Question about Vacuums
Broken power button. stays on if you keep it pressed!
Need to know how to dismantle so i can fix it! can't get the two sections apart and i have undone all screws i can see...
  • issigonis
    issigonis Dec 03, 2012
    It's a Vax mach vx 2. I've got the handle off & unscewed all four screws from the bottom 'ball' area but can't see anymore to unscrew that will allow the base to be released from the part that hinges which the handle attaches too.
  • Vacuums Master
  • 18,424 Answers
Model make please ?
Posted on Nov 29, 2012
3 Suggested Answers
  • 354 Answers
SOURCE: henry will switch on and stay on, only while the
Sweeper shop to get switch, you could have a wiring problem . Take casing off and check out and get those screws out of there they could cause some damage all while unplugged of course.bare wire coud cause your problem and thoe screws hopefully arent from the sweeper
Posted on Mar 09, 2011
SOURCE: electrolux contour 1100 flexihead. Z1436
You need to unscrew the screw at the back / base of the handle. The whole handle section will need to be slid backwards. Best way is to unscrew the screw on the rear approx 5 turns and then bump the end of the screwdriver. A few more turns then bump the end of the screwdriver again. The whole handle will eventually slide backwards and fall off. Then unscrew the two screws at the front (near switch) and the front switch cover plate will lift up (hinging at the top). This reveals the incoming wires etc.
Posted on Jul 09, 2011
How do I bypass the circuit breaker on power sweeper rainbow e series?
If it is broken and will not stay engaged it should be replaced.
Feb 16, 2018 | Rainbow Vacuums
How can I fix my Miele cat and dog vacuum cleaner. The electric lead will not stay out it keeps wanting to rewind. What can I do?
I think this model is a canister. If it is you might have broken the retractor reel from its bracket. Unfortunately it has to be taken apart and the part checked. Unless you are familiar with taking these apart you will need to bring it to a Miele dealer to have it looked at.
Mar 03, 2015 | Miele Vacuums
The cable is jammed in the sebo hoover winding unit, gentle persuasion wont get it out - how do I get to the cable to unjam it?
Have you tried holding down the release button whilst pulling out the cable?It could be the clutch mechanism has not released or engaged.. Assuming the cable didn't double wrap at some point.if this fails it may require you to dismantle from the base.i have worked on sebo vacs , they are a German company and very well made that can withstand harsh treatment without bits breaking off.but if you do decide to dismantle...disconnect from mains power source....take photos at each stage and be methodical ...keep screws to together for each section and if you come across springs try not to remove them before you know how they locate back into the correct positions when it goes back together.good luck!
Feb 01, 2015 | Hoover Vacuums
How to replace cord on phantom modelafv9038 ?
Try YouTube for videos or best plan is to leave it in with someone who knows vacuums. Don't risk taking it apart yourself unless you are confident around dismantled things. If it is a press-to-wind-up reel rather than a wrap-around-two-lugs cord, the most likely problem is the wires have become fatigued and have broken inside the insulation. A vacuum repair shop only needs to trim beyond the broken wires and then re-connect everything. They should not be advising you to replace the whole cable and certainly not to replace the whole reel assembly. hope this helps.
Aug 13, 2014 | Vacuums
Vacuum won't stay powered without holding the button down.
This is over a year too late, but perhaps this will help other people in your situation. Here is how the switch assembly should go together:
Jan 26, 2013 | Dyson Vacuums
My Power head on my Dyson Animal DC39 will not stay spinning. Suction Issue?
There should be a red insert on the right-hand side on the cylindrical bulge behind the brush cylinder. Check that this is moving when you push the button. The red insert should stay pushed in for the brush to rotate. The insert moves in an out as well as rotates in order to lock in the 'in' position. Mine is a little sticky on the rotation and I need to shake the brush head a little in order to get it to rotate and lock.
Jan 05, 2013 | Dyson DC39 Animal Canister Vacuum
Power brush keeps going off and on ,when off i keep pressing red button and switches on ...stays on if you keep it up slightly and not fully down
Just had the same problem. Took apart whole power head to look for broken wire and found none. If you see part way up the hose there is a coller with 4 torx screws holding together. This collar is a swivel that allows the hose to spin without twisting or kinking. Take the 4 screws out and open up. You will see 3 contacts that look like fingers that rub on 3 mating steel rings. Wipe the tips of the fingers and wipe clean the rings. Gently bend the fingers out wards so that they apply more pressure to the steel rings. Reassemble and try. Should take no more than 15 mins. Worked for me good luck!
Jan 06, 2011 | Dyson DC15 All Floors - The Ball Bagless...
My Electrolux Epic 6500 SR will not turn off by pressing on the switch button. I took it apart and removed the switch assy. I can maunually turn it off & on by pressing the rocker arm on the switch...
WOW !!! Finally You are dead on, absolutely 100%.... good work!!!.
Get only a genuine new switch button with spring from an AERUS Electrolux dealer and reinstall.
Then carefully reassemble the entire body and wiring harness.
Congratulations getting there.... you rate as an honorary technical genius in my book,...Your wife should be bragging about you to her friends. I am genuinely impressed and I`ve been fixing these since 1990. I bow in your presence.
PS while youre in there, check the rocker for evidence of fatigue, it is the more common issue
Nov 01, 2009 | Electrolux Epic 6500 Vacuum
Dyson dc15 ball/ taking apart
The Dyson site has a help section where you can read how to take the unit apart to unblock it. Maybe your solution can be found there.
Hard to tell since you didn't say what the part is.
Oct 15, 2008 | Dyson DC15 All Floors - The Ball Bagless...
Vacuums Logo
37 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
