Question about Gale 3070W Subwoofer
How do i convert a Gale 3070 sub woofer from active to passive?
The inner fuses are blowing so I would imagine it would not be worth repairing. I have seen one on ebay that has been converted so I was wondering ho this is done
3 Suggested Answers
rulds2008
  • 3866 Answers
SOURCE: what is a suitable gale gold woofer replacement?
Really does not matter the point is you can rebuild the woofer for less then replacing with a new one but to each his own on this. But as long as its the same size anything would do for this monitor speaker.
I do not mean to sound generic but its true a woofer is a woofer it is what it is sure there are brands out there but they all work basically the same.
All your doing is buying the name.
Thanks please do click the thumbs above to give me a postive rating for my efforts today,
Posted on Feb 13, 2010
Testimonial: "thanks for your help."
  • 19 Answers
SOURCE: I have a gale 3070 sub woofer. When I connect it to the power with no audio connection being made, the inner fuses blow. can anybody help
if a fuse keeps on blowing there is a problem with the amp, Take it in to be repaired, Or just get a different one, It will probally cost you less just to get a different one,
Posted on Dec 03, 2012
How do convert my active sub to passive sub speakers
Disconnect the subs amp from the driver. Run wires directly from the driver to whatever amp is now powering it. If the drivers impedance isn't too low, that should work.
What won't usually work is a one or two ohm car woofer on a home stereo/ theatre setup. The impedance is too low.
Nov 10, 2016 | Audio Players & Recorders
Nov 29, 2012 | Gale Audio Players & Recorders
I ended up with one piece of a Teac model CD-X8 MIcro Hi Fi System. you can see what the whole system looks like at http://www.amazon.com/Remanufactured-CD-X8-Wall-Mountable-System-Subwoofer/dp/B000B65GV6...
Yes - you have the sub-woofer. It is a powered sub-woofer with a built in amplifier for both itself and a pair of small satellite speakers. Frankly, given the low cost of the whole system it may not be worth selling on ebay due to the high shipping costs of such an item, but I imagine you could get $30 for it or so on local craigslist or something, assuming you have no use for a sub-woofer...
May 05, 2011 | Audio Players & Recorders
I have a JBL TLX CSS-SUB1 sub at the back are where you connect the speaker wires to the receiver but i don't know witch wire goes in what? i have no clue
The connection on the receiver would be the sub woofer out. Not a sub woofer out LFE, a sub woofer out with speaker wire connection. From there you plug it in to the top section of the available terminals on the sub you are referring to (speaker level input). One in positive and the other in negative matching what you did on the receiver with correct ends. The speaker connections underneath the top connections is for additional speakers like surrounds to be able to be connected directly to the sub woofer speaker level out for sound. This of course would be for an older receiver connection. I do not think it is possible to convert this connection to an LFE and have it work properly. If the receiver does not have sub woofer speaker connection and only a RCA out then you can try to connect both rear speaker connections from the receiver to the speaker level inputs on the sub and then connect your rear speakers to the speaker level output on the sub to power them. This is an active sub woofer but for some reason they made it connect as if it was passive. I am not sure if this sub is designed for really low frequencies required for movie or if it is better for music.
Nov 01, 2010 | JBL Audio Players & Recorders
I been having a problem with my JBL TLX CSS-SUB1, I don't have the manual. Connecting speaker wires from the JBL TLX CSS-SUB1 to the a Digital Audio/Video Control Center ( it's a reciever) I confused,...
Nov 01, 2010 | Audio Players & Recorders
Cerwin vega passive subwoofer model sw-12b
Passive woofers are hooked up to the output of a sub amp.
Active woofers are hooked up to the sub out of a receiver. They have the amp built in.
Mar 09, 2010 | Cerwin Vega Audio Players & Recorders
Is denon 1356 with active bass. and i want to know the difference between active bass and passive bass.
Hi....
A passive bass is a box with a sub-woofer in it.
An active bass is a box like that with an amplifier built in.
Hope that helps.
Check the Denon site too
Dec 26, 2008 | Denon AVR-1803 Receiver
Eltax DR-110 Sub-woofer issue
Where have you connected the sub's leads?
Feb 26, 2008 | Audio Players & Recorders
Sub woofer keeps blowing fuses
NO dont try a 3 amp fuse.It is made to BLOW if there is a problem. That sub is not worth fixing, JUNK it. There are a lot of problems with it. Such as heating up and melting the board witch could cause fires. Thats what happened to mine. Like I said JUNK it and buy a different one.
Nov 19, 2007 | KLH ASW10-120 Subwoofer
Gale 3070W Subwoofer Logo
41 people viewed this question
Top Gale Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Gale Audio Player and Recorder Expert? Answer questions, earn points and help others
