very much appreciated. THX Andy.
  • 10 more comments
  • Anonymous Dec 07, 2007
    keyboard was working at one time and then it ask for security and i entered it correct and now the keyboard is not working at all. batteries are new and i have the mouse working but not the keyboard.
  • Anonymous Jan 01, 2008
    New installed MX 3200, Mouse will function but keyboard will not type. Tried everything, uninstall, re-install, all properies cheked etc. Light functions on mouse but nothing on keyboard. Drop down panel says the keyboard is connected and working.
  • funtimes Jan 03, 2008
    I have a similar problem. My mouse works fine but my keyboard wont let me type. I cant even login to my computer. The only button on the keyboard that actually works is the "sleep/standy" I've checked the connection, and the batteries, and tried resetting the reciever. But there isn't much I can do with out logining into my computer. Any ideas?
  • DiamondDig Jan 14, 2008
    Having the same problem as described above. I was replacing an MX3000 keyboard that my kids filled with orangejuice and it seems to hook up fine to the transmitter but only the sleep button seems to work on the MX3200.
  • Anonymous Jan 25, 2008
    i know how fix that problem!
    download software from logitech "http://www.logitech.com/pub/techsupport/mouse/setpoint400br.exe" then install, then press left ctrl + alt + f12 , and you see Miracle, type that code and you board will work :)
    nTaxa
  • Anonymous Jan 26, 2008
    I have the same problem, my wireless mouse works fine. The keyboard appears to be connected (because the sleep button works fine), however I am unable to type. I downladed the software from logitech and typed Lft Ctrl + Alt + F12 and it did not crrect the problem I am experiencing. I am oprn to any additional suggestions. Thanks!
  • doctordave Feb 12, 2008
    the mouse works; the keyboard chirps when the sync button is pushed, the mini-transciever blinks, the keyboard shows working in dev mgr- but the keyboard produces no text- no response to any of the keys. I have tested 2 units on 2 different PCs, with existint wired ps/2 keyboards and mice connected
  • Anonymous Jul 06, 2008
  • Anonymous Sep 24, 2008
    i am having the same issue, except mine is on a mac... lovely i know.
    i tried putting the USB key in a PC and running the logitech software. works fine now :D
  • kmnky401 Oct 06, 2008
    I cannot set the clock again
  • Anonymous Nov 16, 2008
    me 2
  • Anonymous Dec 02, 2008
    keyboard not workjng
Just called Logitech support (who were more than helpful, very friendly, and picked up the phone within 5 minutes).
I have an MX3000 laser combo set and the receiver lost connection to the mouse last week. Then the keyboard went out a few nights ago. I had tried what everyone else here had tried to no avail.
So I decided to give a tech support line the benefit of the doubt and call one...
I'm very glad I did!
Here is the entire process for the Left Ctrl + Left Alt + F12 keys. First, when you hit these keys together, a box should pop up on screen to prompt you to reset the encryption sequence. That is what these keys are for. If nothing pops up on your screen (as was my case!), wait a few minutes for the button sequenece to time out, then hit these keys again. Make sure its L-Ctrl + L-Alt + F12 only. Within 2 seconds after that button combo, hit connect on the receiver. Within 2 seconds of that hit connect on the underside of the keyboard. Within 2 seconds of that, hit your Escape key on the keyboard. Sounds completely ridiculous, but this is the direction Logitech support drove me in. And it worked for me. And this is after I tried everything imaginable for over the past week.
We then moved on to the mouse, which i thought we had fixed. But now i have one working and one not working, so I think I need to re-run through this whole process to fix the second mouse. Basically, I now have 1 mouse that works on both receivers, on 2 different pc's with 2 different keyboards in two different rooms (both sets are MX3000 however).
The other now seems to have lost the signal. Will update if I get that second mouse to play nicely with me.
Hope this helps anyone about to trash a perfectly good unit like I was!
Posted on Sep 26, 2008
I know how fix that problem!
nTaxa
Posted on Jan 25, 2008
Solution #3 works for me. Thanks, hutty44!
1. Go to My Computer -> Manage -> Device Manager
2. Under Human Interface Devices, there is a yellow mark beside USB Human Interface Device
3. Right click -> select Update Driver...
4. Select Advance -> ... I will choose driver to install
5. Select "USB Human Interface Device", Next
6. Finally, press Left Ctrl + Left Alt + F12
7. Type the code
Posted on Nov 15, 2008
1) Boot Windows (even if you are using Linux or XXX).
2) Install Logitech drivers from CD (even if system was usable whithout them before).
3) Ctrl(left)-Alt(left)-F12 and they type what they ask you to type.
4) Use that keyboard under Linux/OSX/Wndows, but try to get a replacement for that CRUPy HW as soon as possible, so that you never have to do that stupid thing again.
