Question about Vacuums
Brush stopped spinning - Vacuums
  • 3,287 Answers
Hi Carla,
It is very likely that the rubber drive belt that connects the motor to the beater bar / brush has broken. This is especially true if you've had the vacuum for very long and never had to change it before. The good news is that this belt an inexpensive part and is replaced under normal usage as it is a wear and tear type item - not unlike brakes in a car.
Depending on the model vacuum you have, accessing the belt for replacement may require some simple tools. Most of the time a medium sized regular or Phillips screw driver is all that is needed to remove screws / pry the tool apart for access.
If you provide the manufacturer's name and model of the vacuum or attachment - I will be happy to get you more information on how to replace the belt.
Posted on Nov 29, 2012
2 Suggested Answers
  • 85 Answers
SOURCE: brush attachment stops spinning
does the pin break or the turbine freeze
Posted on Dec 15, 2009
Why did the agitator stop?
Bryan,
Most of the time, when a brush stops, you either have a broken belt or there is something wrong with the brush. If the brush spins very freely when you try spinning it by hand, you have a broken belt.
Jul 21, 2015 | Kenmore 31913 Progressive Direct Drive...
Hoover windtunnel U5453-900.belt melted put another belt on brush was spinning.Brush spins but not easily.It spins then stops therefore burns the belt.How can i get the brush to spin around better
Kristie,
I would suggest taking the brush bearings at each end off and clean any lint or hair that might be in the ends of the brush. If you have regular ball bearings on your brush, you might need to replace the brush roller if the bearings themselves are tight. Hope this helps!
Apr 05, 2015 | Hoover Vacuums
Brush inside main head doesn't spin, and stops spinning immediately after prompting it to spin. seems like the motor stop turning brush, however when i open main head and cover suction hole for a...
Sorry to hear you're having difficulties with your DC14. If the brushbar won't run when the cleaner is in contact with the carpet, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Customer Service
Jul 13, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
The vacuum was working fine then suddenly the main brissels that spin to collect the dirt stopped spinning, the vacuum still has suction but barely picks anything up because the brissels are not spinning
Best thing to do is remove the spinning brush and clean all debris from the brush and most importantly from the ends of the brush. The ends of the brush usually have two holders (square?) that hold the brush in place on the vacuum. The brush is supposed to spin in these holders. If it does not, provided the belt is okay, the location where the brush contacts these holders need to be cleaned and lubricated with some WD40 or some 3 In 1 oil. Be sure the belt is in proper running condition as well.
Sep 05, 2010 | Bissell Cleanview Helix Vacuum
If you've had the brush out to clean it you need to re-set the trip switch which is a red button at the right side of the brush simply press it in till it clicks.
Jul 05, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
Brush attachment stops spinning
Dec 11, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Rainbow SE power nozzle
If the brush is spinning ok, and the belt isn't slipping, then probably the circuit breaker is bad, or the motor is causing the problem.
Oct 23, 2007 | Rainbow 75th Anniversary Canister Vacuum
Bissell 37602 roller stopped spinning
If the roller brush as stopped spinneng .and the brush motor still works the brush belt as broken,
you must replace the brush belt, t
Sep 05, 2007 | Bissell 37603 Upright Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
