Question about Sewing Machines
Why does the bobbin thread clog up and i need to find out how to thread machine right
  • Sewing Machines Master
  • 7,365 Answers
Try using a new needle
try a different bobbin just incase there is something wrong with the
that one.
make sure the bobbin winds the thread evenly on the bobbin
make sure the bobbin is inserted correctly into the bobbin case
what is the name and model number of the machine and I will see if
I can find you a manual
Posted on Nov 29, 2012
SewExpress
  • 41 Answers
SOURCE: Picking up the bobbin thread
A few suggestions:
  1. Rethread top of machine from scratch with the presser foot raised, i.e. remove thread completely from all thread guides & paths and start from scratch, making sure thread is securely seated between tension disks. Once the needle is re-threaded, lower the presser foot and give the tail end of the thread a tug to make sure there's tension on it.
  2. Make sure the bobbin is turning the correct direction for your machine - and that the thread tail is under the tension plate or bobbin tension guide (depending on machine).
  3. Blow out any fuzz.
  4. Insert a new needle, making sure needle is pushed all the way up.
  5. Oil machine (in locations recommended in your owner's manual).
If the basic cleaning and re-threading (above) don't help, your machine(s) may be out of time or have another mechanical issue that will require a repair technician. We recommend a tech trained on your specific brands - they'll be better trained and able to get any repair parts that may be needed.
Hope this helps narrow down your stitching problems.
Happy sewing,
Kim & Linnette
Posted on Jun 27, 2008
bilabon
  • 46 Answers
SOURCE: Threading the Bobbin
Place the bobbin in the bobbin case making sure the thread feeds clockwise. Draw the thread through the slot on the case. Continue to draw under the tension spring and through the opening pulling out about 6" of thread. Hold the latch open, position the bobbin case into the suttle and release the latch. THe case should lock into place when the latch is relaeased.
With the top thread, hold out about 5" to the left. While holding on tot he top thread, turn the hand wheel toward you and you should see a loop at the feed dogs. grab the two thread and bring them behind the presser foot.
Bonnie
Posted on Sep 02, 2008
  • 4 Answers
SOURCE: singer quantum sewing machine won't pick up bobbin thread
Try changing your needle
Posted on Dec 13, 2008
  • 108 Answers
SOURCE: need manual for model 5825c for threading
i was able to find it at www.ifixmachines.com
Posted on Feb 15, 2010
SOURCE: The bobbin thread is not
try a new needle
make sure the bobbin is not warped
make sure the bobbin case area is free of lint or loose thread
make sure you hold the upper thread tail while it's going down to pick up the bobbin thread
make sure there is a 2 to 4 in tail for the upper thread to grab
Posted on Aug 02, 2010
The upper thread won't catch the bobbin thread and pull it up
This is a symptom of wrong timing between the hook and needle in your sewing machine. Try to pull up your bobbin thread by setting your needle to the left and then to the right. If it will bring up the bobbin thread whiled set to the right but not the left you have a timing problem. It can be corrected by a pro but it most likely will need to have some gears replaced also.
Dec 16, 2017 | Sewing Machines
My Bernina 200 bobbin thread snagged and now the bobbin thread will not catch the top thread when I sew, thus, there are no stitches made in the fabric.
1. CHANGE NEEDLE.
2. ADJUST BOBBIN TENSION. MAKE SURE YOU ARE USING THE RIGHT BOBBIN FOR THE MACHINE. THE WRONG ONE WILL NOT ROTATE FREELY. HANG FROM FINGER AND BOB. SHOULD EXTEND ONE INCH WHEN ADJUSTED RIGHT.
3. ADJUST TOP TENSION. (START AT 3)4. EXTEND TWO INCHES OF THREAD FROM BOBBIN. HOLD TOP THREAD TO THE FRONT AND A LITTLE TO THE RIGHT.