Posted on Mar 25, 2008
  • 4 Answers
I had the same Problem this is how i fixed it: Start right click my computer, properties device manager, keyboard and mouse had yellow marks beside them, right click on the keyboard then reinstall drivers. If you still have the disk insert it, allow the computer to search the disc by clicking yes this time only: and then select the advance setting on next page, then click allow me to locate drivers myself. there may be more than one to install. just go through them till you find the one that works for your keyboard. this isn't the best description but i hope that it helps you out.
Posted on Mar 15, 2008
    Problem Solver:
  • 8 Answers
Does your key board work in other applications? For example in word processor. Do you encounter this problem continually or does it occur occasionally?. There could be many reasons for this problem. if its possible let me know what is the OS. and software you use to browse the internet and the keyboard make and model? Do u remember of installing any new applications or hardware just before this problem started? if so try restoring your PC to an earlier point when everything was OK.
Posted on Jun 07, 2007
SOURCE:
Cannot get on to my e.mail
Find Hidden Email Accounts on a Computer
Trust in a relationship, whether parent-child, between spouses or at work, is sometimes put to the test.
When one party feels that trust has been abused, he might want to ease his doubts.
New technology makes it possible to effectively hide email accounts, but most people do not use or understand this technology.
Check the history on your Web browser for free email sites like mail.yahoo.com, hotmail.com or gmail.com.
Most of the time nontechnical users do not realize how much information is contained in the browser history.
When searching the history, most free email accounts will show up with the various user names that were used to connect to them.
It is easy to differentiate between regular email accounts and new suspicious ones.
Check her regular email accounts.
Most free email accounts have the option to enter a trusted email address to be used in case the user loses her password, or to warn her if that information changes on the account.
Checking for such email is easy and quick.
Do a search on the account for words like "welcome," "yahoo.com" and "gmail.com" to check for communication from free email providers.
Check for instant messaging logs.
All major free email accounts have free instant messaging such as yahoo messenger, msn and gmail talk.
Each of those messaging services have logging options that save the live chats to the hard drive. If you have an instant messaging software installed, check to see if the logging option is turned on.
Check in the software where the log is saved and go to that location.
Installing messaging software usually creates one folder named after each account to store the logs.
Check for virtual machines on the computer.
More technical people might be tempted to install a virtual machine that allows them to have a dedicated operating system to use as their own.
If you have a virtual machine software such as Vmware, Virtualbox or Virtual PC, try to boot any operating systems present and do the same searches done on the main computer.
Install a key logger on the computer to monitor activity taking place during anonymous browsing. Modern browsers have an anonymous browsing mode that does not record anything done while turned on.
It is easy, however, to install a key logger that will record everything the user types on the keyboard.
It will allow you to discover any email accounts accessed during anonymous sessions.
Get Into My Email if I Don't Remember My Password or ID
It is not uncommon for users to forget their user names and passwords, especially when trying to access an email account not often used.
Email providers like Yahoo! and Google are aware that users forget and have implemented a way to identify the user in this situation. In order to use this retrieval method, you must have submitted an alternate email address when you signed up for that email.
Go to the email sign-in page. Notice the option underneath the login fields for users that have trouble signing in; in Yahoo! Mail this option is "I forgot my Yahoo! ID" and in Google Gmail this option is "Can't Access Your Account."
Click this option.
Enter the alternate email address entered when you set up up your email address.
Yahoo! Mail users also need to enter the birth date, country and postal code entered when the email address was set up. Click "Next."
Log in to your alternative email address and click the email provided.
Your email user name is available in the body of the email.
Click the link within that email to reset your email password.
To reset your email password, the provider might require that you answer your security question.
Go back to the email sign-in page and log in using your user name and new password.
Sep 08, 2013 | Computers & Internet
I have forgotten my wi fi password
Hello. If you need WIFI password, access the router user by typing http://www.routerlogin.net or 192.168.1.1 in the address field of your browser and then press Enter.
Enter admin for the router user name and your password (or the default, password).
After logging in. In the main menu on the left, click on Wireless Settings, from there you can check the wireless security Passphrase or Key code.
Hope this helps.
Oct 14, 2011 | NetGear DG834G Router
Need the network key
  1. Type http://192.168.2.1 into your web browser address line to log into the 5461. (If you have changed the default IP address, please enter your own)
  2. Enter your user name and password.
  3. Once logged in, select the Wireless tab.
  4. You can see the wireless security from there or network key
Jul 10, 2011 | U.S. Robotics USRobotics USR5461 Wireless...
I forgot my password can not log on to my wireless network any suggestions?
If you are talking about your router then you can reset the router there will be a button on the back that you push and hold for 5 sec then follow the steps below
To open the set up page of the router of the router , one of your computer should be able to go online through the router.
It could be a wired computer or wireless computer.
If it is a wireless computer then make sure that the computer is connected to your own wireless network.
Do not change any wireless settings on the router using a wireless computer.
