Question about Sewing Machines
I have a singer a few years old the tension is loopy on the back
I don't have the manual
  • Sewing Machines Master
  • 7,365 Answers
Try adjusting the top thread tension one number or letter higher and
use a scrap piece of the fabric to test samples of the stitches
if you will let me know the model number of the singer machine I will
see if I can find you a manual
Posted on Nov 29, 2012
Australian S
  • 46 Answers
SOURCE: Replace the needle thread tension dial
If the entire assembly has fallen out you will find if you remove the top left hand cover that there is a small screw in the casting where the tension assembly goes, replace the tension body to the correct position and tighten the little screw.
Posted on Jul 02, 2009
SOURCE: need manual for Singer sewing machine model#100, about 12 years old
I have a manual for this machine..is there something specific you needed to know from the manual?
Posted on Mar 27, 2008
  • 7 Answers
SOURCE: How do i set thread tension on a 306W Singer
Top tension about 4 or 5, make sure the presser foot is up when you theread the machine, make sure you can just pull the bobbin thread through with some slight resistence, if it is too tight slacken the screw on the bobbin case a quarter of a turn at a time anti clockwise.
Posted on May 06, 2009
SOURCE: Bobbin stitch is loopy
4 is the "middle of the road" tension number, but it depends on the thickness of your fabric.
Posted on Jun 15, 2009
Zenqi
  • 208 Answers
SOURCE: Singer Featherweight tension assembly
Putting this back together is a thirty second job if you have done it a hundred times. If you have never done it but have mechanical aptitude, it may be a challenge.
Whatever you do, don't bend the check spring out of shape!
Below is a link to the Singer site with the schematic for reassembly. When placing the check spring back in place, place it in about the 6 o'clock position with no tension so that it has a fair amount of check before pulling it up in place..
When setting the tension, at a setting of "1" the tension disks should just be slightly compressing the beehive spring. "0" is almost no tension at all. Normal sewing is 5.
Get all of the parts together and push in the cup with the numbers while screwing on the knurled nut taking care to get the pin in one of the holes.
http://www.parts.singerco.com/CPpartCharts/2_2999/221-1_221K1_221K4_221K5.pdf
Posted on Jun 19, 2009
Singer touchtronic 2010
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
adjust the top tension one number or letter higher when the stitches
on the bottom are loopy, until the stitches become normal
also change the needle--flat side to the back side of the machine
check with singer website for a manual--some times they have free
pdf downloads
Go to the singer website
Click on customer support--there will be a drop down menu
Choose instruction manual
In the box type the model number( example 2010)
Click search
having a machine serviced once a year is a good idea & makes the machine last longer
and the sewing machine shop will tell you if they can get parts for the machine & if the machine is worth the money to fix it.
I myself have 2 sewing machines, when one is being serviced then I have the other one to use, so I'm not with out a sewing machine when I need one.
good luck
Debbi
May 17, 2012 | Singer Sewing Machines
My Singer 4562 looks fine on the top and the bottom is a complete mess...it looks like a bird's nest. I think it had to do with the tension but I can't figure out how to adjust this.
try these suggestions
1. change needle--flat side goes to the back of the machine
2.check the thread take up lever & see if the top thread stay on it or jumps off, that can make the birds nest you mentioned
3.top tension ususally is on 3 or 4
if you don't have a instruction manual follow these steps
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example 4562 ) & click search
if search comes up with nothing then contact singer customer service
and ask them
Mar 02, 2012 | Singer Sewing Machines
I recently obtained an Old Singer machine in a cabinet. On the front is a metal plate that states 1851 to 1951 100 years, also a metal plate on the front bottom of the machine with number AK213362. I...
hi, congratulations on the sewing machine, if you want to know more about the machine check out these two websites
Ismacs.net
sewalot.com
for the type needle & bulb & manual---check with sewvacdoctor.com
I check on the singer website for a free operation manual but I did 't come up with any thing so
definitely contact the sewvacdoctor for the parts & manual
Sep 05, 2011 | Singer Sewing Machines
My machine is a Singer Inspiration 4210. My stitch on top looks fine at first glance but it is birdnesting underneath. What should I do to correct this?
Check your top tension. It sounds like it may be too loose or the bobbin tension may be way too tight. Most likely it is the top tension that is incorrect though. The TOP tension effects the bottom side of the stitch and the bottom tension effects the top. If the top tension isn't tight enough it won't draw the thread up through the top side taunt enough and the excess underneath makes a big loopy mess.
Jul 29, 2011 | Singer Inspiration 4210 Mechanical Sewing...
Singer inspiration. When using zipper foot. Excess amount of thread on bottom of material, very loose and loopy. Wasting alot of thread for such a some task.
Your top threading is not right, check to make sure that your thread hasn't jumped out of a guide. Totally rethead with the presser foot up, now pull thread, it should move smoothly, next put the presser foot down, the thread should barely move. This will seat your thread in the tension discs. If, that does not work, insert a new needle.
Apr 23, 2011 | Singer Inspiration 4210 Mechanical Sewing...
Singer 5430C bobbins thread always loopy
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
Feb 15, 2010 | Singer 5050 Mechanical Sewing Machine
Can't adjust the tension on old singer!
increase top thread tension slowly till u get similar stitches on both sides
Nov 03, 2009 | Singer Sewing Machines
Jun 15, 2009 | Singer 132QRFB Mechanical Sewing Machine
I have a Singer Inspiration 4220 Sewing Machine. I was working on a quilting project last night, and everything was going fine, until I noticed that the thread on the underside of the fabric was very loose...
It's possible that there is foreign debris in the top tension assembly ,thread the machine and lower the presser foot and ensure that there is tension on the top thread
Jul 28, 2008 | Singer 7462 Mechanical Sewing Machine
Sewing Machines Logo
32 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
