Question about Canon Office Equipment & Supplies
How to get a fax confirmation on a canon faxphone L190
How do you get a fax confirmation on a canon phonefax L190
There should be a button on the front of the fax 'Reports'. Push that. Then go to 'Report settings'. Select that option. For confirmation reports that a fax was sent 'TX Result Report'. Turn this 'On'. You should be set. We just figured this out on our faxphone.
Posted on Aug 07, 2013
SOURCE: Canon FAXPHONE L80 confirmation
First print out your user data.
Press Function, then Report, then arrow down to User Data List and press Set. This gives you a printout of your present menu set.
Now press Function, press Data Registration, press Set. Arrow down to Report settings, press Set.
Select TX Report, select yes.
You can also select that the first page of the document sent shows up on the confirmation report.
Posted on Feb 23, 2008
Chintu-KPV
  • 202 Answers
SOURCE: Can not transmit faxes
Mostly this happens when the firmware of the machine is corrupted
Try reflashing it through a nearby service centre
Also check the document feeder
Please do check the settings whether it shows receive only mode!
I hope this helps u, ..... advance sorry otherwise
Posted on Feb 26, 2008
checkitright
  • 1362 Answers
SOURCE: I have a Canon Faxphone
check the TX section
http://www.retrevo.com/support/Canon-L170-Multifunction-Printers-manual/id/1304dj679/t/2/
Posted on Aug 19, 2008
SOURCE: How do I reprint an incoming fax received 1 0r 2 days ago from a CANON FAXPHONE L80? I am not sure which fax it is (I have the Activity Reports), so is there a way to reprint a specific fax? Or just
There is no way to reprint a fax once it's received. The report is all you can get.
Posted on May 13, 2009
  • 1126 Answers
SOURCE: How do I get a confirmation page of a sent fax on Canon SuperG3?
Tx (confirmation) Report needs to be enabled before sending the fax. Super G3 is an industry standard, not a model number. What model of Canon facsimile do you have? I have most User Guides downloaded...so I should be able to provide directions on enabling Tx Report. Let me know.
Posted on Aug 17, 2009
How do I get out of download mode?
Try power it down, unplug it, wait at least 30s and reconnect it.
If that doesn't work, try resetting the device by: powering it down, click and hold the [Reset] button, and whilst holding it, turn the power back on. Keep holding the [Reset] button until the main screen reappears...
When still no luck, try contacting Canon support directly: http://www.usa.canon.com/cusa/support/consumer
Good Luck !
Jun 27, 2014 | Canon FAXPHONE L190
Memory if full message on Canon L190
I am sure a 'Memory Reset' would fix this.
As to 'how', I can only suggest you check out the precise way to do this in your CD manual.
Dec 18, 2013 | Canon Lasers FAXPHONE L190 Wireless...
How do i clear the memory out of a canon l190 fax machine
1) Power off (front of system)
2) Hold down Rest button (//), keep holding down
3) Power back on, keep holding reset until until back on.
Sep 16, 2013 | Canon L190 Fax Machine
How do I print a confiramtion page to make sure my
Press Funktion and then report-activity reports will be displayed press ok.Or you can go to funktion-datarigestration-scroll to reports,press ok,select TX report,select output yes.Then after you send a fax a tx report of the fax you send will be printed out.
Dec 08, 2009 | Canon FaxPhone L75 Plain Paper Laser
Confirmation sheets
Yes,press usermode go to reports and in RX report switch it to on.
Jul 11, 2008 | Canon FAXPHONE L80 Laser
Canon FaxPhone L 80 Busy
1-you must confirm that your phone line is clean and stable-and this is easy by test the phone line with another good fax if the problem exist.sure your phone line is bad and you connect with the phone company to get help.if the problem goen your fax is guilty.first try to opposite the phone wire from the outlet and change the phone connection with new one.if all above does not work you must send it to nearest workshop.
Mar 03, 2008 | Canon FAXPHONE L80 Laser
Feb 20, 2008 | Canon FAXPHONE L80 Laser
REPORTS
There is a report called a Confirmation report.
Under your set up, you will find it under one of 2 headings. Either under "reports" or it may just say Confirmation.
You will have 3 settings. 1 is to print on error only. 2 will be to print always and of course off.
If you want it to never print set off, if you want it to print when the fax is NOT sent, sellect error .
Dec 11, 2007 | Canon FaxPhone L75 Plain Paper Laser
Canon FaxPhone L80
Press Function, Data Registration, and then Set. Use the up/down arrows to select "report settings", then Set again. Using the arrows and Set change the values or TX REPORT and RX REPORT to "YES". This will pring a TX/RX report after every fax. When you are done press Stop/Clear. This is from Sectioon 14 of the owners manual. Let me know if you need more help.... Mediaman85@mchsi.com
Aug 20, 2007 | Canon FAXPHONE L80 Laser
554 people viewed this question
old marine
old marine
