Question about Dell Inspiron 1525 Laptop Jet Black
Dell inspiron 1525 wireless problem
I just purchased this model and for some reason I cannot connect to a network. I see the networks, I have 5 bar excellent signal but when i try to connect the message pops up:click for info on troubleshooting low wireless signal. I have another laptop which connects without a problem to the same network. Is there any way to fix it?
  • Anonymous Jan 14, 2009
    test
  • megax01
    megax01 May 11, 2010
    When you click the message what does it say?
    You should also check device manager to make sure your wireless networking card is working properly.
  • 561 Answers
Go to http://support.dell.com and under the drivers and downloads section, enter your Service Tag, and download and install the latest Wireless Card driver for your model. Update to latest BIOS version as well.
Posted on Dec 30, 2009
  • juliemoran18 May 14, 2011
    Ok, this confuses me. How on earth do you access that support.dell.com site if you can't get connected??? I'm having problems with my Inspiron 1525 right now too. I can't get connected, though all the other non-Dell computers in this house can, and thank god since I'm using my brother-in-law's way more reliable Acer to research this issue...
Wireless network
Assuming you are using Windows 7, connect to your wireless network, click the signal bars, right click your wireless connection and select properties. Select the Connection tab and make sure
Connect automatically when this network is in range is selected.
nqaakhh4qwaybreaahg4qwaybreaahg4qwaybreaahg4qwaybreaahg4qwaybreaahg4qwaybreaahg4qwaucn9f4k8oqqzjcdlaaaaaelftksuqmcc
Dec 27, 2013 | Dell Inspiron 1525 Notebook
The wireless network adapter could not be accessed. this application may have dimnished finctionalty as a result. can you help me with this? inspiron 1525
There is a reason the wireless network adapter can't be accessed. It could be that you've turned off your wireless network. The driver for the adapter could be corrupt.
Check to see if it's turned on. If you access your network adapters, you should see if it is turned on or not.
If this doesn't help, from the device manager, remove the network adapter. Restart the computer and it will find the adapter and reinstall it. I think this will solve the problem.
Jun 13, 2011 | Dell Inspiron 1525 Notebook
Cannot access internet or no network connection.
Dell Inspiron 1525: Unable to Connect Wireless Network
setting up the right option for wireless network connection at Dell 1525. Here's the following:
  1. Go to Control panel
  2. Select Windows Security Center
  3. Select Windows Firewall
  4. Click on Change settings
  5. Here you might see User Account Control will ask for your permission to continue, simply grant it.
  6. Click on the Exception tab at the middle
  7. Scroll down to Wireless Portable Devices and check the box next
  8. Click Apply, then hit OK
  9. After close the program now you can try to connect again and watch the result.
With assumption you're already make the wireless enable in BIOS setting. In the device manager you should see what the type of wireless wlan card you used and make sure it's already turned on via your switch on your laptop. If it was, then you need to find out the right wireless device driver for Dell Inspiron 1525. Here's the following:
  1. Visit Dell Support site and open the Network tab in the table.
  2. Find your wireless device and download the driver for it.
  3. Aim to a folder on your computer or any external drive if you have it.
At the Inspiron 1525 laptop
  1. go to start
  2. Right click at My Computer
  3. Click Properties
  4. Click Device Manager and Network Adapter .Here you should see a WLAN Mini-Card or might you only see "Unknown Device".
  5. Right Click on it and go to properties to select the Update Driver. Now you should browse the folder to select the driver you're already download at the first step.
NOTE:
Just follow the instruction appears completely. After installation the wireless wlan driver at Dell Inspiron 1525 finish, then reboot the machine and know your wireless connection should be works properly.
Jun 07, 2011 | Dell Inspiron 1525 Laptop
Will not connect to wireless network Dell inspiron 1525 wii not connect to my wireless network says connecting status unknown the dependency service or group failed to start
Hi there. Try these simple steps:
Click Start, then click Run if you're using XP and type services.msc then click OK. If you're running on vista, Type services.msc on Start Search field then click the icon on top that says Services.
Double click Wireless zero configuration on XP and WLAN on Vista. click dependencies and see the services where it is dependent on.
Inside the services window, click the name where your wireless is dependent upon and click start. Check for other dependencies and start reconnecting to your wireless network.
^_^
May 13, 2010 | Dell Inspiron 1525 Notebook
Got a dell inspiron 1525,no internet saying http 404 not found. what do i do?
This generally indicates a lack of connectivity with your network or internet service provider's network, whether it's wired or wireless. Check to make sure you have an established connection to your internet service provider.
Knowing what operating system and your connection status would help to assist you further.
Apr 14, 2010 | Dell Inspiron 1525 Laptop
My Dell Inspiron 1525 has been connected to wireless networks in the area and working perfectly. Suddenly this morning the connection was disabled and now it tells me there are no networks available....
Sometimes when you boot up the wireless card does not get an IP address from the wireless router. If you have an wireless icon on the task bar with a red X on it then right click on this icon and click Repair, if not go to the Control Panel - Network Connections - right click on the wireless connection and Repair. This will force the wireless router to issue the wireless card with new IP address.
If this doesn't work check the Device Manager to see if the wireless card is enabled and functioning, if not reinstall the wireless driver and configure it to match the wireless router settings.
Jun 23, 2009 | Dell Inspiron 1525 Laptop
My wireless will not work
Check your Settings in the Control Panel (Network Connections, as well as Hardware (to be sure the device is enabled!)
Also Check Power Settings in the Control Panel.
Go to Dell.com, Download the Drivers and Software (Everything Relative to Networking)
Reinstall them,
Apr 21, 2009 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
Wireless network driver for dell inspiron 1525
http://ftp.us.dell.com/network/R171131.EXE this is not site this is the setup file of wireless network driver in winxp.. ok pls try
Apr 06, 2009 | Computers & Internet
Dell Inspiron 1525 Laptop Jet Black  Logo
1,586 people viewed this question
Alun Cox