5. TURN HAND WHEEL TOWARDS YOU. THE BOTTOM THREAD SHOULD COME UP FROM UNDER THE PLATE.
6. IF THE THREAD DOESN'T FEED FROM THE BOBBIN TO THE TOP OF THE PLATE THE TIMING IS OFF AND WILL NEED TO BE ADJUSTED.
Jan 02, 2015 | Bernina Sewing Machines
Machine is Jammed
Try turning the wheel to the right end manually----briskly back and forth to loosen thread that are caught in the bobbin. Remove bobbin and clear threads. If none, remove plate below needle to see if thread or fluffy threads are clogged below. No good...have it serviced by a professional.
Apr 06, 2014 | Singer 7422
I can't get the tension right
try rethreading the machine--use every thread guide
make sure the top thread has not come off the thread take up lever
change the needle --make sure it's the right one for the fabric
being sewed
make sure the bobbin is turned the right way in the bobbin case
if the bobbin is a front or side loading also make sure the bobbin
case is inserted correctly into the machine
if none of these suggestions help then the machine needs to be
checked to see if it's a timing problem
Dec 14, 2012 | Sewing Machines
My machine keeps clogging at the beginning of my sewing
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Dec 12, 2012 | Janome Sew Precise Mechanical Sewing...
I have an Elna Funstyler sewing machine and when i sew zig zag the bobbin thread shows up on top, have tried changing tension and doesn't help. Is there any way to oil this machine? Instruction manual say...
If your thread tension is OK and u have correctly threaded machine, I would check manual for first the right bobbin and put in machine right. I have have issues from badly wound bobbins too. If you have replaced correct needle and your fabric, thread and tension are good, I would check manual for the right bobbin tension. Wish I knew more to help......
Dec 15, 2010 | Sewing Machines
My bobbin thread keeps coming to the top of my fabric during embroidering on my Singer Futura CE350, I've tried bobbin embroidery thread, regular embroidery thread and clear nylon thread, I've tried...
With the embroidering, some of the bobbin thread is SUPPOSED to show on the top of your embroidery-the machine isn't doing anything incorrectly. You'll need to thread your bobbin with the same thread as you are using with the top. I had the same "problem" when I first got the machine and took it to a wonderful local technician whose helped me with a lot of things who informed me that this is perfectly normal on embroidery machines.
Oct 23, 2010 | Singer CE350
When I sew a few inches, bunches of threads come out of the bobbin case. It's like it gets clogged or something. I'm getting nowhere with this. Help!
If your bobbin is the correct one for your machine and it is wound tight, not loose and puffy, make sure the thread is going the right way when installed (over the top to the left and then placed flat in the bobbin case). Usually if the thread bunches underneath your fabric it means that the TOP thread is threaded incorrectly. Try re-threading the upper thread. Good luck!
Aug 21, 2010 | Brother LS-2125 Mechanical Sewing Machine
My needle keeps coming unthreaded. HELP please
1) Open the needle plate and bobbin case and make sure the tangled threads are removed.
2) Open the manual; read and follow every step.
3) Thread the machine with the presser foot up - this is often overlooked and causes loopy stitches that pull right out.
4) Make sure the bobbin in inserted so the bobbin thread is feeding from the bobbin spool in the correct direction and through the proper guides.
5) Take hold of the needle thread and lower, then raise the needle to pull the bobbin thread up through the needle plate. Take both threads under the presser foot and to the back of the machine.
6) When you come to the end of the stitching, make sure the take up lever is at it's highest position. This will keep the thread from coming out of the needle when you begin to sew.
I hope this will help and you will soon be sewing.
Mar 10, 2010 | Sewing Machines
Thread clogs up bobbin and knots up thread on back side of fabric
hi there,
well, common problem when you didn't acquired right set up of tension and clean feed dog,bobbins,shuttle race.on figure right bobbins winding.d329aa1.jpgset up counter clokwise thread rotation, set dial tension on #3 to #4, dial stich to # 8 to #12
only on cotton fabrics,others fabrics such as silk..etc,gradually adjust tension fine the smoothest adjustment,
on fig,thread looping top side threading50302ec.jpg follow threading so you can have fine sewing.also clean under bobbins from chips fabric and dust.have a nice day,don't forget to rate my fix,ythanks a lot
May 16, 2009 | Necchi 3101 Mechanical Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
