Question about Freezers
Freezer temp not staying at -20 - Freezers
  • 4,655 Answers
What is your model number? Sea Breeze
Posted on Nov 29, 2012
Frigidaire 20 cu ft. upright freezer went out a few days ago. Discovered bottom seal was not in place but fixed that. Alarm light stayed on through the night and freezer is not cooling AT ALL although...
Is your compressor kicking on? If not then check the contactor-relay and the capacitor. If that isn't the problem then it is probably your compressor. Which is quite expensive to replace.
Aug 08, 2011 | Frigidaire 20 cu. ft. / 566 liter Upright...
Display screen temp. not matching temp. inside freezer .
most likely the temp sensing probe. Possibly the sensor has been moved from it original position and reading the wrong temp. too.
Jul 07, 2010 | Delfield 20 cu. ft. / 566 liter Upright...
How do I test the temperature control module for a kenmore freezer model 253.9284013
You need a multi-meter to do this. The temp.control is just a switch that closes on temperature rise and opens on temperaure fall (or when it reaches the desired temperature). Using a meter set on ohms coneect to the 2 prong ends of the temp. control. Set the temp. control on off. You should not have any ohms because hte temp. control is open (no continunity) now set the temp control to 2 or 3 and it should close (the meter will read ohms or continunity)
if it does then the t'stat works. The only other exception is the temp. control will sometimes (this is rare) not properly sense temp. for example, it fails to sense zero degrees and it will either stay on too long to shut off too soon. I only seen this happen like twice in 20 years. but more or less this is how you do it!!!
hope this was helpful
Mar 14, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Does the light on the outside of freezer stay on . I bought a used freezer. It is a frigidaire commercial upright (frost free) Does the light on outside of freezer stay on all the time? I have no manual....
Normally there is a Green light showing that power is on
A Yellow one for fast freeze and a Red one for under temperature
The outer casing is well insulated from the inside otherwise the freezer motor would run none stop without cooling the contents so the temperature of the outside casing will reflect the room temperature not the intenal
Aug 21, 2009 | Frigidaire 20 cu. ft. / 566 liter Upright...
Temp changes in freezer
If the temperature fluctuations occur (at least the ones to 20-30 degrees) at intervals of 6 hours or so then you are catching it in it's defrost mode which occurs on a timer. The timer shuts off everything except lights every 6 hours for an average of 20 minutes. This usually isn't enough to thaw things but I have seen it cause some crystale. Look closely at the back inside wall of the freezer for an accumulation of frost. If you see it there then you may have a defrost problem. Usually this is accompanied by steadily rising temperature in the freezer and fresh food secions both. The temps you listed (0to10) are fine. Good luck, AJ
May 22, 2009 | Freezers
Proper temp. range in freezer
Hi dgh1,
The freezer should stay within 5 degrees of 0 while in operation. While in defrost the freezer may reach as high as 20 to 25 degrees. If any higher temperatures are reached your food will spoil as they are defrosted and refroze everyday. If you find that the temperature is allowing your food to defrost you may want to replace your defrost thermostat. This device is located on top of the evaperator coil inside the back of the freezer. It is made to turn the heater off when a temperature of 55 degrees is reached. One other possible problem could be your defrost timer is taking to long to restart the cooling cycle after defrosting. I hope this will help you and please send any other questions you may have, I am happy to help. and dont forget to rate me.
Mike Anderson
Anderson Appliance
(865)945-3808
Oct 28, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Temp
jtcarlier
20 Degrees is good
I am happy to assist you!
Neil
PS. Before you leave this site please leave a "Problem Solved" rating for me on fixya.com
Aug 24, 2008 | Kelvinator 12 cu. ft. / 340 liter Chest...
Freezer stops and start
ice cream is always the last to freeze and a temp of minus -10 degrees is usually required to get it to get hard. if you put the ice cream in the door it will be especially tough to freeze. a good thermometor is a good investment as you can observe the temps. usually ten degrees or 20 degrees is what they run. yes they do cycle on and off as long as they hold temps thats good. the outside of the freezer gets warm because the hot compressed refrigerant is spread through piping near its surface giving up its heat of compression . setting the stat to max will freeze the ice cream eventually but utility bill suffers . good luck
Jun 03, 2008 | Danby 3.6 cu. ft. / 102 liter Chest...
Freezers Logo
37 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
