Question about Dometic Rooftop RV Air Conditioner
How many BTUS on rooftop AC unit on 32 ft. FEMA trailer?
Trying to figure out what size generator to get.
SOURCE: what size generator, watts, doe's it take to start AC unit 57915.531 ?
a 10000 due to the startup surge. also need start kits on any ac started by a generator.
Posted on Oct 10, 2008
  • 127 Answers
SOURCE: coleman rooftop a/c unit is fried? i plugged my
If there Air Conditioner is wall thermostat controlled, then take the front cover off the thermostat and check the fuse. If the fuse is ok, then take the inside cover of the AC down and pull down the control box that is mounted in the intake section of the AC. It is held on with two wing nuts. Remove the cover and observe the relays and the incoming AC wiring. Make sure that none of this is burnt. If all looks ok, turn power on and turn the thermostat to High Cool and check if you can hear the relay click inside the control unit. If not, then check to see if the thermostat has 12V going to it. Start there and see how that goes.
If it is controlled by the ceiling mount t-stat and selector switch. Remove the inner shroud and check the incoming AC wires for OK. If they look ok then check the selector switch and the thermostat.
The Refer has protection from this. Depending on which refer you have (Dometic or Norcold), the process is a tad different. If it is a dometic, go to the outside of the coach and remove the access panel on the rear of the refer. Remove the black cover from the control board (lower left side) and check to make sure that the 120V fuse is good (You will need an ohmmeter to check). If it is fine the check to see if you have power going into the 12V block at the very bottom, rear of the refer. If there is 12V there, then check the plug that the Refer is plugged into for 120V. If none, check the GFCI circuit in either the bathroom of the kitchen. If tripped you will have no power to fridge. Start there and then we will move forward.
Basic same checks for a norcold, board is harder to remove as you have remove wires. Mark and remember where they go.
Hope this helps,
Jeff
Posted on Jun 30, 2009
  • 59 Answers
SOURCE: How to identify the btu of rooftop AC unit
ANY # DIVISABLE BY 12. MODEL HAS  12-24-30-36-40-48-54-60 12 1 TON 24 2 TON 30 2 1/2 36  3 TON 36.00 BTU 40 3 1/2 48 4 TON 48.00 BTU 54  4 1/2 60 5 TON   60.000 BTU
Posted on Apr 21, 2010
MOTORWIZJ
  • 1383 Answers
SOURCE: 2007 dometic Rooftop AC "high-lo" switch. What does it do?
YES WITH OUT A DOUBT .. DO NOT TRY TO RUN IT ON HIGH IT MAY DAMAGE YOUR GEN SET ... HELP ? PLEASE VOT
Posted on May 28, 2010
  • 14 Answers
SOURCE: i just bought a fema trailer and its missing the
yes, but when you take the cover off you will discover the name plate with the proper info to replace the remote, also your fema preparer might have placed the remote there as well. thank you and good luck
Posted on Feb 03, 2011
How can I solve this problem
Should still be under warranty take back to deller.
May 22, 2014 | Dometic Rooftop RV Air Conditioner
I HAVE DOMETIC DUO-THERM PENGUIN ROOF AIR CONDITIONING ON RV. THE UNIT WILL RUN WHEN PLUGGED INTO ELECTRICITY BUT WHEN GENERATOR POWERED THE AC UNIT KILLS THE GENERATOR ENGINE. WHAT COULD IT BE?
What size & type generator? On start up the AC unit can draw as much as 17-18 amps in some cases, and if your generator is not designed for a quick draw like that it will die.
Jan 25, 2013 | Dometic Rooftop RV Air Conditioner
Recently purchased a 4400W generator to operate travel trailer primarily and on occasion my ac unit. Connected the generator to the travel trailer, then ran the a/c, everything going well, then the circuit...
What size circuit breaker is on the generator that is tripping? You'll need a 20amp for AC alone, then consider other things that are drawing current when RV plugged in like , converter, fridge etc that may be drawing current at same time. Make sure fridge is on propane, as well as water heater if you have electric element option on water heater. AC may only draw 12-15 amps when running if good and clean and wired properly, but will draw 17-18 amps when compressor kicks in. Perhaps generator not designed for that surge?
Aug 28, 2011 | Dometic Rooftop RV Air Conditioner
The trailer did not have a air conditioner in it before the trailer place installed the new dometic air conditioner. The trailer year is a 1976 AMF Skamp. I told the trailer place that I wanted a 15000 btu...
You have too small a cord on it if it's heating up and then popping your breaker. The a/c has am amp rating on it's data tag, read it and then read the amp capacity of your breaker and the cord your using. If the a/c draws more than 80% of the rated amps for the cord and breaker then you need to find another way to power it up with a bigger cord and a bigger outlet. DO NOT just install a bigger breaker, it is sized for the wiring in your home and a bigger amp draw on that wiring could burn your house down.
Jun 17, 2011 | Dometic Rooftop RV Air Conditioner
I just bought a fema trailer and its missing the ac remote i know its a CARRIER but unsure of model number can i use a walmount thermostat instead
Feb 03, 2011 | Dometic Rooftop RV Air Conditioner
I'm running my RV 115V 60hz a/c while connected to a 4,000 watt gas generator, with no other loads. The A/C has constant cold air, but seems to have an oscillating sound. The trailer is not completely...
this is normal, do not worry that harmonic vibration type noise just tells me that the unit has a full freon charge and is running great, sit back and enjoy
Aug 10, 2009 | Dometic Rooftop RV Air Conditioner
Ac wiring problem
as a general rule ,only if your ac was a window unit. aka a 120 volt unit . all other acs use 240 volt. a 120 leg and a 120 2nd leg to equal 240, so there is really no common. what kills acs with a generator is the lack of watts and starting torque. an ac (3 ton) and up needs a generator of 10000 watts minimum to handle starting trque. they also need a hard start kit to boost starting voltage.for god sake someone reply and tell me what a good job i am doing!!!!!!!as in grade the response to your question.
Oct 17, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
138 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
