Question about Beko Fridge Water Filter Ap930 Ap930x 4346610101
Ice maker works properly. When ice cup in place, ice drops to door/flap...but does not allow ice to fall. Door does not open. ( Door is not frozen) I can put my finger up and open flap & ice falls into cup. What is part pulls door open??
Why does the flapper valve on the refer door not open to let ice out of the door
check that some melted ice or water has got on the flap and frozen it shut.
Oct 02, 2014 | Refrigerators
Frost builds up on outside of ice maker
The little door that opens and lets the ice fall into Your cup is not closing all the way, allowing cold air to escape from Your Freezer and causing frost to build up. Simply look up at it or open the Freezer door and place a lit flashlight in the ice chute so You can see where the light is shining through the ice dispenser at. There should be a build-up of ice there that is keeping the "trap door" from closing all the way. Clean that off and You should be as good as new.
Aug 19, 2014 | Kenmore Side by Side Refrigerator
LG Freezer ice maker makes ice but wont dispense
There is a mechanical flap (trap door) that should open to allow ice that is being pushed by the auger in the bottom of the bin to fall out. Possibly the solenoid that opens the door does not work, or you just have an obstruction (piece of ice) preventing the door from opening far enough to allow the ice to pass through. Here is some helpful information and instructions.
Mar 19, 2014 | LG LSC23924ST Refrigeration : Refrigerator...
Our subzero freezer has a new problem. The cubes
Ice cubes WILL BE slightly moist when they land in the ice bucket. they've just been slightly melted in order to eject from the ice maker. Stop playing with the settings, for starters. put them back to normal, i.e., middle setting, place thermometer in center of freezer, and if you can, one in center of fresh food. monitor after 24 hours, and for the next three days thereafter. freezer temps should be in the -5 - +5°F, sometimes up to 10°, fresh food should be 35-40, sometimes up to 44°at the normal settings. If you are not having temperature issues, see if you notice any frozen drips of water on the underside of icemaker, indicating a possible crack in the ice maker mold, or a faulty water valve. You didnt include your model and serial number, so not knowing the path of the ice shoot, some go out the freezer door, some slide over and get dispensed from the fresh food side. Its possible you may have a problem instead with the flapping door that opens to allow ice cubes to be dispensed, or similar type mechanism. If this door does not seat completely when its closed, it will leak warm air directly into the ice bucket, which would make them slightly moist, also too, this warm air can cause frost and ice to buildup near the warm air source...look for any unusual forms of ice and or frost leading up from the flapping door to the ice bucket. Also look for any gaps in the door gasket when closed, this warm air leak can also cause similar problems, but its most likely with the ice door. could be the door, the spring, the solenoid, or something else i wouldn't know without personal refrigerator inspection.
Mar 27, 2010 | Freezers
I have a KitchenAid side by side and my icemaker is not working
Check the black 2" fill hose going from the top of the freezer to the ice maker fill cup , to see if it's frozen up . Also check the optics system for proper operation . Open the freezer door and the laser should flash 2 times , pause , flash2 times , pause etc. Close the flap on the left side and the laser should go off . If the laser does not come on when the door is opened , then the ice maker is in the harvest ( dump ) mode . If it stays this way , then ice maker is bad .
Sep 12, 2009 | KitchenAid KSRG25FK Side by Side...
Ice maker not working
Pour about 2/3 cup of water into the ice maker . Also , check the black fill hose that fill the ice maker , to make sure it is not frozen . If the ice maker dumps the cubes , then replace the water inlet valve . If the ice maker holds the ice , and does not dump , replace the ice maker . When you open the freezer door , the laser light , should blink twice , then pause ,repeatedly . If you close the flap on the left side , the laser should go off . These are indication that the optics are good . If you open the door , and no laser light , then that means that the ice maker is in the harvest (dump) mode . If it stays this way , ice maker is bad .
Sep 11, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice Maker frost and freeze where ice drops into refrigerator door
You need a service guy to look at it. It could be water leaking or a simple case that the flap isnt sealing and the ice melts and then freezes the flap open
May 14, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
Whirlpool side by side ice maker
its possible that ice is jamed in the ice crusher compartment this happens to me as well the ice drops down to fast causing it to clog and then stays open until it all of a sudden you pick it up on the floor thanks from gilles
Mar 15, 2009 | Refrigerators
Icemaker - flap won't open, cubes collect in chute
the actuating paddle that you are depressing to dispense ice actually pushes the door open at the top of the dispensor, soundsas if thered an issue withthe actuator arm
Nov 18, 2008 | Frigidaire FRS26R4A Side by Side...
Icemaker flap/door does not mechanically open
The description says you have an LG fridge?  I may need the entire model # from the sticker inside the fridge to tell for sure, but there is a motor behind the dispenser controls that opens the door.  Let me know if you need more help.  Also, you can view parts and diagrams at http://www.appliancepartspros.com/.
Oct 21, 2007 | LG LFX25960ST Stainless Steel French Door...
Beko Fridge Water Filter Ap930 Ap930x 4346610101 Logo
27 people viewed this question
Top Beko Refrigerators Experts
AJMAL KHAN
ray gallant
Are you a Beko Refrigerator Expert? Answer questions, earn points and help others
