Question about Gale Audio Players & Recorders
I have a gale 3070 sub woofer. When I connect it to the power with no audio connection being made, the inner fuses blow. can anybody help
I noticed it wasn't working so stripped it down to find the inner fuses blown. I replaced them and as soon as I connected it to the mains, they blew again
    Problem Solver:
  • 19 Answers
If a fuse keeps on blowing there is a problem with the amp, Take it in to be repaired, Or just get a different one, It will probally cost you less just to get a different one,
Posted on Dec 03, 2012
SOURCE: fuse blows
Both 3 or 4 amp slow blow fuses are suitable replacements for the 3.125 amp subwoofer fuse.
It could be that the subwoofer is blowing the fuse because the one you installed was not slow blow.
But, more likely is the subwoofer has a short in the power supply which is causing the fuse to blow.
Posted on May 31, 2009
SOURCE: sub woofer keeps blowing fuses
NO dont try a 3 amp fuse.It is made to BLOW if there is a problem. That sub is not worth fixing, JUNK it. There are a lot of problems with it. Such as heating up and melting the board witch could cause fires. Thats what happened to mine. Like I said JUNK it and buy a different one.
Posted on Dec 13, 2008
SOURCE: blown fuse on sub woofer
1 amp 250-volt from radio shack #270-1021
Posted on Jul 24, 2009
  • 336 Answers
SOURCE: Unit blew the internal fuse. SONY SA-WMS367 SUB-WOOFER
Bad output IC or voltage rectifier are the most likely at fault.
Posted on Nov 29, 2009
rulds2008
  • 3866 Answers
SOURCE: what is a suitable gale gold woofer replacement?
Really does not matter the point is you can rebuild the woofer for less then replacing with a new one but to each his own on this. But as long as its the same size anything would do for this monitor speaker.
I do not mean to sound generic but its true a woofer is a woofer it is what it is sure there are brands out there but they all work basically the same.
All your doing is buying the name.
Thanks please do click the thumbs above to give me a postive rating for my efforts today,
Posted on Feb 13, 2010
Testimonial: "thanks for your help."
Why does the fuse blow Instantly?
Link for the service manual: http://elektrotanya.com/pioneer_vsx-305_405.pdf/download.html On page 50 of the manual (36 of the pdf) it says for the "Sub woofer pre-out jack (Not available on the VSX-305 model) If you want to boost the low frequencies, connect to a subwoofer power amplifier" Your model will not drive a sub-woofer with out another amp. His sub may be a powered sub?
Aug 31, 2014 | Pioneer VSX-305 Receiver
Power sub woofer is not working on my pioneer vsx-81txv everything is working all the speakers except the power sub connection at the back all i can hear is the hissing sound when i try to connect the sub...
Hissing? How loud? A sub isn't even capable of making high frequency sounds at normal volumes.
The Pioneer manual would tell you how to enable and test the subwoofer output.
Page 17 and the MACCV procedures on Page 33 (auto) or 43 (manual)
Jun 13, 2011 | Pioneer VSX-81TXV Receiver
Sub-Woofer blowing fuses.
You should open it up and look for a short. Usually, an exposed wire is touching metal. Wrap the wire with electrical tape and look for a ground wires that are loose. That will blow fuses too.
Feb 15, 2010 | Harman Kardon HKTS 7 System
AV receiver single line output to two line input on sub woofer
You are trying to connect the powered sub output of the receiver to a standard (unpowered) subwoofer. Can't be done.
May 05, 2017 | JVC Audio Players & Recorders
Connecting a Sony Subwoofer SA-W2500 to a STR DE 598
It is based on your sub-woofer type..whether powered or passive sub woofer..
Assume that you have powered one..RCA sub woofer jack is the best to feed it ..you should use RCA sub woofer output on your receiver as well..good luck
Jan 08, 2010 | Sony STR-DE598 Receiver
No Sound
This might very well be a fuse - check by setting the sub woofer to "On" to see if it powers up. If it does, there may be a problem with the sub woofer audio cable(s) or connection(s).
Don't forget to check for a tripped circuit breaker or blown fuse on the stereo's speaker output. If your sub is connected to a low level output - this shouldn't be a possible cause - as circuit breakers & fuses are usually on amplified (high level) or speaker outputs.
Another possibility is that the settings of the stereo has been changed from a *.1 system to plain stereo 2.0 or some other setting that disables the LFE (low frequency effects) or sub woofer audio output.
Sep 18, 2009 | JBL Venue SUB10 Subwoofer
Connection of a subwoofer to Yamaha ZX-V490
Get a powered sub-woofer that has speaker level inputs, then run your front speaker wires into the sub-woofers speaker level input and then run a set of speaker wires from the sub-woofers speaker wire output to your front speakers. This is a common way to use a sub-woofer with a receiver that doesn't have a sub-woofer output.
Most powered sub-woofers have these connections, just check it out first before you buy one. They look like speaker jacks on the back of the receiver.
Let me know if you have any other questions.
Jan 02, 2009 | Audio Players & Recorders
Amp light is on but no power to my subs!
Hi There.
When you say the 40 Amp fuse blew. Was it your mains battery fuse or was it the fuse on the amplifier? If it was the fuse on the amplifier then you may have hurt the amplifier. The Kenwood KAC-8101D is a 1000 Watt monoblock amplifier. Therefore if you say that 1 of your woofers is not playing, then it is almost certainly blown if you are sure it is connected correctly. Try disconnecting it and only running the woofer that tries to play. If this woofer is still working correctly, you will notice a drastic drop if the sound of your bass. The reason for this is because you have changed the impedance load on your amplifier due to the fact that the other woofer is not working. Have your working woofer checked and replace the faulty woofer then you should be banging again.
Hope this helps!!
Jan 30, 2008 | Kenwood KAC-8101D Car Audio Amplifier
Sub-woofer output not working
"Sub-woofer output not working" problem, and notify you when a new solution is offered.
Press the setup key on the front of the receiver
Select the subw setting
Move the multicontrol knob until the sub woofer is on
Turn off the receiver and turn back on- the subwoofer should be on
The operator manual can be downloaded on the web site--- free
http://www.retrevo.com/support/Kenwood-VR-507-Receivers-manual/id/480ag219/t/2/
Sep 22, 2007 | Kenwood VR-507 Receiver
Subwoofer not working
if u are a technician then its easy to check, problems are, blown fuse, power amp IC output transistor may be blown, check for burnt componenets. changing and blowing a fuse means ur output IC or transistors are shorted.
May 15, 2007 | KEF Audio KHT 2005.2 System
342 people viewed this question
Top Gale Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Gale Audio Player and Recorder Expert? Answer questions, earn points and help others
