Question about Sony CDX-F50M CD Player
No power to faceplate. Fuse and power uo to receiver is good. What else should I check?
No power to faceplate. Checked power to the radio and no problems there. Checked fuse on radio and it is good. What should I check next?
killer_clown
  • 86 Answers
SOURCE: Sony Receiver Won't Power On
Did you have any Rca Cables running to a Tv or anything by accident cuz it could run thru those, Lighting is a powerfull substance, if it hit the house then it could of ran into the cable to the tv an went out, thats wierd this is the 1st time ever hearing this, try looking in side to see any burn markings, an take a wiff cuz you can tell if somthings fried by the smell of it, if it is then its most likly dead
Posted on Oct 20, 2008
godspeed808
  • 125 Answers
SOURCE: sony cdx-gt200 no power
its knackered either send it in for repair or buy another amp at wholesale cost here:
www.godspeedaudioheaven.com
Posted on Feb 04, 2009
  • 323 Answers
SOURCE: I have lost power to my sony cd player in my car
Take the cd player out and run the 12+V to + on 12+V battery.
Run the Ground/Black wire to negative on battery. See if the cd player will turn on. If it does, check your ground in the dash. This is just a good trouble-shooting method to make sure the cd player system board is not fried.
Posted on Feb 09, 2009
SOURCE: my sony sub isnt working, i checked the wires
do you have a power on signal wire hooked up?
Posted on Jun 09, 2009
Ganx
  • 113 Answers
SOURCE: Unit blows the fuse on power up. This happened
Hiya try
http://www.icpowerx.com for the Mosfets, you will probably need to replace driver transistors also (not always but sometimes they go). Also check the resistors to output, they will be the big white ones.
Go here to read on testing FETs
http://www.4qdtec.com/mostest.html
Just to be sure. If one is blown, replace all
Posted on Jul 15, 2009
No sound rom the speakers. removed radio and checked wiring harness and checked the fuse under the hood and they are all ok. what can I check next?
These units are prone to problems... get a good aftermarket one from Crutchfield on-line with the faceplate adapter... it will be easy to install and look factory.
Jun 24, 2015 | 2008 Dodge Avenger
1997 camry no power to radio
fuses that look bad are.
fuses that look good , can be , in FACT bad.
DMM, (flip to low ohms)
fuse reads 0 ohms, its good
fuse reads infinity its bad.
if fuse is good check for 12 at the radio power wire.
the radio must be ground do work, is it?
some radios have a separate ground wire (black) is it grounded?
post new radio make and model and can answer with 100% accuracy.
im a retire ET.
DC to daylight. experances.
Dec 24, 2013 | 1997 Toyota Camry
I have a 2003 ford focus and my radio does not work. I have checked the fuse for it but there is nothing wrong. Anything I can do or check?
Check the detachable portion of the "faceplate" on the radio. It's where the memory buttons are. That sometimes doesn't get a good connection and the radio won't work.
Jun 01, 2011 | 2003 Ford Focus
Kdc-x993 - power to head, but no display when face is installed. the cd eject button is blinking but when i install the face, the display will not come up.
you dont have power to the ignition wire on the radio(red wire) the yellow wire should have constant power(12 volt) check your radio fuse in the fuse block on the car or on the red wire itself
Jan 23, 2010 | Kenwood Car Audio & Video
Pioneer DEH-4100 No power
if you dont have a 12volt power supply, you can test the headunit by connecting your yellow, red, and black wires directly to a car battery. connect the yellow and red wires to the positive terminal and the black wire to the negative terminal. Before doing this make sure the red wire has the small inline resistor supplied by pioneer and the yellow wire has a 10amp fuse.
May 19, 2009 | Pioneer DEH-P4100
No power to Kenwood KDC-4019 faceplate
It sounds like the stereo does not have the "ACC" voltage. It could have blown a fuse. The "ACC" voltage goes to the red wire on the harness and you get that voltage turned on only when the ignition is turned on in the car.
The symptom of the disc ejecting and nothing else works is an indication that only the constant voltage for the yellow wire is connected. Check the voltage on the red wire with the car turned on, if you have that 12 volts at the red wire, then you need the radio serviced.
It is not very likely that the faceplate has gone bad. Just because the radio will not turn on is not an indication that the faceplate is bad. It could be a voltage regulator in the radio or a circuit trace is blown, or almost anything else. There are many reasons that the radio would have the problems you describe and it can only be found out for certain by troubleshooting the radio on a test bench with the proper tools. If you have a multimeter and a power supply I can guide you thru troubleshooting the radio and even email you the service manual in PDF format if you would like to take a crack at it yourself.
Let me know how you want to proceed.
Dave
Oct 25, 2008 | Kenwood KDC-4019 CD Player
It's dead
Make sure all your wires from the radio to the car are connected and check both the fuse on the radio and the one in the car. Is there anything else in the car that turned off?
Jun 06, 2008 | Panasonic CQ-C1100U CD Player
Sony CDX-F50M CD Player Logo
27 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
