I have 200 replacement tweeters how much r they worth
    Problem Solver:
  • 19 Answers
50 cents each
Posted on Dec 03, 2012
How to remove top dash of 03 honda odyssey to replace tweeters?
Most top dashes are held in place with screws located under the defrost ducts. This may not be the case with yours but worth a look
Apr 12, 2015 | 2003 Honda Odyssey
BOSE 2 AND VCSX OVER DISTORTION
have a tech look at your set you have some bad caps in the audio circuit along with your audio out put transistor or ic.have it replace along with the bad caps.good luck my friend.
Jun 10, 2007 | Bose VCS-10 Center Speaker
Need to replace tweeters. Anyone have specific info on aftermarket tweeters that will work
Replace tweeters with units having the same impedance as originals so amplifier loading is the same.
If unable to get exact replacement for unit, then it is important that you also replace the corresponding tweeter(s) on other channel since all speakers sound different and have different efficiency. Result will be unbalanced sound.
Mar 12, 2015 | Audio Players & Recorders
Hey.. I just bought a Bx8 studiophille.. Unfortunately I got cheated.. One of the speakers tweeter is not working.. Can you give me a solution.. Where can I get it replace??
How sure are you that't you tweeter and not a contact cable or, sunce they use cheap xhinese capacitors on the m-audio, just a capacitor has dead. Don't buy a tweeter, since they very often die and check the inputs , especially TRS amd rca and unscrew the the backplate and you'll notice that the cables and connectors used are cheapio. So it worth to check the pcb,s if you see broken caps. Which wouldn't surprise me , since their cheap once. And before buy another tweeter, first try it out on another small amplifier, to see if it works. Buying a new ine is the last fase, they ask high prices for a 10 dollar unit. Where did you buy it and how old is the unit?
Greetings richard
May 09, 2014 | M-Audio Audio Players & Recorders
How do I open up an EV sx100+speaker to fix the diaphram?
I just replaced diaphragms in the tweeters in a pair of EV Sentry 200 speakers. The tweeters had 4 bolts holding them together. One of them was stuck. It's just a matter of gently but firmly twisting it back and forth until it starts coming apart. Make sure you take it apart evenly or it will bind.
Sep 12, 2012 | ElectroVoice . Speaker
My tweeter isnt working how can i repair it and where
If it's removable then you can probably swap it out of another speaker, or find the specs (stamped on the back of the tweeter) and swap it with one that is compatible in ohms and size, wattage etc. maybe look at www.parts-express.com to start. It's probably not worth repairing in a shop unless it is under warranty still.
Aug 28, 2011 | Behringer Eurolive B212A Speaker
Hello, My CLSC-6C speakers make "scratching"
Most likely it is a rubbing voice coil in either the midrange driver or the tweeter. The only way to repair is to replace the bad driver or tweeter with a new part. Contact CV for replacement parts costs. Replacing parts in most speakers is usually easy to do if you have rudimentary tools and skills. Most connections are made with "faston" slip on/off connectors so a soldering iron is usually not needed.
Apr 02, 2011 | Cerwin Vega CLSC-6C Center Speaker
Tweeter not working
Check the continuity of the removed tweeter with a VOM meter (I use an original Heatkit MM-1 available on eBay for $20) and do the 1.5 volt battery click & scratch test mentioned above.
Celestion A3 tweeters (also used in the A1 and A2 speakers) or the replacement diaphragms are no longer available from Celestion. A1 speakers show up regularly on the United Kingdom eBay website for $300 or less and are small enough to economically ship to the USA. You would also end up with a midrange spare speaker (assuming it is the same as in the A3 cabinets)
The part number for the A series 3 bar tweeter is T4969/P. The 3 bars refers to the 3 bars in the casting to protect the dome. I got this number from the box of my spare tweeter I have the earlier 1 bar castings in my A3's.
Go to www.ersatzteil-versand.at do an "artikelsuche" (article search) for the number T4969/P and something extremeley similar shows up except that they list the manufacturer as Onkyo. The part number and description are so similar to what is printed on my spare tweeter box it would be worth 81 euros to see what shows up.
I have designed an adapter plate for either a Scan-Speak Revelator Tweeter D2904/710002 4 ohm, 1" soft dome, 70 mm diameter magnet, $220 or a Vifa D27TG35-06 6 ohms, 72 mm diameter magnet, 91 db, $37.50..Both are available from:
http://www.speakercity.com/ in Burbank, CA
I only modeled the front flange of the tweeter to save time. I have not built any of these yet but the price would probably be $400 for a pair of adapter plates and speaker flange modifications. But when you are done you would have replaceable tweeter for a long time to come. The 2 protective bars are drawer handles available for $3 each.
Other possibilities are:
http://www.audioloudspeakers.co.uk/boultons.shtml voice coil rewinding in the uk
http://www.speaker-repairs.com.au/coils.htm voice coil rewinding in australia
http://www.speakerex.com/diaphragms_new.html in Florida can rebuild the woofer and replace the midrange but no longer have the 4 ohm diaphragm for the tweeter.
If you want the drawings (and 3D geometry file necessary for the machinist to make the curved edges) for the adapter plate and tweeter flange modification contact me at mercedes280se-4@yahoo.com
Feb 11, 2010 | Celestion A3 Speaker
I have a pair of pioneer cs99-a speakers and i need the tweeters and the horn tweeters repaired is this possible if not were can i get second hand parts from cause i need a 4 inch and 5 inch midranges that...
hi i solved the problem with the super tweeters. two of them didnt go so i pulled them apart and got the voice coil and unwound it enough to solder it back on to the terminals.they both go excellent now took about a hour well worth the time.
Nov 29, 2008 | Pioneer Audio Players & Recorders
22 people viewed this question
 Grubhead
Grubhead
