Question about USA Spec MERC99 6-Disc CD Changer
USA SPEC SCD F100i cd changer - manual removal of magazine
How do you manually remove magazine? Lable on bottom states "manual eject" ? Does the unit have to be wired mormally for magazine removal? I just purchased used and concerned that it functions prior to paying for installation - Thanks
3 Suggested Answers
SOURCE: car cd changer problem
cd changer not working in leganza
Posted on Jun 13, 2010
SOURCE: Need pinout for USA SPEC SCD-A88 CD changer
Sorry to hear it I had same prob with vw88e tried to email usa spec and get pin out but no results.. had to get the screwdrivers.. DO THIS ON A CLEAR TABLE WITH GOOD LIGHT !!face pops off easy enough ya gotta have 3 hands to gently hold ones youve popped and work the others then 6 little screws 3 on each side.. CAREFUL not to drop the little sliders for mounting in car they have springs that pull them out of thier home and they **** to get back in remove the top.you should be looking at the top now and can see the cartridge..and a little bit of the cd that was last playing.
there's a large gear.. with a pin in a half moon with a little flat tail lookin slot. if the pin is in the little flat area, carefully spin the gear until its out of flat and around to top of moon. cd that was playing is now in cartridge.. on the bottom in the back is another little gear (Between the mechanical case and outer shell) carefully spin that gear until the disk selector is all the way down (if it goes up or doesn't move spin the other way) keep spinning until cartridge ejects if you want reassemble if you just wanted disks toss it as is if reassembling just go reverse face plate goes on last
Posted on Sep 01, 2011
What aftermarket stereos will work with usa spec scd-f100
That unit is designed to work on Ford vehicles that have a CD button but no CD changer.
Oct 13, 2012 | Ford F-250 Cars & Trucks
I kept the CD changer from my jeep when I traded it. I disconnected the 8 pin plug and removed the unit. But I left the 6 CD's in it........any easy way to eject the CD's???
that depends on whether there is a tray loaded into the cd mechanism. if there is, you will either have to power up the changer or take it apart and remove it manually. if there is no tray going to the cd mechanism, you can use a thin flat object and slide it back and forth on the bottom of the magazine to remove it.
Jan 26, 2011 | Alpine CHM-S620 6-Disc CD Changer
The eject button does not work on my grundig rcd300 car stereo
Sorry but it have to be replaced or taken out and sent to be repaired.
Nov 06, 2009 | USA Spec SCD-VW44 6-Disc CD Changer
Need pinout for USA SPEC SCD-A88 CD changer. The unit has a short (~6in) cable with a round 8-pin connector on the end. In particular I want to apply 12V and GND so I can eject the discs that are trapped...
Oct 12, 2009 | USA Spec SCD-A88 6-Disc CD Changer
Eurovox 'Maestro Series' 10 stacker displaying 'E-99'
CD ERROR DISPLAYS
CD Changers
E01:
The disc magazine is not inserted in the cd changer
E02:
No disc is inserted in the disc magazine
E04:
The disc is dirty, or the disc is inserted into the disc magazine
upside down
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
FM/RF Remote Controls
E99 RESET PROCEDURE FOR REMOTES:
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
WAIT:
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds.
IF THESE ERROR CODES STILL KEEP APPEARING
CONTACT YOUR DEALER.
Jun 21, 2009 | iLO CA3000V CD Player
Car cd changer problem
Jun 18, 2009 | USA Spec SCD-D50 6-Disc CD Changer
My 2001 Jetta 6 disc changer has a cassette but I don't know how to get it out of the changer. Does the car need to be on?
The front of the disc changer has a sliding panel (usualy the left side slides to the right). After you open it completely either on left or right bottom (inside) you will see a little red or yellow push button. This allows to eject the cassette. No, the car doesn't need to be on, but depending if the wiring is standard or not it doesn't harm if the car is on.
Jun 14, 2009 | USA Spec SCD-VW44 6-Disc CD Changer
Inoperable CD changer
Hi the alpine/merc/bmw cd changer all seam to suffer with the same problem, they say no disc, or no mag try firmly hitting the mag with the handle of a screw driver. the loadinga arm, tends to get stuck. you could try using some grease on the arms, and levers, white spray gease works best. but dont forget to cover the laser beforehand, you dont want grease on it :) Mark www.carradiospares.co.uk
Mar 27, 2007 | USA Spec MERC99 6-Disc CD Changer
USA SPEC MERC99
Unplug all the cables, leave it out for several hours then replug it in and eject. This happen to me, I called 1-800 Mercedes and that's what they told me and it worked.
Sep 27, 2006 | USA Spec MERC99 6-Disc CD Changer
USA Spec MERC99 6-Disc CD Changer Logo
263 people viewed this question
Top USA Spec Car Audio & Video Experts
xxxxxx xxx
Are you an USA Spec Car Audio and Video Expert? Answer questions, earn points and help others
