Question about Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV
Hi I need to knwow how to change the lamp XL 2200
    Champion:
  • 240 Answers
Remove center scrue turn handel to the left
remove handel
remove protection plate.
now you will see a loop handel lift loop ring up and pull out tords you.
very simpel, sounds hard but its not.
regards,
daniel.
Posted on Jan 11, 2009
I am trying to figure out how to replace my replacement lamp, but do not know where it is located.
Lamp Access door for Sony KF50WE610 is below the screen on the front of the TV. This page shows location of Lamp access door and DIY bulb change instructions for most SONY LCD TVs:
DIY Bulb Installation Guide
XL-2000 XL-2100 XL-2200
XL-2400 XL-2500 XL-5000
XL-5100 XL-5200 XL-5300
This page shows Lamps and bulbs for all Sony LCD Projection TVs
Sony Lamp Gallery
Look at Optical Engine Faults before buying a lamp or bulb. Replacement bulb will not repair these problems.
Feb 05, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
I need instructions for changing lamp in sonye55a20
LAMP NEEDED IS AN XL-2200 THERE ARE TWO THUMBS SCREWS ON LEFT AND RIGHT HAND SIDE OF THE TV BEHIND THE BOTTOM LEFT/RIGHT CORNERS OF THE SPEAKERS. LOOSEN THEM AND PULL THE FRONT PANEL OFF THEN YOU WILL SEE THE LAMP DOOR TO THE LEFT OF THE FRONT LOOSEN THE NEXT THUMB SCREW THEN PULL THE DOOR OFF AND THE LAMP IS HELD IN PLACE WITH 2 ALLEN WRENCH HEAD SCREWS LOOSEN THEM AND PULL THE LAMP OUT. INSERT NEW LAMP AND DO REVERSE
Dec 17, 2010 | Sony KDF-E55A20 55 in. LCD Television
Dark picture
most likely just a lamp issue this lamps are rated for a avarage us of 2-4 years
when the lamp starts to burn out the picture will dark to get dimm to the point where you need to turn off all the lights in the room to see the image the first thing I would replace would be the lamp
I found it for you just incase
http://www.discount-merchant.com/XL-2200-LAMP-p/sony-xl-2200-housing-h.htm
Oct 18, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
HOW TO REPLACE THE LAMP ON MY SONY LCD PROJECTON
Lamp is a user replacable. You can follow the instructions listed in the Manual. Click on the below link to open the Manual:
http://www.docs.sony.com/release/KDFE55-60A20.pdf
Jul 25, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Replacing lamp
Lamp replacement procedure is written in user manual,check page-17
Click Sony Support to download free copy of user manual of KDF-60WF655 if required.
There are two thumb screws at lower corners if you see tv from rear, remove these screws and take out lower front panel, in center of that space, you will see lamp cover, remove it and unscrew old lamp, pull it out and put new lamp then put things back in reveres order.
Required lamp of KDF-60WF655 is available in Sony Accessories Store for $200 under part number XL-2200
Hope these info will help you.
Thanks.
May 13, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
How change XL-2100 on my television
Please use XL-2200 replacement lamp in the TV.
I'll forward a link where you can download the Manual for the TV.
Please copy and paste the link in the address bar of the web browser to download the Manual.
http://www.docs.sony.com/release/KDF60XS955.pdf
Please refer to page # 16, 17 18 and 19 of the Manual to view the information about how to replace the replaement Lamp in the TV.
Thank You!!!
Apr 05, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
The picture and sound on my 55 inch Sony disappears momentarily
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is XL-2200.You can find it here: http://www.discount-merchant.com/Sony-XL-2200-TV-Bare-Lamp-Bulb-p/sony_xl-2200u_a1601753a_lamp.htm?Click=48173 Have a blessed one!
Apr 02, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony kdf42we655 red light blinking lamp I have lamp don't know how to replace how to open panel
If you have changed a spark plug in a car--this is EASY to do. The lamp is behind the front panel in this set IIRC. That bottom piece comes off, after removal of the "thumb screws" on each side of it on the rear. It then takes some effort to "pop" the catches loose, but it will come off, just work from one side at a time. Then, the lamp door is in the middle and a big thumbscrew holds it on. Remove it, and the lamp is behind here, up a small "tunnel" and you will need an allen wrench to remove the screws holding it on. Once this is done, it pulls out--and can be replaced with a sony lamp, I think an XL 2100 or XL-2200. BTW a new Sony lamp WILL come with an allen wrench.
Oct 09, 2009 | Sony KDF-42WE655 Television
Wrong model number listed in my original question
I gave you exact and correct lamp part number of KDF-E55A20 and explained in previous reply that there is no difference between XL-2200 and XL-2200U lamp. both are same, first on came with new TV and second one is its replacement number.
KV-36FV26 is CRT TV and has no lamp inside.
May 18, 2009 | Sony KV-36FV26 TV
Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV Logo
37 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
