Question about Hobart Dishwashers
Which way do the dishes face in the tray before sliding them into the dishwasher, or does it matter?
Some people say you must face the dishes forwards, but others say they can be placed facing sideways in the tray. We found that facing the plates sideways lets us spray both the front and back of the plates easier than if the plates were facing forwards.
    Habit-Forming:
  • 36 Answers
If is a door machine, it doesn't matter. If is a conveyor Machine face the dishes on the direction of advance.
Posted on Nov 28, 2013
  • 423 Answers
SOURCE: dirt left on dishes on top tray; bottom tray washes fine
The broken bottom arm is probably preventing any water / water under pressure to get to the upper arm.
After you replace the lower arm, you should have much better cleaning in the top shelf.
While you are in there replacing the lower arm, recommend you remove the filter under it and clean the filter and any debris you find. Be careful of broken glass!
Good Luck!
Posted on Apr 04, 2009
  • 423 Answers
SOURCE: Whirpool dishwasher, top tray spray unit does not spin
When the spray arm does not spin and even the powder does get mixed in, your probably have a failing pump/motor.
Before you call for service, try the following. Remove the lower spray arm and filter beneath the spray arm (and as always, check for plugged spray holes and for any broken parts.) Screws will need to be removed to to this.
Rinse everything in the filter, removing anything that does not belong.
With a flash light, inspect the whole sump area, looking for anything that may be blocking water flow. Watch out for broken glass down there!
Look closely at the impeller, looking for damage and that it spins freely and is securely attached.
While you are looking down there, inspect the heating element for damage/being broken/bumpy when it should be smooth.
Reassemble and run a load of those gathering dirty dishes!
The detergent ~should~ dissolve and clean effectively. BUT, if you have recently bought a cheaper, generic dishwasher powder, buy yourself a name brand powder like Electrosol or Cascade and only use it. The cheaper stuff is junk and will rarely clean even in perfectly operating DWs.
If all this does not work, then the pump motor most often the problem and needs to be replaced. When it is being worked on, make sure the heating element is checked. If I were replacing the pump motor, I would also replace heating element at the same time.
SOURCE: stainless steel face plate/front cover for a black dishwasher
Here you go, there is a company that makes them
http://www.kitchensource.com/kau/frigodw.htm
Posted on Apr 24, 2009
  • 9 Answers
SOURCE: dishwasher lower spray arm falls off
These parts can be replaced easily and reasosnably cheaply for example the top spray arm is about £20.00p. But you need the back water feed tube as well as the lower spray arm which should come as one package. (depending on model i'm going by bosch). You shouldn't have to pay more than £30.00p + p&p. Hope this helps.
Posted on May 19, 2009
  • 297 Answers
SOURCE: stinky brand new LG dishwasher
most likeky its just the food.
Posted on Aug 04, 2009
How to organize dishes in dishwasher
Facing dishwasher, Back row dishes face left. Front row dishes face right. Do not put anything in the middle space between the 2 rows or on the edges.
Nov 24, 2014 | Frigidaire Dishwashers
The lg dishwasher doesn't use all of the detergent and the dishes are not 100% clean
first check the water supply if good water pressure.then check the pump under the bottom dish tray remove parts check for debree.
Jan 25, 2013 | Dishwashers
There are no error codes showing, water is definately getting hot but dishes on bottom tray not cleaning, i have used few products specially designed to clean the dishwasher itself without any dishes in,...
Check that the arms spin freely when spun by hand, then check the outlet jets at the trailing end of the arms are not blocked with food particles and other solid matter. This often happens and the arm is unable to turn because the water jet that is supposed to drive the arm does not have the force to rotate it with the result is that the upper dishes do not get enough water and chemicals. .
Jun 18, 2011 | Baumatic 23 in. BDW13 Built-in Dishwasher
The upper spray nozel no longer spins. There is water going in but for some reason it no longer turns leaving the uper tray of dishes dirty.
Check that the arm outlet jets at the trailing end of the arms are not blocked with food particles and other solid matter. This often happens and the arm is unable to turn because the water jet that is supposed to drive the arm does not have the force to rotate it.
Feb 05, 2011 | Danby DDW2406 Stainless Steel Built-in...
Dish feels hot but not drying
sounds like your heating element is not working prtoperly or you are not washing in very hot water stop washer in middle of cycle and open it if steam come out hot steam be careful keep face away when you open itif not hot that could be the problem,A appliance serviceman once told me if water is hot enough and end of wash and rinse cycle not to run the dry cyvcle just open dryer a few inches and let the steam out Run hot water over a plate or a pot and set it in the drain tray in your sink notice how fast it dries itself while draining in the tray very hot water in a dish washer dopes the same good luck with this problem I hope my advice helps you oh yes one more thing always run the hot water till it get hot before you turn your dishwasher on
Dec 15, 2009 | Kenmore Dishwashers
Kitchenaid Dish Drawer unit is canted forward; I need to get to the back legs to adjust them downward. How do I get to them?
Open the dishwasher door and undo the two screws that secure the face to the counter-top. Open the kickplate and slide the diswasher out of it's hole. You should be able to easily access the back legs now. It may be easier to disconnect the drain and supply hoses (turn off the angle stop first) and flip the dishwasher upside down using a carpenter's level to make sure all your feet line up. Flip it over, reconnect, and reinstall.
Jul 01, 2009 | KitchenAid Dishwashers
The dishwasher is not dring the dishes
How old is this unit? Are you removing the dishes at the end of the cycle or leaving them? Are you filling the rinse aid dispenser? The new dishwasher will not dry properly without rinse aid. Dishes have to be removed at the end of the cycle because a dishwasher is a moist environment moisture will reform on the dishes if left with door closed. A dishwasher does not have a fan to move the moist.
Jan 25, 2009 | Frigidaire 24 in. FDB635RF Built-in...
It is leaving soapy taste on dishes
you are using way to much detergent. and it is probably a stainless steel dishwasher. you should run a cup of vinegar on the top rack face up with nothing else in the dishwasher and no more detergent. run the vinegar in the dishwasher 3 times and then only cover the detergent tray a third of the way when washing the dishes.. do not put any detergent in the prewash slot.
Dec 24, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
Asko D1706
I also had this problem. Support person couldn't tell me if the pump was supposed to run even when setting the control knob to 'off' (bar before (1)). After draining the pan, the control knob functioned normally. So apparently any power to the unit will run the pump when the overflow pan is filled, no matter the position of the knob.
Sep 10, 2008 | Asko D1706 Built-in Dishwasher
Dishwashers Logo
78 people viewed this question
Top Hobart Dishwashers Experts
Jason
handygirl911
handygirl911
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
