Canon np2120 is giving a error code E000
La machine was working, just put the error.
  • 4 Answers
SOURCE: Canon D880 Error -- E000
Press "Additional Functions", press "#", then press the "Right Arrow" button till it says, "Printer", then press "Set" then press the "Right Arrow" button again until it says "Printer Reset" then press "Set" again, the display will ask you "Yes" or "No". Press the "Left" arrow for "Yes", then press "Set". Now, unplug the power cord and wait 5 seconds and plug back in. If this don't work, get a new fuser.
Posted on Jun 16, 2008
SOURCE: How to reset error code E000 on IR2000
E000: Fuser did not heat up. check Fuser lamp, check thermistor, check thermostat, if this parts ok try to reset the trouble code. to reset fuser errors, first shut power off and turn on again. Then, go to service mode. Select "User mode" by pressing additional function ( * ) key then Press "ID" key ( # ) on user mode screen. Select menu 7 using cursor key. Press "OK" key. Select 4 item with cursor key. Press "OK" key. Printer reset. YES=( * ) to clear fuser error code E000.
Posted on Jul 12, 2008
checkitright
  • 1362 Answers
SOURCE: I have an old canon
Are you mechanically inclined????
If yes the problem is most likely the fuser lamps are burned out.
This is to take out the fuser unit (the two heat rollers where the paper exits---------let machine cool first!!!!!!!!!!)
1-unplug machine
2-open left side door
3 open front door
4- remove the green knob on the left
5-remove the left side cover ( i beleive you need to take off the two screws on top that hold the glass also)
6-remove the back cover(it is hooked onto the side cover)
7-after removing the side cover look at the fuser left top corner unplug the connector- there should be one on the right also big black wires with a white connector remove the screws that hold the fuser in place
8- once the unit is out there is a lamp that runs the whole lenght of the roller that is the fuser lamp there are wires on each side, remove the lamp bracket holder and one wire, you should be able to tell if it is blown, it will be black and smoky looking not clear.
if you go through these steps you should take advantage and replace the thermistor, thermofuse, claws, and oil roller.
I use to love the 2120 they are one of the best machines Canon put out a true workhorse, do these things and don't worry about hte fuser for another 3-5 years .
If you don't have a parts supplier try precisionroller.com
Posted on Aug 19, 2008
biz_kid1
  • 107 Answers
From a fellow FixYa expert, "Press "Additional Functions", press "#", then press the "Right Arrow" button till it says, "Printer", then press "Set" then press the "Right Arrow" button again until it says "Printer Reset" then press "Set" again, the display will ask you "Yes" or "No". Press the "Left" arrow for "Yes", then press "Set". Now, unplug the power cord and wait 5 seconds and plug back in. If this don't work, get a new fuser."
Posted on Jan 06, 2009
  • 4 Answers
SOURCE: System error E000
Here's the definitive reset. It will work on the following models: ImageRunner 1200/1300, PC1060/1061/1080F, ImageClass D620/D660/D661/D680/D681
Press Additional Functions key
Press #
Press > to #7 Printer Function
Press Set
Press > to #4 Printer Reset
Press Set
Press <
Unplug printer and repower it.
Posted on Apr 24, 2009
I am having problem with IR3300 of code E000-0000 give me solution
Hi
I found your problem here:
Error Codes Canon iR3300 Code E000 0000
and it seems to have a number of alternatives. And also by changing the drop down menus along the top of the page you can view other errors for your machine and for other models and makes. You can also use the link to get a Service Manual for your machine, and this might be a good idea as it will almost certainly explain how to do the repairs..
Hope this is helpful, if so would you please register that with Fixya
Cheers
Jan 02, 2015 | Canon imageRUNNER 3300 All-In-One Laser...
Canon imagerunner 2230
try to clear in service mode touch Additional funcion key then 2 8 at same time then additional func key again in that order screen should change to service mode then touch copier then function then clear then err then ok then turn off machine using main switch if it wont clear you have a bad fuser
Dec 02, 2008 | Canon IMAGERUNNER 2230 Copier
Error Code E000-FF13
E000 error in a Canon is a problem w/the fuser (exit where it gets hot)\
Check thermistor, thermofuse or lamp
Oct 13, 2008 | Canon imageRUNNER C3220 Color Copier
Canon super g3 image class d880
E000 means your fuser section is having problems.sometimes you can reset but may need to replace fuser unit.
Sep 04, 2008 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Jul 11, 2008 | Canon Office Equipment & Supplies
Canon IR 1600 error message
Note: To reset E000, E001, E002, E003, go to service mode 4. select SET, go to "#7 PRINT-ER," in service mode. Then press Execute "#4 PRINTER RESET." Power the unit off/on.
May 17, 2008 | Canon imageRUNNER 1600 Laser Printer
Canon IR 3100 error code (E000020-0081)
error code E00020-0081 my canon printer IRC3170i.what is the problem?Anybody can help?
Feb 19, 2008 | Office Equipment & Supplies
System error E000
Press #
Press Set
Press Set
Press <
Jan 14, 2008 | Canon ImageClass D880 Copier
Error E000
the machine model or brand is not mentioned,
but if it is canon this code relates to heater [fuser} proplem
Dec 21, 2007 | Office Equipment & Supplies
23 people viewed this question
k24674
