Question about Brother HL-2040 Laser Printer
Prnbr001.inf not found
Trying to install Vista driver for Brother 5240 on Windows 7 Beta. How do I restore prnbr001.inf file?
  • 320 Answers
Go to and down load the drivers for vista
Posted on Jan 13, 2009
I want motherboard drivers for compaq KT477AA ACJ SG3430IL drivers (windows 7 32 bit ) Pls help me..
Windows 7 can be told to use the Vista drivers for most things.....did you try that ?
[ Note : This method should only be used whenever you have a "setup file" or .exe extension to run to install the drivers.]
Leave the device unplugged while doing this (Unless the drivers are stored on the device, for instance a Mobile Phone)
If you have already installed the Incorrect Drivers, then do a System Restore, or Restore a System Image, to a point before you installed the drivers, otherwise this might not work.
1. Right-click the Setup File and choose -Properties-.
2. Next, click on the -Compatibility- tab.
3. Then, check the box marked "Run this program in compatibility mode for" and select -Windows Vista- from the drop-down list.
4. Next, check the box "Run as Administrator", then press the [OK] button.
5. Run the setup file as normal, and should allow the installation of the Vista driver files.
Sep 11, 2012 | Compaq Computers & Internet
I have an dell vostro 1310 an my bluetooth stop work after i put windows 7 on it so i put back the original windows vista on it an my bluetooth still does not work
Try this program, I bet using this you could even get it to work on Windows 7.
This small freeware utility will try to install generic Microsoft driver for your bluetooth adapter. The program is based on a widely known method of patching %WinDir%\inf\bth.inf file.
It works for most (but not all) bluetooth adapters, both USB dongles and built-in.
Before making changes to your system the program automatically creates a restore point. If anything goes wrong you can use Windows System Restore feature to revert all changes made to your computer.
Jan 29, 2011 | Dell Computers & Internet
My vista does nnot recognize one partition on my
1. In the run command (Start menu bar) type "regedit" to bring up the Registry Editor.
2. In Registry Editor, navigate to:
3. In the details pane, double-click DevicePath.
4. Add a semi-colon to end of the existing text, and then add the path to %SystemRoot%\System32. The result should be similar to: %SystemRoot%\inf;%SystemRoot%\System32
Do not remove the %SystemRoot%\inf file path from the DevicePath registry entry.
5. Click OK to save the new value, and then close Registry Editor.
6. Delete “INFCACH.1” FROM C:\Windows and C:\Windows\Inf Directories (if it exists)
7. Ensure that there is a copy of the usbstor.inf file in C:\Windows\Inf
If there isn’t – follow the below steps:
a) From another Vista system (copy it out of another Vista system and copy it directly into the C:\Windows\inf directory
b) From the problem machine, run Command Prompt ( as administrator). From C:\ do a dir usbstor.inf /s . Wherever the file is found, go to that directory and copy all the files located in that directory to C:\Windows\inf directory
8. Open device manager, uninstall all unknown devices (right click, uninstall) so they all disappear from the list
9. Reboot the computer
10. Plug the device in (the drivers will now install and the device will be usable!)
Mar 06, 2010 | Electronics - Others
INF file not found
the file is corrupt please look for another one
Oct 07, 2009 | A4tech PK-635 Webcam
LG DVD gsa-h55 driver .inf file
I doubt that you'll be able to getmuch support for a product that hasn't been released to the puiblic yet.
The edition you have will be a Release Candidate which was released to developers to find any bugs.The RTM has only just been released to manufatures so that they can develop the drivers for when it goes on general release.
Basically you're jumping the gun a bit.
Aug 05, 2009 | LG GSA-H55N DVD-RAM Burner
Driver help PLS
Try here >
Apr 26, 2009 | Brother HL-5270DN Laser Printer
Problem in canon
i found a solution for printing with Canon MF 3110
1- Download Driver For MF5730/5750/5770 For Vista 64-Bit
File Name : L7602ENx.exe
Follow These Steps
1- Add Printer
2- add a local printer
3- Use an existing Port : Choose : USB ( Virtual Printer for USB )
4- Have Disk
5- Locate the File Name : MF5700AK.inf
6- Printer Name : Change From Canon MF5700 Series To Canon MF3110 Series
7- Print Test Page
it Work for me on Vista Home Premium SP1 64-Bit
still Cant Manage to use the Toolbox for Scanning ( Any Ideas ? )
Oct 22, 2008 | Canon MF3110 All-In-One Laser Printer
No valid INF file when trying to install Z640 to windows Millenium
The drivers are not designed for WinME.
The Lexmark driver for that model only supports Windows 2000, XP, Server 2003, and Vista.
Unfortunately, none of these drivers will work on WinME.
Mar 21, 2008 | Lexmark Z640 InkJet Printer
Epson GT5500 Flatbed scanner
unfortunately Epson has not made a driver for this scanner that is compatible with Vista and from the looks of it, they don't seem to have any plans on making one!
Jan 29, 2008 | Epson GT 5500 Flatbed Scanner
MFC 8420 Problem
Hi, .inf are product information files and tells the computer the specific brand/model and drivers needed for your all-in-one and are OS specific. They are normally found inside a folder named DRIVER with other files such as .cab, .dll, .sys, etc. The installer sometimes compresses all of these files in an .exe, .zip or .rar to reduce file sizes. Double clicking on the download compressed/installer will expand or auto-install. Your download must match the brand/model of the all-in-one and your operating System, XP, Vista etc. Your drivers/installers may be found here > Hope this be of some help to you. Pls post again how things turn up or if we can be of further assistance. Cheers.
May 01, 2007 | Brother MFC 8420 All-In-One Laser Printer
Brother HL-2040 Laser Printer Logo
2,092 people viewed this question
James Cagle
James Cagle
Jim Keysor
