Question about Snapper Garden
1990 briggs &stratton 16hp twin V model 303777 code 95101011-mower low usage-mechanic replaced carb, made other adjustments, was running good- got it home, hard to start, doesn't idle well, so
SNAPPER SR1642 (CONVERTIBLE) MODEL 421615BVE SERIAL 65870989
  • Harlan D. Hill Dec 01, 2012
    PROBLEM SOLVED BY TAPPING THE TOP OF CARB. WHILE CRANKING ENGINE. RUNS LIKE A NEW MOWER NOW.
SOURCE: need help to reinstall the under mower 42'' unit that out
I have that manual. If you want, give me a postal address and I'll mail you a copy. Mac
Posted on Nov 23, 2008
  • 246 Answers
SOURCE: coils keep burning out on 12.5 hp briggs &
Hello:
>>Have you Replaced the Coil with a New One?
>>If No, then Replace the COil and your Problem will be Corrected. The Ign Mosule inside the Coil is Heating Up and Shorting Out. This Causes the No Fire when Hot Problem.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 15, 2009
  • 636 Answers
SOURCE: Briggs & Stratton 22 HP V-Twin won't start
Take it back , it is still under warranty if you just bought it.
Posted on Jul 25, 2009
  • 496 Answers
SOURCE: Snapper Briggs and Stratton riding mower
It's mounted in an enclosure directly over the carburator.
Posted on Sep 22, 2009
SOURCE: Walbro Carburetor on Briggs & Stratton Model 28R707
If the float don't float, the needle valve stays open and gas runs into crankcase.
If float floats (has no gas inside) then the needlel is probably worn and needs replacement.
Posted on Sep 30, 2009
HOW TO ADJUST VALVES ON 16HP TWIN 2
I recommend taking it to your local Briggs and Stratton dealer or authorised repair centre.
Or you can buy a manual from Briggs and Stratton for your make and model which will give you photographs from which to work.
That's what I did to service my B&S lawnmower.
Mar 15, 2015 | Briggs & Stratton Garden
Will not start. but if I pour gas in carburetor it will. stop after the gas is burn of carburetor
Could be that the needle is stuck in carb, or else the fuel pump diaphragm is bad. Check the pump, thats what I would check first.
Jan 24, 2013 | Briggs & Stratton Briggs Stratton Vanguard...
Briggs & Stratton 16HP carb small hose purpose? Have a Snapper riding mower with 16HP Briggs & Stratton16 HP V-TWIN OHV Vanguard, Model 303777 Type 1145-A1 4750 Code 97021011. It started...
Should go to the valve spring access cover. Is the PCV line and keeps engine from building up pressure internally.
To clean the carb you will have to remove it from the engine and give it a through cleaning with small diameter wires run through the ports and blowing out the gunk with low pressure air or WD40's little red tube. From your description, you need to do this as the ports are clogged and not letting proper amounts of fuel through to the engine.
good luck.
Sep 16, 2012 | Tools & Hardware - Others
Ok i have a problem with my Briggs & Stratton 16HP v-twin vanguard engine.When i start the engine and rev it up when i idles back down it sits there and rev's up and down then it straightens out and...
It appears that you have a slight mis-adjustment in the idle speed and idle mixture. To adjust setup, start with at least a half tank of fuel, and have engine at operating temperature (That is warm but not overly Hot). The Briggs & Stratton Website manuals section should show the locations of the adjusting screws if you are not sure of them.
To adjust idle speed set Throttle control to minimum and adjust screw on throttle butterfly to maintain a good idle speed. To adjust idle mixture, screw in idle mixture screw (Lean) until motor falters and then screw out (Rich) until it falters again. Correct setting is the halfway point of these two positions. You may have to re-adjust idle speed again and also the mixture to get best running.
If you are not comfortable doing this, take it to a B & S dealer.
Sep 21, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
How do you replace a condenser on a 16 hp Briggs and Stratton v-twin model-303777...type 1142-E1. Note:Engine runs fine for approx 30 min(until it heats up) and then shuts off & will not restart until...
The condensor is not the problem for they go bad upon not hold a charge. When the engine heats up and the engines dies out the problem may lay in the magnito's frame mounting from swelling from the heat, a loose mounting bolt(s). Or a Magnito that is ready to go out completely
Sep 10, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Have 303447 briggs 16 hp only fires one cylinder
Have you also changed the spark plug too. The ignition circuit is pretty simple, from the battery, the Coil is energized, the "points" or equivalent, through the "Distributor" or equivalent, and onto the Spark Plug. So it is a simple matter to work along the path, proving the "Integrity" at each, point by testing. IF it still doesn't fire after ensuring all Leads are OK, the Spark Plugs are proven OK, the Cables, the Points, & Distributor, . IT is either that or the Ignition Timing is OFF. Please check all those points.
Apr 23, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Can a novice replace a carburetor on a Briggs & Stratton V-twin Intek 24 hp riding mower engine? If so, can I get some insruction sheets via email?
Yes its pretty easy you can do it.Are you sure the carb is bad most of them just need a good cleaning .I would disassemble be careful there are some little parts in there and if you are careful and pay attention as you disassemble it you can just clean it .Go to auto parts store get a can of spray carb cleaner .remove bowl be careful the is a float in there a little square or round bellows .Slide the pin out and then the fuel loat pin underneate the float now take out any adjustment screws you can find and spray cleaner in every hole you can find several times and reassemble if idle or fuel mixture screws were removed a standard setting of 1 1/2 turns out from seated position is the norm and some adjustment may be needed once running either in or out till runs smooth.
Nov 11, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
89 people viewed this question
Top Snapper Garden Experts
ray gallant
Don Eagan
Leakfixr
Are you a Snapper Garden Expert? Answer questions, earn points and help others
