Question about Samsung 37 in. Flat-Panel LCD HDTV
Tv stays on, but loose picture and volume
Same time of day
came back on same time of day
  • 133 Answers
You need to go into the menue, and find timers, and turn them off, that is one of the things that cause this, especually at the same time
Posted on Jan 11, 2009
Tv recalls
tap the sides and top of the tv to attemt to restore the picture.
You probably have a loose component or wire inside that is affected by heat. If it is under warranty maybe return it for repair.
Unfortunately most electronics are disposable these days.
Sep 11, 2013 | Dynex Televison & Video
ALBA tv screen turns itself off, but the volume stays on, what's wrong with it? how do I correct it?
Might be some loose solder terminal/s at its horizontal output section. The set should be checked.
May 11, 2012 | Proton MM2701VT 27" TV
The volume and picture on my LG 42LB1DR TV shuts off by itself
check the menu for power saving option if it`s on shut it off.
Aug 28, 2009 | LG 42LC2D 42 in. LCD HDTV
I have a 32" Toshiba Regza, within the last week, the screen goes blank but still have audio. If I turn the TV off and back on the picture comes back, sometimes the picture stays but other times the...
i know your problem. its an inverter loose connection from CCFL to inverter output. back of your LCD inside the TV. try to remove and re-connect again. be sure no power and AC is unplugged. romsky79@yahoo.com
May 28, 2009 | Toshiba Regza 32LV67U 32 in. LCD HDTV
VIORE LCD TV/DVD won't turn on
19 in wont turn on. red light just solid , unplugged for a day still same , is there a reset button
Aug 18, 2008 | Televison & Video
36 inch RCA tv loses picture and sound, but power stays on
Cable Looses signal power after 20m ... Install signal amplifier
https://youtu.be/AkiKf4G4UE0
May 04, 2017 | RCA 36V430T 36" TV
Volume up then pic gone
Good Day;
The TV's front panel may be bad, manual buttons. TEMPT FIX; remove speaker, cloth covered, cover, disconnect cables. TV will work but only with remote.
Good Luck!
Jun 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
"snow" screen, full volume, remotes don"t work
good day
due to the long time the buttons were not used, they tend to get stuck and this causes channels eighter to stay in one station or continou scanning. it could be resolved by spraying WD40 on the buttons and press it many times then dry it before operating the unit.
chris
Mar 25, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Picture flips from color to black and white continuously
I believe your set has a loose conection that needs to be resoldered ,every time you hit it reacts and that is good,you need to use a wooden or rubber handle to tap in the main board,around the tuner and in different areas until it reacts,be attentive when it does so you can flip the board and resoldered the area that made it react,once the problem is corrected you need to resoldered any other overheated areas and there should be a few in your set,check the grounds in the tuner(where the coax goes in the inside,is a silver box),the horizontal driver transformer and output transformer.Be careful while you do this and stay away from the thick red wire going to the back of the picture tube specially when the set is on. Let Us know how it goes or if you need more information.
Nov 08, 2006 | Sony KV-32FS13 TV
Samsung 37 in. Flat-Panel LCD HDTV Logo
Jerry Greenberg
Jerry Greenberg
