Question about Maytag Dryers
My gas dryer has stopped working. Model # pye2300ayw I have checked breaker, plug, and door. They do not seem to be the problem. Any suggestions
Maytag Performa PYE/2300,3300
  • Danielle Walters Nov 29, 2012
    Problem fixed! Thanks! Replaced high thermal kit for only $31.45.
    Top Expert:
  • Maytag Master
  • 9,472 Answers
Does it spin?
Posted on Nov 30, 2012
aborcass
  • 2651 Answers
SOURCE: Will not turn on
the most common fault is a faulty thermal fuse heresd the part number for the replacement LA-1053 you can release the top assy by popping 2 clipps approx 6in. in from each side unde the front of the main top assy. the thermal fuse is located within the heater assy box direct;ly in the rear just under the main top. the kit includes a few tehremos and instructions depending on you rmodel
Posted on Nov 03, 2008
dinomb
  • 16 Answers
SOURCE: Maytag Electric Dryer Stopped Working
Check spring tab behind door switch-if it's bent/out of adjustment, circuit will act like door is always open.
To confirm this, open door, set dryer to active setting, and hold in door switch; if it comes on, then it's either the spring tab, or the switch is malfunctioning
Posted on Mar 30, 2008
mastatech
  • 478 Answers
SOURCE: Maytag Performa Dryer won't start.
I would suggest checking and probly replacing especially if you cant hear the timer motor.
Posted on Mar 28, 2009
localwonder
  • 6784 Answers
SOURCE: Maytag Performa Electric Dryer will not turn on
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer/control
Replace if defective (note: uncommon problem).
Posted on Jun 07, 2009
Illeagle
  • 525 Answers
SOURCE: Maytag Performa PYE G2200 gas dryer, the dryer
Based on the information provided, it sounds like a broken drum belt is at fault. Below is an illustration of the drum belt.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-PYG2200+-%3d%3di529597&PartID=529597
Here is a parts/disassembly diagram:
http://www.repairclinic.com/Dryer-Gas-Maytag-Style-Appliance-Diagram
Here is a belt installation diagram:
Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
All links courtesy of www.repairclinic.com
Posted on Aug 17, 2009
Model # pye2300ayw it seems to run fine but no heat?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 18, 2011 | Maytag PYE2300AY Electric Dryer
My Maytag Performa electric dryer will not start. The Model # is PYE2300AYW, Serial # 10923714ZB. It was working fine but will not turn on now. I have checked the breaker box and it is in the on...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Jan 16, 2011 | Maytag Dryers
My dryer will not start
A dryer may not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Apr 12, 2010 | Maytag PYE2300AY Electric Dryer
My dryer won't do anything. Maytag model PYE2300AYW REV 10, Serial 10604533ZU
First thing check the circuit breaker to see if it is tripped or if it is a fuse style if the fuse is blown. Next if that all checks out okay check the door switch and see tha the door switch is being made when the door is closed. The machine will not operate with the door open and if the switch is bad or stuck open then the machine will not work.
Jan 18, 2010 | Dryers
Maytag electric dryer (PYE2300AYW) does not stop on auto cycle.
Either the control board or the humidity sensor is bad.
Jan 11, 2010 | Dryers
I have a Maytag PYE2300AYW. Push button but nothing happens. Had breakers to house checked and all good.
Dryer suddenly stop working when pushing start button (knob will make a humming or ticking kind of noise but won't turn on. I cleaned and check the outside exhaust and lint screen passage. Nothing is helping. help
Jan 08, 2010 | Maytag PYE2300AY Electric Dryer
Maytag Dryer model number PYE2300AYW will not start.
check your fuses in the dryer their is only one fuse that could shut down the whole dryer like that. Open back panel and get a volt meter and check for continuity on the fuses. HOW? first un plug it then open back then you will see the heating element their are 2 fuses on the heating element take off wires and check those.Then if those are ok look down thier is another fuses its long white with 2 wires comming out of it with a black center that should be your problem check it repair it run it . GOOD LUCK
Oct 12, 2009 | Maytag Dryers
Maytag model PYE2300AYW won't do anything at all
Hi, Did you check the safety fuse on the right side of the heater housing? Little fuse with two white wires going to it?
Please let me know if I can assist you further.
Vic
May 23, 2009 | Maytag PYE2300AY Electric Dryer
Magic chef dryer
hi there,
she may have tripped the house breaker. unplug the machine and check the breaker on the house electrical box. plug the dryer back in and see if that will work.
Sep 30, 2008 | Dryers
Dryers Logo
94 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
