Question about Car Audio & Video
Hi i have a vauxhall vectra with an inbuilt cd changer how do i get m magazine out after i push the eject button thanks
SOURCE: Problem with stuck magazine....
OK I have had exactly the same problem and spent the last hour or so fixing it. It seems to have its logical knickers in a twist after the battery going flat and won't eject because its left a CD in the playing position, IE, out of the magazine. So, remove the changer from the car (usually velcro then pull off the two phono and the power connectors) and undo the four small cross head screws holding the case on. Pull the front panel off (you may need to pinch the case in the middle top and/or bottom as there is a clip here holding the front panel), then either pull the sides of the case out until the two rotary Horizontal/vertical mount controls disengage (or you may be able to rotate them anti-clockwise until they pop off, but I didn't try this) and lift off the lid. Next, pull the four little mounting posts on the internal deck assembly out of their four rubber mounts on the outer case, and disengage the two springs from the horizontal/vertical mounting controls. The mech is now loose inside the case but be careful as its attached by a rather delicate ribbon cable to the outside cables and connectors, This will unplug after you pull off the sticky tape holding it to the chassis, but you might be able to do the rest of this without unplugging it if you turn the mech over carefully. You will see a motor assembly and several white cogs (actually you will see two but the little tiny one with a worm (spiral) drive only moved the CD mech optical head so ignore that one). Using a small screwdriver, carefully rotate the cog closest to the motor so that (viewed with the motor closest to you and to the right) the plastic parts under this assembly start to slide to the right. You should actually be able to see the CD underneath start to move to the laft, back into the magazine, and the CD mech will open up to release it. Once the cog doesnt want to turn any further (and the CD is completely back in the Mag), then you will be able to manually eject the mag by pulling sideways gently on a round white part on the mag side. The mechanism should click and release the mag. Hey presto... fixed. Now just reassemble the whole thing back into its case, probably a good idea to check that each of the CD's is correctly seated in the mag and that there is nothing wrong with any of them that could cause it to jam again, then go try it in the car prior to final assembly. As we now know that this unit seems to be prone to throw a wobbly if its power is removed with a CD in it, I would strongly recommend that you eject the mag before disconnecting the unit for final assembly, assuming it all works OK now, or indeed any time you might have to disconnect the car battery for any other reason. Hope this helps, it did it for me! Mark
Posted on Jan 21, 2007
Eagleeyes
  • 199 Answers
SOURCE: Inoperable CD changer
Hi the alpine/merc/bmw cd changer all seam to suffer with the same problem, they say no disc, or no mag try firmly hitting the mag with the handle of a screw driver. the loadinga arm, tends to get stuck. you could try using some grease on the arms, and levers, white spray gease works best. but dont forget to cover the laser beforehand, you dont want grease on it :) Mark www.carradiospares.co.uk
Posted on May 03, 2007
Eagleeyes
  • 199 Answers
SOURCE: factory installed Alpine 6 CD Changer- cd magazine (for 1998 BMW 528i E39)
Hi , seen lots of these.
whats happend is the Tray that the disc sits in has jammed halfway in.
in most cases giving the mag a swift tap (hard tap) with the haddle of a screw driver , while pushing the eject button normally is just enough to dislodge the mag.
otherwise its a repair job.
were do you live Alison?
Regards
Mark
www.blueice-electronics.co.uk
Posted on Jun 23, 2008
welcomejee
  • 10594 Answers
SOURCE: how do you eject the magazine
Press and Slide Front half cover as shown in below image and you will see eject button there to eject magazine.
Posted on May 04, 2009
SOURCE: Can't eject cd magazine - E-99 error message
I had the same problem. I opened up the unit and found out that there is a plastic gear that moves the loader. When worn the loader can not load tha magazines nor change cd's. I replaced the gear and the cd autochanger worked fine.
Gerald,
Kenya.
Posted on Aug 25, 2009
Blaupunkt cd5 changer does not have an eject button how do i retrieve my cd's?
If it has a magazine, you'll have to remove it. Some magazines push in to latch and you can push to unlatch and pop out
Sep 18, 2012 | Blaupunkt IDC-A09 5-Disc CD Changer
I have a 1997 Ford Explorer purchased new with te
is there a coin holder in front of the changer? if so, there may be a coin lodged inside the changer preventing the carrier mechanism from moving. look on the bottom of the changer to see if a coin might be stuck.
Mar 11, 2010 | Clarion DC625 6-Disc CD Changer
My 04 yukon cd changer won't eject the cd. any advise?
if you push the eject cd magazine button on the changer does it sound like it's trying to eject it? if it doesn't you'll need to replace the changer. if it does, then you've got a stuck cd magazine tray. it sounds weird, but when i was working on land rovers this happened all the time on the full size range rovers. what we did was push the magazine eject button on the changer to eject the cd magazine and sort of slap the changer around a bit. 90% of the time it worked. the other times, we'd go in with a 90 degree pick and try to push the stuck cd tray back into the magazine (while it was still in the changer) while pushing the eject magazine button on the changer. and you'll need to replace the cd magazine. if it happens again, you'll need to replace the entire changer.
Feb 16, 2010 | Car Audio & Video
Eurovox 'Maestro Series' 10 stacker displaying 'E-99'
CD ERROR DISPLAYS
CD Changers
E01:
The disc magazine is not inserted in the cd changer
E02:
No disc is inserted in the disc magazine
E04:
The disc is dirty, or the disc is inserted into the disc magazine
upside down
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
FM/RF Remote Controls
E99 RESET PROCEDURE FOR REMOTES:
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
WAIT:
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds.
IF THESE ERROR CODES STILL KEEP APPEARING
CONTACT YOUR DEALER.
Jun 21, 2009 | iLO CA3000V CD Player
How do you eject the magazine
May 04, 2009 | Sony CDX-T69 6-Disc CD Changer
I put a small pin in the reset button a few times and that then got the catridge to eject.
Apr 14, 2009 | Car Audio & Video
No ejection
hi does it make any noise or clicking?
you may have a cd dislodged or mag dammaged.
Mark
Sep 05, 2008 | Clarion DC625 6-Disc CD Changer
Factory installed Alpine 6 CD Changer- cd magazine (for 1998 BMW 528i E39)
Regards
Mark
Jun 23, 2008 | Car Audio & Video
How to eject the disc tray when not connected to the car?
hI , to enject cd is look a piece of strong tooth pick insert to a small hole at right corner of cd changer , push and and push tooth pick until the tray comes out.
Feb 02, 2008 | Sony CDX-454RF 10-Disc CD Changer
I receive error msg and cant eject magazine
The magazine in our Sony CD player would not eject. I tried pressing two buttons at the same time etc., with no result. I uplugged the player, removed the screws that hold the black metal cover on and took off the cover (pull the metal up, out and away at the back bottom sides, then slide it back to release the lip from under the front pane.) Looked down inside and saw the problem, a CD disc extended about 1/2 inch from the magazine, blocking ejection. I pushed the extended edge of the disc back into the magazine with the tip of a kitchen knife. Plugged the player back in, pushed power and then the eject button, and the magazine ejected. Replaced the metal cover and it works fine. If it won't eject again I know what to do. Be sure to unplug before you work, you don't need an electrical shock.
All the best, Sonia Murray
Nov 28, 2006 | Panasonic CX-DP801 8-Disc CD Changer
Car Audio & Video Logo
501 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