OK ! Now you have a computer online through the router and you want to open the set up page of the router.
First step is check the IP address of the computer.
Check the IP address and the Default gateway on the computer.
For Windows XP
START ==> RUN ==> type in cmd in the RUN box==> click OK or Hit ENTER . You will see a black window that is a command prompt . In the black window type in " ipconfig " ==> and Hit ENTER on your key board .
For Windows Vista and Windows 7
click on START ==> type in cmd in the start search box ==> enter ==> you will see the black window. Type in " ipconfig "you will see a lot of information. Try to find out the local area connection IPv4 address .
Note down the Default gateway number.
For MAC OS
Click APPLE icon in the right top corner of the computer. Go to System Preferences ==> go to Network ==> you will find the option Built in Ethernet or Airport whichever is connected. If you go to that you will find the Ip address and router Address.
The default gateway is the IP address of your router.
This IP address of the router will be used to open the set up page of the router
Now you got the IP address of the router.Open the Internet Browser ( Internet Explorer, Firefox, Safari )
In the Address bar of the browser Type the IP address of the router.
Do not type http:// or www just type in the IP address only.
It will ask you for the user name and the password of the router.
This is the User name and the password of the router and NOT the wireless password. On a wireless router, there are 2 passwords. One is to access the router and the other one is for the wireless network.
For most of the routers the default password will be " admin " . for some routers the default password is " password ". For Linksys router the default password is admin and no user name.
Jan 13, 2011 | Computers & Internet
I cant log in. I wanted to change my Email. but now i rather have it the way it was at first.
For Windows XP
For MAC OS
Jan 10, 2011 | Computers & Internet
Another computer locked my router so my kids cant get on the internet on their laptops
Connect your router to any of your laptop/desktop through LAN cable and launch internet explorer. Type the IP address 192.168.2.1 in Address space and press enter. You will be asked to enter user id and password. Generally, user is admin and password may be admin or password. Once you log in, just search for the mac filter option and disable it. You are done now.
Nov 27, 2010 | Linksys Wireless-G WRT54G Router
I want to change password for wifi network
Open up an Internet browser window on your computer system. To gain access to the default settings, type in the default IP address of the wireless router in your Internet browser's address bar and press enter. You must refer to the wireless router's documentation or navigate to the manufacturer's website for the correct IP address.
Type the default user name and password in the security dialog box that appears, then press Enter on your keyboard. Because different router manufacturers use different default user names and passwords, refer back to your router's documentation or support webpage for the correct information.
Navigate through the router administration pages to find the wireless router's administrator password settings. Change the default user name and password to a unique set so that possible unauthorized access to your router settings will not take place. Make sure to hit "Save Settings" to complete the change.
Set up your wireless security settings by navigating to the proper administration settings page. By default, wireless routers do not come with a password for connectivity access. Choose the appropriate wireless security level you need and type in a unique user name and password. Save these new settings and log out of the router's administration setup.
5
Write down the user names and passwords for both network access and the administration setup page. Keep these user names and passwords in a safe place.
Thanks.
Have a great day.
Oct 14, 2010 | Computers & Internet
Hi, im trying to find out the password to my
HI,
If you have any computer hardwired to the router than click on start >> go to run >> type cmd and press enter >> type ipconfig and press enter >> this will show you an ip address, subnet mask and default gateway >> note down youe default gateway >> open an internet explorer and type the default gateway in address bar for example : 192.168.1.1 and press enter >> it will ask you for user name and password >> by default user name should be admin and password should be admin/password. >> after logging in to the router page go to wireless security and check your wireless network key.
If you fail to do this than you might have to reset your router and have to re-configure it again.
May 15, 2010 | Computers & Internet
Wi fi on ipod touch not connecting
First of all check what is the ip address of your router ,,,default is 192.168.1.1,,,but if it does not work click on start>run>type cmd >hit enter,,,in cammand prompt type ipconfig >hit enter,,,you will get default gateway address on the computer which is connected to computer,,,,type this default gateway in address bar of internet explorer not in any search engine,,,,it will ask for user name and password of router default is leave username blank in password type admin,,,if it does not work then there is no way to check wep key ,you need to reset the router to factory default ,,,and if it does,,,go to security under that there is subtab wireless security ,,you will get this wep key in key1 field,,,
Jan 02, 2010 | Linksys Wireless-G WAP54G 802.11g/b...
How do you find your WPA key?
log into the router :
Connect the router to your PC using an eithernet cable
Open internet explorer
put in address 192.168.0.1
User name : admin
Password : password
Go to the wireless security settings
Your WPA key should be displayed if one was set up
Dec 29, 2009 | NetGear WGR614 54Mbps Wireless Router...
Logitech Cordless Desktop MX3200 Laser Keyboard Mouse Logo
5,173 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Damen Wong
Damen Wong
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
