Question about Hotpoint BWM12 Front Load Washer
HI, My BWM 129 door wont open. The handle is loose and wont release the door. How do i get the door open?
ghappliances
  • 126 Answers
SOURCE: hotpoint BWM 129 washer
ARE THE PADDELS BREAKING OR MELTING.
Posted on Sep 15, 2008
beltronic205
  • 1460 Answers
SOURCE: i have a hotpoint bwm 129. clothes arnt coming out
is it rinsing okay is it pumping ok if not clean filter located at sump hose
Posted on Sep 30, 2009
  • 353 Answers
SOURCE: door handles slack feels like springs dropped so cant open door
You can release the catch from inside just keep trying and thern you need to replace the door catch itself this is a simple job
Posted on Jun 11, 2010
  • 1382 Answers
SOURCE: unable to open door
Remove the top cover, and release the door catch from inside the washer, you will probably need a screwdriver or similar to do do this.You will need to replace the door catch and spring, and possibly the door lock, as it may break when you force the door open.
Thank you !!
Posted on Jul 04, 2010
beltronic205
  • 1460 Answers
SOURCE: bwm 129 intergrated will not spin out the water
Check the pump is not jammed/blocked also filer which is located within sump hose bottom middle of machine
Posted on Jul 12, 2010
How to fit door seal to hotpoint bwm 129
two large clips one on outside other on inside
Apr 16, 2015 | Hotpoint Washing Machines
What part do I need? It opens from the inside. The handle is not snapped.
Are you saying the inside door handle isnt snapped,but the door wont open by pulling on the inside door handle or is it the outside door handle thats not working??Both the inside and outside door handle has a spring and other components on the backside of the handle which cant really be seen unless you remove the whole door handle assembly.One of these components are most likely broken or the rod that attaches between each handle and the locking mechanism(part that locks into the door striker to keep the door closed and releases it too)might have come loose from the back of the handle.The outside handle is usually mounted to the door by pop rivets or bolts/nuts.The inside handle is usually mounted with screws,but it really depends on what kind of car youre driving.Youll probably have to remove the handle to inspect it for damage.Open the door and watch the locking mechanism for movement while youre pulling on the door handle.If it doesnt move when you pull on the handle,the handle is definitely broke or the rod has come loose from the back of the handle.
Mar 09, 2015 | Cars & Trucks
DRIVERS FRONT DOOR CAN'T OPEN FROM IN OR OUTSIDE
There is a rod inside the door that connects the inside and outside door handles to the latch mechanism, if it gets bent or broke it won't activate the latch. The inside door panel will have to be removed and parts of the mechanism also to reinstall. Would recommend maybe taking somewhere unless it's an old BWM.
May 03, 2011 | BMW X5 Series Cars & Trucks
Hi my ford door wont open from the out side
This is a generic answer since you didn't say what year or model it is.
This requires removal of the door panel and PLEASE DO NOT USE A SCREWDIVER TO PRY THE PANEL LOOSE, you can get a cheap fastener release tool from an auto supply store. It looks like a carpet tack remover.
Inside the door there's a link that connects the outside door handle to the door latch. This link goes into a hole in the latch AND a hole in the door handle and is secured with clips. If one of these clips fall off, vibrations will eventually cause the link to fall out of these holes. Put the rod back into the hole and put a new fastener on it.
Jan 10, 2011 | Ford Fiesta Cars & Trucks
Unable to open door
Thank you !!
Jul 04, 2010 | Hotpoint Ultima WF860 Front Load Washer
Rear door wont open-hatch or window - can open hatch with inside release
Sometimes there is a safety sensor that does not allow it to open if the vehicle is in gear. This sensor may be faulty but most likely not the problem. Remove the inner panel on the back hatch and inspect the linkages from the outside handles to the releases inside the door for the glass and hatch. These have most likely came loose from the latches they operate
May 18, 2010 | 2006 Mitsubishi Endeavor
F22 code door wont' open
We had called Sears for an appontment, and the repairman did exactly what your technician had shown as the way to open the door - fortunately, he found that the wire connection to the release handle had come loose, so he had to get inside and reconnect it. Thank you.
Carl
Jul 21, 2008 | Whirlpool Washing Machines
Hotpoint BWM 129 washer
Jul 16, 2008 | Hotpoint BWM12 Front Load Washer
Washing Machine Door will not open
it is poss that you pressure system has not released, and this can keep the door closed. Unplugging it will not cure this fault. It is also poss that you have a blocked filter or waste. Unfortunatly has you are older people I would call an engineer
Jun 23, 2007 | Ariston Technologies AW129NA 16 Lbs Front...
Hotpoint BWM12 Front Load Washer Logo
69 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
