Question about Hoover Washing Machines
What does the fault code E16 on my hoover washer dryer mean
SOURCE: Fault code F20 on kenmore he2t clothes washer
I have a brand new front loader that never fill with water but shows F20. How can I get this machine to wash clothes?
Posted on Aug 09, 2008
BIKER T
  • 909 Answers
SOURCE: Hoover oph714d - error code e16. What does it mean
Where in the program is this happening?
Posted on Sep 20, 2009
  • 155 Answers
SOURCE: My hoover washer dryer VHD is showing a fault E11
It means there is a problem with the dryer board on it.You can try removing
the lid and just check the dryer control board on it.Make sure the
connections are ok and that none of the wires are broken.Then if the wires are ok the dryer control board will need to be replaced.
Posted on Apr 10, 2010
  • 343 Answers
SOURCE: iw712 fisher and paykel washer has fault code 37 w...
37 is drain error..There could be electronic reasons, but the most common problem is that there is a clogged pump or something is jammed in the pump impeller... Empty the machine of water and lean back against the wall so you can get access to pump, which is clipped to the bottom of the drum..Try turning the fan and see if the pump is blocked'/jammed.....Disconnect the wires and rotate the pump motor anticlockwise...It will be prevented from turning by a small plastic latch. Unlatch and remove pump motor...Remove any detritus and refit pump motor....If the motor resistance is less than 33 ohms (230volt) or 7ohms (110volt)..the pump motor itself might be the cause of the fault code, and should be replaced......This is a very simple job for a tech...Good luck....Nomess
Posted on May 24, 2010
richroth
  • 9472 Answers
SOURCE: My Hoover VisionHD washing machine
E16 is for an "open circuit" on the heater.
Posted on Jan 03, 2011
Hoover washing machine error code16 has come on
Hi!
Baically, Hoover washing machine error code E16 means that there are problems with the insulation of the heater. this may lead to the shutdown of the circuit breaker and other random errors, but this is difficult to prove without replacing the heating element.
Apr 27, 2017 | Hoover Washing Machines
What does e16 mean please?
An E16 error code means there is a heater insulation problem which could cause the tripping of your fuse box and other random cycle errors, but it's hard to prove without the replacement of your heater.
For more information on other error codes , watch this video .
http://www.espares.co.uk/advice/0/2531/how-to-understand-hoover-and-candy-washing-machine-error-codes
May 15, 2015 | Hoover Washing Machines
MY FRIGIDAIRE DRYER STOPS AND THE DISPLAY READS E16
I appreciate your post, Deejanae!
I see that your Frigidaire dryer is displaying an error code of "E16". It appears that "E16" is an invalid code. I would recommend performing a reset on your dryer and you can do that by flipping the household circuit breaker off for at least ten minutes. If you continue to experience an issue with an "E16" error code I would recommend contacting a professional technician for proper diagnosis and repair. This will help you avoid any unnecessary part purchases. -Matt
Apr 22, 2015 | Frigidaire Dryers
Wot is e16 mean
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3450-hoover-optima-fault-codes-carbon-brush-motor.html
looking here i see that error 16
tells us that the heating element has gone bad and needs replaced
or the wiring is bad
could just be a loose plug on the htc/ temp regulator
you can check it but its pretty clear by the error
so look to hoover spares ebay etc espares etc for the cheepest if you feel like replacing it yourself
Dec 09, 2014 | Hoover DYN8163D8X White 600 mm Washer...
Hoover dyn8164d had code E03 then E16 now E08
Hi.
These specific codes indicate the following:
E08 means that the Motor jammed or tacho fault
E16 means that the heating element is shorted or that there is a short in the circuit containing the element.
E03 This error code indicates that the water is not draining quickly enough.
Before doing anything it is worth removing the washing machine mains plug from the power outlet and leaving the machine disconnected for at least ten minutes. This will reset the codes if no faults still exist. Then plug the machine back in and select required wash routine. If all is well, well done you just needed to reset the machine. If a fault code is still showing then it would indicate there is still a problem in the area indicated.
You said you had checked that the filter was ok, it is also worth checking that your drainage hose is not blocked or
kinked.
Jan 11, 2014 | Washing Machines
What is error code 16
If it is an Optima with a brushless motor (I only have those fault codes for Hoover), 'E16' means 'water heater element insulation fault'. Sorry ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jul 31, 2011 | Hoover Washing Machines
Hoover wash-dryer 110 soft wave It doesn't centrifugate. I would imagine that I have to clean the filter, but I cannot find the filter. Thank you beforehand for your help. Christina
hi christina,,,its dont centrifugate???????? hmmm! do you mean spin?
or it dose spin,,, but dont pump out? if its not spining there is a program fault,,,or motor fault,,,,if it dont pump out,,,thats a pump fault,, program fault or a blocked filter,,,the pump has its own motor,,,however if there is a program fault that could cause the pump to fale to pump as well???
my brain hurts now!
Aug 07, 2010 | Hoover AAA160 Front Load Washer
Error 16 on hotpoint wd71 n what does it mean???
F16 - Extremely high water level Disconnect or turn off the water supply and ensure that the water level does not rise any more. Then Book a service engineer
Mar 12, 2009 | Hotpoint Ultima WD72 Front Load...
Hotpoint ultima 1200 wm72
code e30 means motor fault. this can be just motor brushes, tacho fault or module fault. can't narrow it down more than this - you will have to dive in and check
Apr 05, 2007 | Hotpoint Ultima WD72 Front Load...
Washing Machines Logo
80 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
