Question about Sewing Machines
How do I adjust stitches on my brother xl 3022
The stitches are too small, I would like to know how to adjust them. also thread is bunching up on bottom stitches.
  • Sewing Machines Master
  • 7,365 Answers
Here are 2 links for a manual, you can choose which one you
want, one is a downloadable version the other a hardcopy
http://www.sewingpartsonline.com/instruction-manual-brother-xl-3022-instant-download.aspx
http://www.sewingpartsonline.com/instruction-manual-brother-xl-3022.aspx
Posted on Nov 30, 2012
  • 20 Answers
SOURCE: I have a Singer Sewing Machine 5817C, the thread
Make sure that there is tension on the thread when you have passed it through the tension unit, by making sure the presser foot is down, and then gently pulling the thread to feel tension. If there is no tension, as seems to be the case, check the tension discs inside the unit to make sure that there is no debris stopping them from closing.
Posted on Oct 14, 2009
SewTechWayne
  • 186 Answers
SOURCE: Brother xl-2600I sewing machine thread problem
Try turning the handwheel so the take up lever is at its top position, then remove the garmet.
good luck!
Posted on Jul 30, 2009
kent581
  • 87 Answers
SOURCE: bottom of stitch is bunched with alot of thread and machine jams
Try these time savers:
Test your thread quality to start, thread your machine and LIFT the presser foot (this opens the tension disks). Pull your top thread straight back. If you feel no tension no mater how much thread you pull, your thread is good. If that your machine passes that test, then let me know, we can go to step 2. If not, try different spool of thread, same test until you get a smooth pull (tip: always check your thread this way when you thread your machine)
Step 2:
Pull on your threaded bobbin thread while it’s in the machine. Does it pull smooth and even? If so, go to step 3. If not, try a new bobbin (bobbins get bent or distorted if wound too tight).
Clean thoroughly in the hook and bobbin case area and oil 1-2 drop is all.
Posted on Mar 18, 2009
  • 16 Answers
SOURCE: How do I adjust the bobbin settings on my Brother XL-3022
Well is your machine skipping stitches? "Not looping" does that mean not creating a stitch? To adjust your bottom stitch you usually adjust the top tension regulator. I can try to help you more in detail check out my forums http://www.sewingmachineryrepair.com/forums/index.php
Posted on Feb 28, 2010
  • 1116 Answers
SOURCE: Bobbin thread bunching up.
Thread the machine with the presser foot up and see if this will remedy the problem.
If not, refer to the manual to be sure the threading and bobbin are set up as they should be.
If the bobbin thread and top thread continue to not link together, it could be the timing needs to be adjusted.
In this case, take the machine to a Brother dealer for service along with a sample of the stitching.
Posted on Apr 01, 2010
I don't know how to change needle postion when changing the foot to another one my machine is a brother xl 3022
Here's a manual for your machine:
Brother XL 3010 Operation Manual
It appears that your machine does not have the ability for the user to change the needle position. Instead, it seems that the selection of the specific stitch pattern determines where the needle is positioned, ie #1 appears to set the needle in the left position but other stitch and width selection will move the needle position.
Oct 16, 2017 | Brother Sewing Machines
I'm having a problem threading my brother sewing machine model XL 3010
1. Clean up any loose thread in the bobbin area.
2. Pull on the bobbin thread while it is out. It should give a tension that is equal to the top tension of three. You'll have to approximate. Adjust the screw tension on the bobbin. It is the screw nearest to the thread exit hole on the side.
3. Put it back in.
4. Now, the top tension should be at about three. If it still allows a little wad on the bottom of the fabric you can adjust the top tension by tightening a small amount and monitor each time you adjust. The wad should go away.
Oct 05, 2016 | Brother Sewing Machines
I cannot get the tension right on my 2600 Brother machine. I am stitching in the ditch with three layers of material. Can you please help?
Make sure you have the right size needle...not to small. Then do a simple seam through three layers (doesn't need to be a seam just sewing through 3 layers of scrap) using a wide zig zag stitch. Examine the stitch looking at both sides. Do they look even, identical?
Think in opposites, ie the bottom thread tension affects the stitch on the top side and the thread tension on top affects the stitch on the bottom side. If one side is loopy then the opposite side tension is too loose (or, sometimes that side's tension is too tight). Adjust until both sides are identical looking. Then try stitching in the ditch like you wanted to.
Mar 30, 2011 | Brother XL-2600
Feb 28, 2010 | Brother LS-2125 Mechanical Sewing Machine
Brother MB 2600
You should not have to adjust the bottom tension when using sewing thread.
There is a tiny screw on the side of the bobbin case - left/loose; right/tight.
Mark the screw head slot and edge of the bobbin case with nail polish or sharpie so you know where you started.
If you are having a stitching problem that appears to be loose bobbin thread, it may be that the machine was threaded with the presser foot down.
Always thread a sewing machine with the presser foot up.
When the presser foot is down when threading, the thread cannot enter the tension control and you get loose, loopy stitching.
Feb 24, 2010 | Brother XL-2600I
I have a Brothers XL-3200 which works great but then the bottom thread will bunch up, amass, thread will wind around the bobbin and lock up the machine. It can also break the needle. Can you help me??
Your thread tension needs adjustment.
Most likely it is the lower thread tension (not the upper thread tensioner).
When sewing very thin or very heavy material - it is required to adjust the lower tension as well.
To regulate the lower thread tension - turn the small screw on the tension spring of the bobbin case with a small screwdriver.
To increase tension - turn it clockwise SLIGHTLY.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jul 01, 2009 | Brother XL-3500
Wont sew thread bunches up
Hi!
I think you are threading the top of the machine incorrectly. Make sure that what I'm saying is correct, use two color threads to sew with- and you will see that it is in fact the top thread that is bunching.
This might be a tension problem. Could be the bobbin is not threaded in the case right. First, check the threading of the bobbin and then check the stitch.
Next, adjust the tension on the bobbin case. There is usually a small screw on the case that can be tightened or loosened. I think you may need to adjust it a bit or adjust the top tension knob, just a small bit at a time. It the top does not change the stitch, then go to the bobbin case and adjust the screw to tighten the stitch a little bit more.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 19, 2009 | Kenmore Sewing Machines
Threading and operation
http://www.devicemanuals.com/guide/Sewing%20Machine/Brother/Brother-XL-3022-Sewing-Machine-Owner%27s-Manual-T0RNeE5qUT.html
or i could photocopy pages from my manual and post them too you if that would help. (can't scan as my scanner doesnt work for some reason).
if not than nevermind.
Feb 10, 2009 | Brother LS-1217 Mechanical Sewing Machine
Sewing Machines Logo
178 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
