Question about Ford Garden
Where do you add hydraulic oil to 6600 ford tractor
4 Suggested Answers
  • 251 Answers
SOURCE: ALLIS CHALMERS 190 GAS -HYDRAULICS ON TRACTOR ARE
hi , replace your hydraulic oil filter and pump and renew the oil .
hope this helps
Posted on Jun 21, 2010
  • 252 Answers
SOURCE: My recently purchased used MT180HD tractor will
hi there joedorava
is there input to pumps , are there any leaks in the system either oil / air
have you purged all the air from the hydro units and wheel motors
if air is entraineed in oil , you may get alot of noise from caviatation in the pumps and wheel motors also heat , and vibration and no movement until all the air is gone
top up oil to correct level
caviatation can be quite destructive on pumps etc
i assume you used the correct hydraulic fluid for the unit in question
have you checked changed hydraulic filters when changed hydraulic fluid ?
other than that cant give any more info
cheers pauly46
Posted on May 25, 2011
  • 8 Answers
SOURCE: Where is the hydraulic oil
Its the transmission itsef, you fill it from under the hood between battery and steering console. Its a little black cap that lifts off tube.
Posted on Jun 30, 2011
Wat hydraulic fluid do i use for my ford tractor 6700 modelEC215 serial number B364256
First, whatever you buy be sure it is Transmission/hydraulic fluid not just hydraulic oil. The hydraulic and trans oil are the same oil. John Deere trans fluid will work, Case IH. Tractor supply has a fluid that works good, Traveller Trans/Hydraulic Renew. It is for older tractors.
Nov 14, 2016 | Ford Garden
Hi - What SAE oil do I use in my Ford 6600 hydraulic system?
Penrite recommends a combined transmission/hydraulic oil, 10W-30/75W-80 or GL4..........
http://www.penriteoil.com.au/products.php?id_categ=5&id_products=162
May 25, 2016 | Ford Cars & Trucks
Don't know how to read the hydraulic dipstick for a 1944 ford 2n tractor
Ford Tractor Hydraulic System - My Ford Tractors
www.myfordtractors.com/hydraulics.shtml
All N-Series Tractors - Ford-Ferguson 9N, 2N, and Ford 8N ... 6 - How long has it been since you changed the hydraulic fluid? ... If that didn't do it, read on. ... then remove the bottom bolt from the inspection plate that has the hydraulic dip-stick.
Yesterday's Tractors - Fifty Tips for Ford 9N, 2N and 8N ...
www.yesterdaystractors.com/articles/artint268.htm
I'd like to say that the reason I have an 8N Ford tractor is because that's the tractor ... The N tractors have a common sump for the rear end, hydraulic pump andtransmission. ... (Read the label.) .... Take the inspection plate with the dipstick off.
Ford 8N, 9N, 2N, NAA Tractors Information - SSB Tractor ...
www.ssbtractor.com/wwwboard/messages15/
Helpful information and resources on Ford 8N, 9N, 2N, NAA tractors from SSB Tractor, a leading provider of tractor parts, manuals, implements ... 1944 ford 2n: What type of oil to use? and whats the oil pressure should be? ...... N Series Trans/Hydro Fluid - Interesting To Read ... Ford NAA/Jubilee Hydraulic dipstick location?
Jan 01, 2016 | Ford Cars & Trucks
How to check the hydrolick fluid on a 1972 ford 5000 it has no dipstick I just got this tractor
Ford Tractors Information - SSB Tractor Forum
www.ssbtractor.com/wwwboard/messages4/
Helpful information and resources on Ford tractors from SSB Tractor, a leading provider of tractor ... tractor pumps oil but won't pump hydraulic fluid ..... 1972 Ford LGT165 lawn and garden tractor hydraulics ..... Ford 5000 transmission oil level
Aug 17, 2015 | Ford Cars & Trucks
Does rear end oil and hydrodaulic fluid go in same reservoir
Ford 8n's use a commion sump, rear end, transmission and hydraulics. Ford called for 80 or 90 weight gear lube depending on temperature (winter/summer) about 5 gallons The link below is a great article on proper oil and maintenance....Hope this helps...
< http://www.myfordtractors.com/hydraulics.shtml > Ford Tractor Hydraulic System
Jul 26, 2014 | Ford 8N Tractor
What type of hydralic oil used on NAA FORD TRACTOR
NAA Ford Tractors us 90 weight gear oil in the hydraulics, and transmission.
Oct 25, 2012 | Ford Naa 600 800 Tractor Tachometer...
I have a Ford 3500 backhoe year is mid 70's. I need to replace the transmission fluid. Any idea what tyoe of fluid?
Officially, it's listed as M2C53A trans & hydraulic oil. Hope you can track down an equivalent where you are
Apr 11, 2010 | RTO Ford Tractor 2000 3000 4000 5000 Water...
I have a ford tractor and hydraulics are slow
not so fast,, yes thick hydraulic oil can cause slow hydraulics and if the hydraulics speed up when warm then this may be your problem. if they dont then you need to look at possible problems with the pump, the spool, or linkage to spool. remember that speed is flow, a pump can have good pressure but lousy flow. also there should be some kind of pressure relief valve in system if this stuck open then it will let oil go back to tank causing your problem. there is no quick answer to your problem but there are a lot of possibilities. need to do some diagnosing!
Feb 08, 2010 | Parat 1:32 Scale Diecast Replica: 1920...
Ford 4000 hydraulic problems
First, make sure there is plenty of hydraulic oil in the reservoir
2nd, no leaks that are dumping the pressure
3rd, no blockage in tubes, located inside pump housing.
4th, make sure operating handle is engaging
try these and if nothing works let me know.
Jan 23, 2010 | RTO Ford Tractor 2000 3000 4000 5000 Water...
Garden Logo
562 people viewed this question
Top Ford Garden Experts
Dennis Key
Dennis Key
donald boissonneault
fordexpert
Are you a Ford Garden Expert? Answer questions, earn points and help others
